Question about Panasonic PT-47WX53 47" Rear Projection HDTV
Red shift to left with curve at bottom
Hi all, I have a Panasonic 47WX53 47" (4 years old) that all of the sudden developed a shift in the Red projection to the left and a slight curve to the left at the bottom. Tried to use the convergence menu to correct, but doesn't shift far enough to correct. I called the local service shop and they gave an estimate of between $300 and $500 to fix. I have messed with electronics for years and for that kind of $$, I will try to fix it myself. I've read a couple of other posts with a simular problem that have suggested to replace the "Convergence Box". I've looked inside the unit, but don't see a "Box". I do, however, see the two convergence IC chips. Is this what they are refering too? I looked the part# up on MCM Electronics and it costs about $20. Might be an adventure to change if thats the problem. If anyone has a solution to this problem, or has had the same problem, please post a reply. I have a blue shadow and too much yellow on the right side of the screen. I've tried to use the  manual convergence adjustments in the setup screen  but the blue won't line up properly  on #'s 2, 3,  6, 8, and  9. The blue cross won't go  far enough to the right, especially on #'s  3 , 6, and 9.  I've taken the back panel  off the TV but am not sure where the  convergence  IC's are.  Does anyone have some kind of a step by step instructions on how to replace the IC's?  I've never done this type of work but am pretty handy, besides I can't  really afford  to pay a repair  service.
  • 1,694 Answers
Par 2 = " I do see the convergence chips..."
Par 3 = " I'm not sure where the IC's are...."
Please verify STK part # of IC's on large heatsinks.....
And then I'll give you step-by-step instructions......T.
Posted on Nov 19, 2007
  • Vista Electronics Nov 25, 2007
    Where are you on this repair?..........................T.
Hi I have a panasonic pt-47wxc43g and i seem to have a several red curved lines from top to bottom can you help to solve the problem.
The problem could pincussion.Try to adjust through remote.If they are not working.There is problem in the board.The pincussion IC output is deffective.Need to replace the IC.
Jul 01, 2011 | Panasonic Televison & Video
I have an older (about 10 years old) Toshiba 35
You some how have turned on the closed caption function on your tv, go to the tv's menu under closed caption an dturn it off.
Mar 22, 2010 | Televison & Video
Panasonic HDTV from 2001. 51
I had the same problem and fixed it myself with a kit from Works great now.
Jan 09, 2010 | Panasonic PT-51HX41 51" Rear Projection...
I have a projection tv that has a yellow bending line
It sounds like you need the convergence amplifiers replaced. Are you an expert solderer? If not, I would have a qualified technician repair this. Most places here in Alabama will fix it between $200-$300.
Jan 05, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Uh oh... the colors are curved and wacky
replace the amplifier IC chips for the convergence.  part # stk392-???  could be from 040 to 120..  90% chance that'll fix it.
Oct 08, 2007 | Panasonic PT-47WX49 47" Rear Projection...
3 curved lines top & bottom/blurred picture
This indicates a convergence problem..convergence power supply probally.. however ive seen 2 other cuicits cause this ..
Sep 24, 2007 | RCA HD52W59 HDTV Projection Television
Yes you do need to change the convergence IC's. But you really should buy the replacement IC's that the manufacturers recomend as these IC's at MCM are cheap replacements and sometimes they simply do not hold up to the factory specs. Go to, enter your model number and you should be able to find the proper IC's there. If you notice the price is a bit higher, thats because they are the right parts!. Next go to MCM electronics and get a tube of heat sink compound and apply a generous layer on the back of the new IC's before you install the new IC's. Also you should check around for overheated or cooked resistors around the area of the convergence IC's. Now when all is sais and done, you will be better off to go ahead and get the service manual so you can do some convergence alighnments. The manual is good to have as it tells you how to get into the service menu and what to adjust and for what. One word of warning though, in the service menu, DO NOT make any adjustments you do not know anything about AND before making any adjustments in the service menu, write down the values so in case something messes up you have a place to go back to. Good Luck.
Mar 19, 2007 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic PT-47WX53 47" Rear Projection HDTV Logo
59 people viewed this question
Top Panasonic Televison & Video Experts
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
