Question about Whirlpool Duet GHW9150P Front Load Washer
Our whirlpool is leaking from the bottom during
I have the same problem with my 3 yrs old washing machine. It happened yesterday. Someone please help me.
Our door gasket was leaking and running out the bottom... not sure how the gasket got holes in it but it had five or six holes and it is not that old. the gasked was over a hundred dollars and the water bill ran over a hundred dollars before I found the leak
Posted on Jul 21, 2009
Whirlpool duet front lading washer, GHW9150PW4
Could be drum bearings gone Quite a big job hence costly with around 3 hours labour plus parts, some models need half drum as the bearings are loaded in here,leak could be door boot seal at 7 yrs old not sure if worthwhile as its about the end of its working life.Good luck
Apr 06, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Hello. I have a two years old Whirlpool washing
Unless you look underneath it will not be easy to confirm but please check the following.:
1. check if the motor has failed, the housing has come off.
2. checckif the belts have failed and brought it off the pulley.
3. check if the main spindle , pulley has come off from the main shaft.
4.check if theere is any foreign material struck in between the tub and outer cover. Checking with manually must confirm.
5. check aftert he above had been looked into to see if any other issues are visible or audible.
Hope these tips helps.
Aug 24, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
My GE Washing machine appears to be leaking from the bottom
It sounds to me , you need the seal and bearing kit.. It is over 300.00 dollar repair, if it is an old washer I would say go get a new one
Jan 13, 2010 | GE Profile Performance WPSF4170WAA
Whirlpool Duet Sport washing machine with a leaking door.
You need to check if the door is not loose on the washer, make sure you tighten all the screws on the door
Jan 07, 2010 | Whirlpool Duet Sport HT WFW8400TE Washer
Washer leaks during fill up
check the bottom of the inlet hose where it enters the machine. It is most like;y a split hose or a corroded valve.
Sep 25, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Leaking washer drain pump
Yes, the drain pump is a common leak area.
2 clips, 2 hoses and it pulls off.
If it has leaked for a long time you will have to get aggressive to get it off.
Feb 21, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Washer leaking water on floor
Need to check drain pump and its hose connections. If its not from the drum seal then that's usually where the leaks occur.
Mar 30, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
266 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
