Question about MicroBoards Saturn (SPS-1007-01) Burner
I have a 1998 Saturn SL2, the drives seat adjustment cable/wire broke, what is it called so I can replace it? I can not seem to find the name of the part.
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 231 Answers
Why not make your own with a spool of 5 dollar mechanics wire from the loacal parts store? or call the dealer and someoine there will know what the part name is by descring it as the drivers seat adjustment cable/wire as you did on here.
Posted on Jul 19, 2009
I have a 2000 Saturn sl2 and The right front motor mount was broke right down the middle and I replaced with oem part and it seemed to help quit a bit but still shifting hard what is wrong you think .
most engines have 3 or 4 engine mounts and if one had failed the others will be close behind. Misalignment of the engine to the shifting operation will lock levers or jam cables.
Dec 09, 2014 | 2000 Saturn SL2
I have a saturn sl2 and i replaced the knock sensor and the check engine light still coming on saying circuit low
At times it may not be the sensor that is the issue but the components which is surrounding the sensor which gives it its readings. It could be dirt or adjustments such as timing or dirty sensors or even wiring issues.
Jun 29, 2011 | 1998 Saturn SL
LP IN ELK GROVE,CA I HAVE A 1998 SATURN SL2 FOR ABOUT 1 IN HALF NOW WHEN DRIVING AND SIFTING INTO GEARS THERE IS A VERY LOUD NOISE COMING FROM SEEMS THE RIGHT FRONT SIDE OF THE CAR, ABOUT A MONTH AGO I...
Hi :) I have a 1997 SW1 wagon same front end have replaced parts over the years since new and I'am still driving it that noise is coming from the CV axle to replace it you jack up the car and set on jack stands safely remove the bolt holding lower ball joint in place and seperate the two parts, Undo the large nut on the outside of the wheel hub and push the stud out of the bearing the take a large srewdriver or pry bar and pry the other end of the axle out of the center shaft support housing that goes to the transmission and reverse process to repace making sure the inner CV shaft is all the way seated into the center shaft support.
Mar 18, 2011 | 1998 Saturn SL
1998 saturn SL2 automatic-the transmission will "jump into neutral" when I hit a bump, also the speedometer will work on and off when driving according to the bumps in the road....
check the connections under the vehicle at the transmission may be loose and needs adjustment or tightening also check the wiring and cables in area may be rubbing against [or loose] shifter linkage
Mar 26, 2010 | 1998 Saturn SL
My automatic seat belts are stuck around the halfway mark, how would I get them into the driving position? the Car is a 1991 saturn SL2 Sedan.
Probably best to replace, when the mechanism gets unreliable do not risk fixing try a wreckers yard, make sure the replacements pull out cleanly but lock when "jerked" hard.
Dec 15, 2009 | 1991 Saturn SL2
I have a 1998 Saturn SL2 that has a strange transmission issue
Could be the stability control system that Saturn's have. Same thing on my 2008 Saturn..stumped me for a bit too.
Oct 13, 2009 | 1998 Saturn SL
Gas Gauge and Odometer Broken
yeah replace the odomitor cable that should hook into the side of the trans by the fire wall. also check the fuel tank float and fuel pump
Jun 08, 2009 | 1993 Saturn SL2
93 sl2 shifts early and hard
Adjust the TV cable between injector and transmission. Loose the cable at top. Apply full pressure to accelerator. Adjust. Then allow the pedal to return. Do not over pull on the cable. Can damage control plate inside the tranny.
Feb 03, 2009 | 1993 Saturn SL2
MicroBoards Saturn (SPS-1007-01) Burner Logo
151 people viewed this question
Top MicroBoards Computers & Internet Experts
 Grubhead
Grubhead
 Russ Hill
Russ Hill
Are you a MicroBoards Computer and Internet Expert? Answer questions, earn points and help others
