IP4700 series has 2-way paper feeding. Please check you paper feeding from bottom cassette or rear auto feed!
Before perform the printing job, you may notice on your printer right side can select paper feed from rear or bottom.
Enjoy printing.
please the dumping roll and paper feeding pad is very celing and
who do use paper ? this paper is very glose papre ? if yes,
when one by one give up and second time
the paper is regulary use the friently paper and out of air in paper
and put the paper trey and use regulary ok.
Regular paper feeds?
Then use a single sheet of photo paper at a time with nothing else in the tray
Use a ord processor to see if there is t software glitch
It sounds like the printers rollers are slipping on the heavier paper, possibly because this paper is smoother then your regular paper.
Try cleaning the exit rollers on the printer with something like methylated spirits - if the rollers have gone shiny, then you can
usually revive them by using some emery paper to roughen them up.
''grabber'' roller out of work sometimes, you may try
1) there is a input paper sensor around roller, the roller out of runing if the sensor is not senitive enough or sensor switch dirty,
clean the sensor as you can find it,
2) Lighter-weight paper feeds and prints fine, which means this paper input sensor works ok, but you need to make sure they are same paper input sensor,.
3) the paper surface bright and the roller worn could be cause paper feed fail, you need clean the roller anyway. still not fixed, you need to adjust the roller pressure by increase the spring force.`
seems that y´all experiencing various paper feeding issues check first for recommended paper type
that printer should handle 4x6´s up to 8.5x11´s and if it can´t feed a particular size - hardware issue & check your warranty status with the manufacturer
