Question about NetGear WGR614 Router
NetGear WGR614 -Installation Problem on Windows Vista PC
I cannot get the Installation Wizard to get past the "Modem/Network Recognition Stage.
I have done any and all of the following:
A]] Disabled each of the 3 Internet Connections that I have on the PC -on-board NIC, installed NIC (Installation Program demands it), and Wireless NIC.
B]] Hooked the PC into the Router (and Router into the Cable Modem), then, afterwards, hooked the PC directly into the Cable Modem -and over a period of several minutes, also exchanged each wired NIC and separately plugged them in. Also tried hooking up the PC to the Router only, not connected to the C-Modem.
C]] Disabled the on-board NIC in BIOS and used the PCI-NIC; afterward physically uninstalled the PCI-NIC and used the onboard NIC.
D]] Made sure that each of the 3 NICs has its own IP address.
E]] Set each of the 3 NICs to auto-get their IPs.
F]] Made sure that the Cable Modem was indeed functioning properly and could access the Internet.
In every case, the CD's Installation Wizard repeatedly reports that it cannot find the Modem (and it always calls the device a 'modem' whether it's the Modem or just the Router), and halts the installation.
PLEASE tell me that I'm missing something obvious and easy -I'd really prefer a "duh!!" INSTEAD OF "this device just doesn't install on this OS" or something similarly distressing.
THANK YOU IN ADVANCE FOR YOUR HELP!!
  • 1,272 Answers
Please make sure that you have the NIC enabled and on the computer and set to automatic settings for IP address. Now follow the steps below to reset and reconfigure the router:
Reset:
At the back of the router you will find a small tiny hole (which has a small button inside it). Press the button with the help of a paper clip. and hold it down for 30 seconds. After 30 seconds, please release the button and power off the device for 5 seconds.
CONNECTIONS:
1. Connect a Ethernet cable from the modem to the WAN port of the router(isolated port).
2. Connect the computer to the router using any one of the 4 available ports. Please make sure that THERE IS NO DIRECT CONNECTION BETWEEN THE MODEM AND THE COMPUTERS (either using Ethernet cable or USB cable).
3. Power off the modem and the router after making the connections.
4. Power on the modem and wait for the lights, then power on the router.
RECONFIGURE:
1. Open the browser(Internet Explorer or Mozilla Firefox).
2. Access the router, usually with http://192.168.1.1 or http://www.routerlogin.com.
3. Login to the router with the Username as "admin" and Password as "password" (please note that the username and password is case sensitive).
4. Click on 'Basic settings' from the left menu and select 'Use Computers MAC Address' from 'router MAC Address' section.
5. Click Apply.
6. Once it updates the settings then power off the modem and the router. Power on the modem and wait for the lights, then power on the router.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
Posted on Jul 18, 2009
Thnx.anand....i browsed many sites but only u gave the solution....
I WAS GETTING AMBER LIGHT FOR IP ADDRESS IN THE NETGEAR ROUTER....
ONLY TO ADD ONE THING FOR MORE UNDERSTANDING.....
IN THE BASIC SETTINGS PAGE ...IN THE FDIRSYT COLUMN
FOR LOG A SELECT "NO"...
THEN U WUD GET MAC ADDRESS COLUMN AT THE BOTTOM WHICH AS ANAND SAYS SELECT USE COMPUTER MAC ADDRESS...
AND THE IP ADDRESS AMBER LIGHT TURNS GREEN....AND YIPIEEEE THERE YOU GO...
Posted on Aug 19, 2009
How to instal
You'll wanna check out: ftp://downloads.netgear.com/files/WNR1000_SM_WW_23Jan09.pdf
Look for "installation"..
To help you set up your router and get on the Internet quickly, the Resource CD contains a Smart Wizard™ Installation Assistant. The Installation Assistant walks you through the steps required to connect your router, modem, and PC(s); configure your wireless settings; and enable wireless security for your network. When you have finished, you will be Internet ready!
You can set up your wireless router using one of two methods:
• Smart Wizard Setup: The Smart Wizard Installation Assistant setup is available on your Resource CD. See "Installing Your Router Using the Smart Wizard" on page 9 to use the Smart Wizard Installation Assistant.
- This is the easiest option. The wizard guides you through the setup process. It automates many of the steps and verifies that the steps have been successfully completed.
- Smart Wizard requires a PC running Microsoft Windows.
• Manual Setup: If you cannot or prefer not to use the Smart Wizard Installation Assistant, see "Manually Installing Your Router" on page 13. For example, if you are connecting to a Mac, are using a Linux operating system, or are technically knowledgeable, select this option. If you choose to use this option and install your router manually, for best results, install and set up your router in this order:
Failure to follow these guidelines can result in significant performance degradation or an inability to wirelessly connect to the Internet.
NETGEAR does not recommend or support adding a NETGEAR router behind another router, or replacing a gateway with a a NETGEAR router.
If you have a Macintosh or Linux system, you must use the manual installation method (see "Manually Installing Your Router" on page 13).Getting to Know Your Wireless Router 7
1. Install and connect your wireless router to your network (see "Connecting Your Wireless Router" on page 14).
2. Set up your wireless router for Internet access (see "Setting Up Your Router for Internet Access" on page 18).
3. Configure your wireless network and select wireless security settings to protect your wireless network (see "Configuring Your Wireless Network" on page 21)
Feb 04, 2011 | NetGear WNR1000 Router
Network is hooked up correctly but when I try to get internet on the wireless laptop it says to unplug router for 10 seconds and try again. I did this and it still doesn't work. What else can I do?
Open the control panel ... delete the connection in yout network folder. Turn off the modem. Turn off the router. wait ... wait ... turn on the modem ... wait ... wait ... turn on the router ... wait ... wait ... turn on your computer wait ... wait ... run the connection wizard to discover the router. Windows should take if from there with a little help from you.
May 27, 2010 | NetGear WGR614 Wireless Router
I have a netgear, 54 mbps wireless router WGR614 v5 and can not locate my installation disk. Can anyone tell me where I vcan get the instructions to install it?
This is Netgear Support and the page for the Netgear WGR614 version 5,
http://kb.netgear.com/app/products/model/a_id/2587
1.Software you need:
Click on the Downloads tab.
Now click on the - WGR614v5 Firmware Version 1.09, in blue.
(I would bookmark this page. After you have installed the software, you need to come back, and download the Installation Guide. While installing the software, it is best to have your internet connection closed, and all windows closed. You will then be on your desktop screen.
If you do not have your downloads set to save to your My Documents folder, {Documents for Vista}, this download will go to your desktop screen.
When you see it, double-click right on the file name. The Installation Wizard will come up. Just click on Next, Next again, and Finish. Do not be concerned when it shows you where the file is going. It will be put in the correct place. Don't change it)
2.Documentation: (Instructions for installing)
Click on the Documentation tab.
The Installation Guide is listed at the top of the list
Sep 30, 2009 | NetGear WGR614 Wireless Router
Internet access not working on desktop thru Netgear WGR614 router
Make sure your desktop doesn't have static IP address. Go to Network Connections, Properties of Local Area Connection, Internet Protocol > Properties. Select Obtain IP Address Automatically and Obtain DNS Servers Automatically. Apply the changes and restart the computer.
Jan 18, 2009 | NetGear WGR614 Wireless Router
Wireless INstallation
you need to ring your ISP to get a network user ID and password, when you enter these in to the router settings the Internet light will light up green.
Jun 08, 2008 | NetGear DG834G Router
default access to router is http://192.168.1.1
login/password is with your instruction booklet.
May 07, 2008 | NetGear VS-WGR614 Wireless Router...
NetGear WGR614 Wireless Router Problem
dear leetheone,
your network wireless is not properly set up. you have to properly set this, try using the windows wireless wizard and follow the prompts.
sid
Dec 02, 2007 | NetGear WGR614 Wireless Router
NetGear WGR614 Router Logo
442 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
