SOURCE: Craftsman 42" 19.5hp B&S Stalling
i have a crafsman mower and it only cranks it wont start wat would be wrong
SOURCE: Need an owners manual for a craftsman lawnmower model 917254240
Hello kwoody2315:
>>To View a Breakdown of this Unit Go to this Site Addy, http://www.searspartsdirect.com/partsdirect/index.action?sid=PSHx20080114x00001 and Enter the Model Numbers and Click Search. From this Page you can View Diagrams and Parts Lists for you Equipment Using the "View Sub Components" Section Near the Bottom Left. You can Also Enter "Owners Manual" in the Search Box and it will Direct you to the Page you Require.
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
SOURCE: Cut grass clippings does not get picked up by riding lawnmower
When using a bagger, you need correct blades on mower or Worn blades will cause the deck not to get the vacuum needed for the bagger to pickup.
SOURCE: I need a manual for a Craftsman 19.5 HP Turbo
My lawn tractor is leaking grease from rear left axle. How do I fix it ?
SOURCE: craftsman lt1000 stuck in neutral
The rear wheels are keyed to the axle shafts with a sqaure key, if the last owner forgot to replace one of the keys the axle will just turn in the centre of the wheel and not turn it, because the gearbox has a diff it means neither wheel will turn if either side has the square key missing, pull the wheels off and check the key is there.
