Question about Zenith Z19A11S TV
Programming this tv was originally hooked up to a satelite and worked. we have directv. the antenna cable is hooked up but when i try to program the channels no channels are found. After it is done the search it says check cable/antenna connection and try again. is there a special way to program for directv. we go off of channel 4 but i am only getting fuzz on the tv.
  • 50 Answers
Re: programming
Can you enter channel 4 manually and get picture
Posted on Nov 20, 2007
0 characters
3 Points
Magnavox tv has cable channels 2-13 only. Lost original remote. Using a universal remote. Tried to auto program. It started scanning but when channel 14 came around, just fuzzy snowy picture all through...
The set needs to be switched from antenna to cable in the setup menu. It is capable of either antenna reception or cable reception. Ch 2-14 are the same frequency for antenna and cable but above 14 they are different. That is why the picture is stoping at 14. After you switch it to cable auto program again. Thanks for using fixya.
Nov 12, 2009 | Standard (CRT) Televisions
Static jumping picture
sounds like bad connection or bad tuner in the tv - have you tried playing a DVD or VCR tape ( if available ) - more info would be needed to help you further -such as - are you on cable, cable box, satelite or antenna and do you hook up to your TV using the a/v or RF(cable) input.
Oct 18, 2009 | Sony FD Trinitron WEGA KV-20FS120 20" TV
Antena inputs are not receiving the cable signals. Its a panasonic projection tv
Try running the antenna or cable through a vcr and then hook the VCR to one of the video input of the TV (use yellow red and white out of VCR to TV) Try changing channels with the VCR.
I don't know if your on cable satelite or antenna.
Oct 03, 2009 | Panasonic Standard (CRT) Televisions
Cant get my cable hooked up
check your unit if it is cable tv compatible.then, hook your cable to antenna in.then do the manual tunig/search for channel.if not,you'll need to buy a cable converter ,much better if it has audio/video out.
Mar 29, 2009 | Mitsubishi CS-40503 TV
I have a jvc tv model av27530. Disconnected cable box b/c going
You probably have to find your original remote to the set and go through setup in your menu. On most sets, there will be a menu item which will allow you to switch from Cable mode to Air mode. If you have no Cable connected, then you must set tuner in Air mode.
If you are using an external device to run on channel three, then try this:
Make sure device (rather it's a vcr or game console), is hooked up to your Antenna Input connector. Also, some of these devices will have a small hidden switch on back that says 3 and 4. Move the switch to 3 position. Turn on device. Go into TV menu and do a Channel scan. This should auto program any device hooked up to the TV antenna input jack to channel three.
Keep in mind that you may not receive anything by Feburary of this year without an HD converter box to tune in channels with and outdoor antenna.
Jan 09, 2009 | JVC AV-27530 27" TV
JVC LT 43E488 LCD HD TV cable box doesn't get local channels
boomergal, do you have satelite cable or directv or dish?
Dec 12, 2008 | JVC AV-36D303 36" TV
Want to use DTV converter with my Toshiba 32AF42
If you're not on cable or satellite, you will need an antenna to get off-the-air reception. This TV does not have a DTV tuner, so you will also need the converter box. Depending on how far you are from the broadcasters' transmitters, you might be able to get away with an indoor antenna. Or you might find that you get few channels with the inside antenna and then you'll need something outdoors. There are a number of styles to choose from.
The antenna hooks to the converter box, and the converter box then goes to the TV. It can be hooked to the TV's "ANTENNA" connector. This should be covered in the set's manual where it shows you how to connect a regular antenna. With the box, your TV will always stay on channel 3 or 4 (depends on how you set up the box) and you'll change channels on the converter.
You can also connect the converter to the TV with audio and video cables like you would a DVD player. Most of the "coupon-eligible" converter boxes include direct video and audio output jacks. This gives you better picture and sound quality than by hooking it to the TV's antenna input.
Hooking up a converter box is like going back in time to when cable TV was new and you had to get a converter box from your cable company. Same way of hooking it up. Hope this helps!
Dec 07, 2008 | Toshiba 32AF42 32" TV
Program satelite or cable
you are not specific as to programming cable or satellite .if you have cable tv with a cable box there is no need to program tv channels.the tv should be left on channel 3.check the back of the cable box & tv it may also be connected thru rca/s-video or componant cables meaning the tv should be on a line in/source ,or video input. for a tv without a cable box
you can do the auto or manual programming. no need to be on channel 3. if you have satelllite tv you need the box to hook up to your cannot bypass this box unlike cable tv.also check the back of the box for the other possible connections
good luck
Jan 28, 2008 | JVC AV-27D202 27" TV
Digital reception
Check the menu screen to see if you have an option to program digital channels . If not the answer is no . If you are on cable or satelite then you need not worry as the only people who will be affected by the digital change over will be if your on outdoor antenna or rabbitt ears only with your tv. Your cable and satelite providers will not change you over on feb 19th 2009 . Everythung will be the same . Good luck
Dec 28, 2007 | Sanyo DS31520 31" TV
it sounds me that it is due to cable wire connection where it is connected is probably might be loose or if you have cable box there is some loose connection.
Oct 05, 2007 | RCA F31672ET TV
Standard (CRT) Televisions Logo
114 people viewed this question
Top Zenith Standard (CRT) Televisions Experts
matt martin
matt martin
Anastasio Benjou
Are you a Zenith Standard (CRT) Television Expert? Answer questions, earn points and help others
