Question about Samsung HLN5065W 50" Rear Projection HDTV-Ready Television
Green tinted people
We have a Samsung DLP television, just upgraded to Comcast HD cable. When we are going through the tv the images appear to have the correct color tint, but once we switch to the HD component cable to display the images (changing the input) the color is very off. Everyone has a green tint. When we adjust the Green/Red tint towards the red side the people skin tones even out, however, then everything that should be green ends up brown/yellow. For example, the grass looks like it's dead because it's brown and not green.
The images also appear to be washed out, where the images are typically pretty bright on the tv, when viewing them from the HD cables they appear "muted." Any suggestions?
We called comcast already and they were not helpful- reset our connection and said to change the color settings on the tv, but trying all kinds of combinations of color options we can't seem to figure this out.
Any help is greatly appreciated! :)
  • 668 Answers
The only time I have had issues like this was because of the Component Cables not being in the right position (the Red and Blue connections switched), or a bad Component Cable where the Blue Connection is not receiving a signal. Swap out the cable to be sure and double check that it is properly installed. Green to Green, Red to Red , Blue to Blue.
Hope this helps,
skyassoc
Posted on Jul 18, 2009
    Problem Solver:
  • 16 Answers
Does the box and tv have HDMI? If so try connecting the tv to the HD settop box with that to see if the box has a component output problem. While working at Cox Cable we used (and still do) Scientific Atlanta boxes and I have seen a few that had bad red outputs on the component cables. If you have another device that outputs HD like Bluray on component cables try that to the tv to show the tv is good or not. Ask the cable company to try swapping the box to see if this is a possible bad output to your TV. You can check your cables by bringing them to a home where you can try them or to a store where they can be used to see if all colors work.
If the cables work in another setup and changing the box does not do it then your TV has an internal problem. How many component inputs does your TV have and did you switch? If the cable-box has HDMI and the colors are correct with that and your cables work when checked, it is internal to the TV or the connectors at the back.
Posted on Sep 13, 2009
2 Suggested Answers
  • 1779 Answers
SOURCE: Green tint on Siny 50" DLP
Most likely a defective Light Engine Assembly. They normally cost about $800.00, or in that area.
Posted on Aug 14, 2009
Samsung tv has no bule
be sure all your input cables are good & firmly plugged in at both the source & the TV. If these things are O.K. then may be the digital PCB
Apr 02, 2015 | Samsung Televison & Video
67" Samsung DLP. Last night it started flicker to a green tint. Back to normal then green tint. Now it's completely a green tint. Still has picture and voice but green tint and not bright like before.
In those sets there is what they call color wheel and it could be on its way out it sounds like its stuck.or not working prop in any case you need to bring it in for service place
Mar 26, 2013 | Televison & Video
My screen has a green tint that will not adjust out ?????
The light engine on this TV uses a 3 lens DLP system. You probably have a section of the DLP engine that is dirty or going bad. I have one that is overly yellow the way yours is green. I tried to clean it out, that helped but did not cure the problem. The actual DLP lenses are nearly impossible to get to. That is a good thing because they are very fragile, too! It is watchable but not perfect. Life is hard... with the age of these TV's watch classified ads or Craigslist. Sometimes you can find them for a very low price or even free! They are very easy to work on and really a pretty good tv with working correctly.
May 03, 2012 | JVC HD-61G787 61" Television
I have a SAMSUM HL-T6187SA DLP LED 1080P. The problems I see are a Green Tint and the RED(s) display as Blue(ish). John
It sound likes the problem of your unit is the light engine. This is very common problem on Samsung DLP TV's and tons of complaint regarding on the picture quality. If you search "Samsung DLP law suit" you will find various comment regarding on the issue.
This part is an expensive one and I would advice you to call Samsung service department (1-800-726-7864) to let it diagnose by their Technician and see if they would cover the parts.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Aug 25, 2011 | Samsung HL-T6187S Television
I have a Samsung HL-R5067W DLP HDTV. I have HD cable from Comcast. My TV plays the HD signal flawlessly. The non HD channels have columns and rows of colors on the screen. The picture can sort of be made...
this could be 1 of 2 things--either the light engine or the digital board--i'm betting on the board because hd cable is good--light eng/cost prohibitve--board maybe !!
Jul 22, 2009 | Samsung DLP HL-P5663W 56" TV
Green Plaid Screen
Are you able to access the on-screen menus (like brightness/contrast etc)?
If those menus are appearing over the green screen, then it might be a cable or image source problem. I've often seen this green screen when the HDMI encryption between my cable box and my TV gets messed up. Only solution has been to power cycle the cable box.
If you can use something other than an HDMI cable to connect your TV to your picture source, I suggest trying that and seeing if you can get SD channels again. If you do get them back, it was a cable issue. If you still can't get them, contact your cable/satellite provider, see if there's something up with their signal.
May 30, 2009 | Samsung HLP5067W Television
Green tint to picture when dvi cable is connected
The tv will show correctly in 720p mode. Cable box and PS3 must be set to display in 720p or the green tint will remain. For the PS3 I return it to 1080p when I am about to play a game, blu-rays and dvd's can only play in 720p.
Dec 15, 2008 | Akai PT46DL10 46" HDTV-Ready Television
Green tint to everything on my Samsung HDTV Digital 1080i television
I have the same problem here on this Samsung 40" LCD. its a 2007 model. everything was fine until recently. I had to reset my digital cable box. now the picture has the green tint. its ruined what was a nice tv, and it won't go away.
Mar 11, 2008 | JVC HD-56G886 56" Rear Projection HDTV
Plasma with green tint
Could be a main board.Tuner could be bad.
Dec 24, 2007 | Samsung LE32R41BD 32 in. HD-Ready LCD...
Samsung HLN5065W 50" Rear Projection HDTV-Ready Television Logo
423 people viewed this question
Jerry Greenberg
Jerry Greenberg
