Question about GE DBVH512EFWW Dryer
Code E61 I have just purchased a new dryer and I plugged it in and I have this code on the screen
I have the same problem, and it might be due to the fact that your dryer operates off a voltage that your house is not providing. Your dryer might need 220 volts and is only receiving 110 volts. That may be why it powers up but nothing works but the light when you open the dryer door. It needs more power to run the rest. Look into changing the voltage on your receptacle in your house to 220 volts to properly operate your dryer. Good luck!
Posted on Jul 03, 2009
Replaced heating element now I get error E61, I ohmed out the thermostat on top of heating element seem to be ok
Hello Louie, I appreciate your inquiry!
Based off the information you have provided your Frigidaire dryer is displaying an error code of "E61" after you have replaced the element. An "E61" error code means that there could be an issue with your heater relay or main control board. You may need to seek additional assistance from a professional technician for proper diagnosis and repair. This will help you avoid any unnecessary part purchases. I hope this information is helpful to you. -Matt
Mar 28, 2016 | Frigidaire FASE7073LW Affinity 7.0 cu ft...
Replaced circuit board and i have heat but still shows e61 code
Hello friend, thanks for your post!
Based off what you have described your Frigidaire dryer is displaying an error code of E61. I understand that you have replaced the circuit board and you are still receiving the error code. An E61 means that your heater relay as had a failure which could be a potential problem with your heater relay or a wiring harness. You may need to seek professional assistance with proper troubleshooting this will help you to avoid any further unnecessary part purchases. If you need help locating a local technician you can visit your manufacturer's website for a list of available technicians. -Matt
Aug 05, 2015 | Frigidaire Dryers
Error code e61
Identification
  • GE dryers use three-character codes that display on LCD screens. Every code starts with "E" and is followed by a two-digit number.
Power Failure
  • When your home loses power, the "E01" error flashes on the screen. Reset the dryer memory by unplugging the device, waiting 30 seconds and plugging it back in. The error code will disappear.
Thermistor Errors
  • Errors "E02," "E03," "E04" and "E05" are thermistor errors. The thermistor, when operating properly, reads the temperature of the dryer. Errors E02 through E05 indicate the thermistor must be replaced.
Effects
  • When there is an error with the door switch and sensor, the "E60" error code will appear. An unbalanced door will produce the E60 code. Try to close the door gently and listen for the click. If the error remains, the door switch may need to be replaced.
Control Board Errors The control board sends signals from the controls to the dryer. When this fails, errors "E61," "E80" and "E81" appear. Contact GE service or install a new control board for the dryer
Jan 15, 2013 | Electrolux Dryers
Replaced control board on dryer still getting e61 code
The problem is not with the dryer as confirmed by the other identical dryer brought by the dealer. The problem is in the wiring of the receptacle where the dryer is being plugged in as characterized by error code E61 which means the control board is receiving a high voltage. The dryer operates both on 110VAC for the controls including the motor and 220VAC dedicated for the heating circuit. The receptacle must be configured according to the specifications of the dryer. Refer to the diagrams below and configure the receptacle according the plug that came with the dryer. Voltage across L1 and L2 is 220VAC, L1 and Neutral is 110VAC, L2 and Neutral is 110VAC.
Nov 17, 2012 | Frigidaire Electric Dryer
What does Frigidaire affinity dryer code E61 mean
E61 is a line voltage problem, most of the time it means you have the neutral and the L2 wire either reversed or in the wrong position. Verify that the voltage is correct at the plug then at the machine and that you have 240 volts at the terminal block on the back of your dryer.
Oct 18, 2012 | Frigidaire Affinity ATF7000ES Front Load...
Brand new Frigidaire Electric Dryer gives Error E61. Store brought out another identical dryer with same result. Help please!
Note: You may need the service of a certified electrician for this task.
Jul 13, 2011 | Frigidaire Electric Dryer
Error E61 appears on digital screen. dryer does
I was told it was main computer board. Ours got the code when we had power surge.. Not sure how yours happen
Nov 17, 2009 | GE DCVH515GF Gas Dryer
Dryers Logo
560 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
