I need to get to the motor because I think that the motor brushes might need replacing after three years of operation
SOURCE: my chipper is throwing long chunks of unchiped
Either your blades are dull or the gap between the intake tray by the blades is too far or is rounded off. Many chippers have a plate on the intake by the blades that can be flipped around when it rounds off. Also some have a edge on the other side of the blade so it can be reversed and give you a fresh edge. Be sure to unplug the sparkplugs and remove the key when going into your chipper to ensure no one can start it when your in it. There is usually a lock bar to keep the blades from moving.
SOURCE: i have a brush master chipper was working but has
look at the magnita the round **** under the coil you make just have to sand it with a fine sand paper and maybe the under side of the coil
SOURCE: looking for manual for troy-Bilt super tomahawk wood chipper
here is the link to the manuals for the 47266 http://www.brentchalmers.com/
enjoy :)
SOURCE: need a manual for a 4-cylinder Asplundh Wood Chipper
I don't really have a solution I do have the same problem no manual on engine. But I can offer a little more information on it. I believe the engines are 2.3 liter ford. If your engine still has points it doesn't mean that it is an old engine mine is a 2000 which is fairly new. They are Ford industrial engines not quite the same as what is in cars. The problem is no one knows anything about them.
SOURCE: What year is my wood
The B & S Code is the date of Mfg. This engine was built in 1994 (first two digits rep. the year), Sept.( the next two digits rep. the month) and the second day of that month. Your engine was built on Sept.2,1994. Your chipper may be one year newer as the engine had to be installed after the date of mfg. Your welcome
From North Carolina
