Question about Dishwashers
My Whirlpool ADP 5550 dishwasher has a red light constantly on it. It looks like a star and is positioned under the 'green' light that comes on on the main panel when the dishwasher is started. This has never happened before and I am unable to find the manual. Can you provide any ideas?
Managed to track down a copy of the manual from the Whirlpool website. The red light is an electronic indicator to show that there is no rinse aid.
Posted on Jul 22, 2009
Red salt light is on whirlpool ADP 2962
The sensor is defective replace it.
Apr 06, 2012 | Dishwashers
Whirpool ADP 5550. Will only rinse. Does not
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help
Thank you for using fixya.
Sep 17, 2011 | Whirlpool Dishwashers
Whirlpool adp 5550
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Aug 29, 2010 | Dishwashers
DWF 415 Ikea Whirlpool Dishwasher as constant
DWF 415 Ikea Whirlpool Dishwasher has constant green blinking light. Drain pump works ok (as it will pump out a jug of water if I tip it into it!) but no water comes in. Cycle stops about 30 seconds after thre is no more water to pump. Any ideas on how to fix?
Oct 09, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool Dishwasher ADP 4601 , Light flashing constantly.
There is a switch attached to the door latch that may need to be replaced. (the switch is inside the door).
Feb 08, 2009 | Kitchen and Much More Dishwashers
My dishwasher model adp 941 won't start - start led flashes
exactly the same problem today with an AD9520
Don't know the cause but from reading other posts re dishwasher problems I tried holding start but on for 5 - 10 seconds and it seemed to clear the symptoms at least. It ran for a short while and stopped but the flashing had stopped and I could start a wash cycle which is now running!
Dec 14, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Flashing light
I had this problem at home too, it turned out to be a kink in the water outlet pipe. I straightened out the kink in the pipe, put duct tale around it to strenghten it and the dishwasher has been working perfectly since.
Aug 08, 2008 | Whirlpool 24 in. ADP5962 Free-standing...
Whirlpool adp 44045 dishwasher not drainign and geen light constantly flashing - how do i drain system
First pull off hose on your garbage disposal and look for a clog.If no disposal then un do the drain hose under sink and look there.
Jun 03, 2008 | Whirlpool Washing Machines
Dishwashers Logo
1,657 people viewed this question
Top Dishwashers Experts
