Question about General Electric 20 Amp, 1 Pole Thick Type THQL Ground Fault Interrupter Ge
I want too lear too instal current at home,ect
  • 5,660 Answers
Becoming an Apprentice Electrician, and/or moving on to a Journeyman, then Master Electrician, involves either going to a Vocational Technical, (VoTech), school, or learning on the job.
As you work on the job, you will be under the license of an electrician. After you learn your craft to an extent, you can take a test for becoming an Apprentice Electrician. Then after two years on the job you ca test out for your Journeymans Electrician license. You will be tested in the Residential, and Commercial areas.
See if there is a company that is willing to hire someone, who wants to learn the Electricians craft in your area.
Tips from me:
1.When working on a circuit, NEVER assume the power is off. Even when you are sure it is.
Use your test equipment, and make a quick check before you put your hands in there!
Has kept me from getting shocked for many years now.
2.After making a wire connection to the breaker, before you insert the breaker in the Service Panel, wiggle the wire a little. Then try to tighten down the circuit breaker screw, a little more. You're dealing with Alternating Current, (AC), and AC vibrates! It can eventually vibrate screws loose! (50 to 60 Hertz. Hertz means Cycles per Second)
Posted on Jul 18, 2009
My daughter just got an apple ipod touch 4th generation 8gb and we are trying to set a photo to her ipod as wallpaper and it shows that it saves but when she goes to the home page it is not there in the...
Hi idiehl271...
To use any picture for your background you must have that picture installed in the Ipod.
To install a different picture as a background picture do the following:
1...Turn on Ipod
2...Touch "Settings"
3...Touch "Wallpaper"
4...Touch the arrow in the middle of the window, next to the current wallpaper
5...Select pictures from "Wallpaper",Photo Library, ect.
Please take time to rate me
Aug 23, 2011 | Apple iPod Touch 8GB 32GB 64GB 3rd...
I got bought a laptop for christmas, and Microsoft Office Home and Student 2007 was pre-installed. I've been trying to get onto Microsoft Word but it keeps asking for a Product Key. How do I get one?
When you purchased your laptop Microsoft office was installed for trial purpose, to obtain a serial key you would need to purchase the software from a local office stoce, eg: Office Max, Office Depot, ect. Or you could purchase it online at: http://office.microsoft.com/en-us/buy/buy-office-2010-FX101843016.aspx?WT%2Emc%5Fid=ODC%5FENUS%5FOATProdHome%5FMonBuy.
Purchase the newer 2010 version, as the 2007 version is outdated, but you will need to uninstall your current version before installing
Mar 04, 2011 | Microsoft Office Home and Student 2007...
Trouble locating cooling sensor on 2003 gmc envoy
4.2L Engine To Remove:
  1. Disconnect the negative battery cable from the battery.
  2. Drain the coolant from the engine.
  3. Disconnect the engine coolant temperature (ECT) sensor connector. Engine coolant temperature sensor removal and installation gm-04-42-1509.gif
  4. Remove the engine coolant temperature (ECT) sensor from the engine.
To Install:
  1. Apply thread sealer P/N 12346004 or equivalent to the engine coolant temperature (ECT) sensor threads.
  2. Install the engine coolant temperature (ECT) sensor into the engine. Torque the sensor to 12 ft-lb (16 Nm).
  3. Connect the engine coolant temperature (ECT) sensor connector.
  4. Refill the engine with coolant.
  5. Connect the negative battery cable to the battery.
5.3L & 6.0L Engines To Remove:
  1. Drain the coolant from the engine.
  2. Disconnect the engine coolant temperature (ECT) sensor connector. Engine coolant temperature sensor removal and installation removeect.gif
  3. Remove the engine coolant temperature (ECT) sensor from the left cylinder head.
To Install:
  2. Install the engine coolant temperature (ECT) sensor into the left cylinder head. Torque the sensor to 15 ft-lb (20 Nm).
Jul 08, 2010 | 2003 GMC Envoy
Dear Sir, I am Service Enng For Canon Copier i do work only R/C Machines and iR 3300 Instal More Machines But I Face Only Error E-602 0003 I do 1 9 Proses Then Problem is ok But sir how to Format and...
helo there
there are several ways to format the harddrive but the easiest way is to use the operating system cd i.e xp home win me ect ect when you install it and the installation begins it will ask you about installing or repairing the current operating system select new installation than continue after a few steps it will it will show you your current partition and ask you about partitrioning the drive just click yes and continue from there dont be suprised if it asked you to install a nother valid operating system cd like win 98 or me so have one ready ok? itis needed to validate the authanticity of the cd than after this if will ask you to put the other cd in and it will continue to format the drive and install the operatring system ok this is almost exactly how this procedure occurs some things are self explanitory. ok i really hope that this is really helpful please let me know how this is going i can help more if needed ok and please dont forget to rate my solution
best regards michael
(USN) RETIRED
Aug 05, 2009 | Computers & Internet
I have lost my install cd for hp psc 1510
Hello there:
if the manufactures website is no help please go to www.radarsync.com and use this totally free driver update utility this helps update all of your drivers and will get the drivers for the devices that you are trying to install if you have no installation cd. I.E printers / mice / keyboards / web cams ect.ect ok?
Please dont forget to rate this service .
best regards
mike
(usn retired)
Aug 04, 2009 | HP Office Equipment & Supplies
Saturn SC wont turn over
when it comes to DC electricity like on automobiles. DC current wants a really good connection. check and make sure the wires at the alternator you just installed are tight. check the tightness of the battery cable connections at the battery. check the tightness of the main cable that goes straight to the starter. small things like the dome lights ect.... will still work many times when the connection is not so good, but big current items like the starter need a good hard connection to work. sometimes when the connection is sub par, the starter will just make a clicking noise but wont turn over the engine.
Jun 11, 2009 | 1992 Saturn SC
Home Theartes
Trying to program Toshiba remote CT90157 to work with my Koss KS-5116-2 DVD player... any suggestions ???????
Jan 12, 2008 | Televison & Video
Ive got a 40gb ps3 and a bt home hub wireless router how do i connect ps3 to computer ps ps3 is upstairs and pc downstairs
look on the back of your home hub. there should be a Wireless Key in a Grey box. (BT Home Hub wireless settings)
note the wireless key.
go to your ps3. and turn it on log on ect. go to settings and down to network settings (right at bottom).
(Im not sure of the next section because im currently on a network but it should be an option to find network).
anyway you search for networks. should find your home hub.
keep going right untill you have to enter any settings. and write your WEP Key (Not WKA). (wireless key from back of router).
Jan 10, 2008 | Sony Playstation 3 (PS3) Console
Phone locked
Hi Try this *2767*688# = Unlocking Code
Aug 28, 2007 | Samsung SYNC SGH-A707 Cellular Phone
General Electric 20 Amp, 1 Pole Thick Type THQL Ground Fault Interrupter Ge Logo
355 people viewed this question
Top General Electric Electrical Supplies Experts
Rob Bridges
Level 1 Expert
ken skalski
David Harrelson
David Harrelson
Are you a General Electric Electrical Supply Expert? Answer questions, earn points and help others
