Unless the phone and the printer support direct connection, you must get an assigned IP address thru the network router. This occurs when you connect to the wireless network. After that, your phone will need some sort of printer app, since it is not a true computer and you cannot load driver software for the printer in the same manner as for a PC.
SOURCE: i'm looking for a driver for hp laserjet m1005 mfp
Hi Oye!
Here is all avalible drivers for your HP M1005 MFP
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?lang=en&cc=us&prodNameId=1839459&taskId=135&prodTypeId=18972&prodSeriesId=1839458&submit.y=4&submit.x=9&lang=en&cc=us
Select the OS you running and download the drivers you need
Good luck
Nic
SOURCE: hp laserjet m1005 mfp printer, but it's cd was crack
You can downlaod the original drivers and software from the following link.
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=1839459&prodTypeId=18972&prodSeriesId=1839458&swLang=8&taskId=135&swEnvOID=228
SOURCE: HP Laserjet M1005 MFP scanner and printer shows
The job that you are trying to print is too complex for the printer. Add more memory. Or simplify the job.
SOURCE: driver for HP laserjet M1005 MFP printer for
Here is the Driver and Software download page for your HP Laser Jet M1005 at hp.com:
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?lang=en&cc=us&prodNameId=1839459&taskId=135&prodTypeId=18972&prodSeriesId=1839458&lang=en&cc=us
1. After you click on the link above, select the language for your printer driver from the drop down menu.
2. Select the version of Windows 7 you have. (either 32- bit or 64-bit)
3. Save the file to a new folder on your desktop. (It will be easy to locate after downloading it)
4. I would also download the Windows 7 Print Driver - Installation Instructions save it to the folder on your desktop and read it before you install the printer driver.
SOURCE: HP LaserJet M1005 scanner M1005 mfp how to share beware spam number 1*800*532*4187
Hi ,
Ok , 1st - lets go to your control panel , and click on printer and devices ,
see if your other printer is there , if not you need to add a printer , make sure your other printer is turned on , now is this a wireless printer or cable connection ?
if it is wireless answer yes when ask , if not say cable , once the printer is added you should be able to share your printer ........let me know if this works , if not I will advise futher ..............Good luck Roy
