Question about Honeywell Electronic Programmable Heat/Cool Thermostat - CT3300A100 Heater
Honeywell UtilityPRO thermostat backlight won't go off
The green backlight on one of my brand new Honeywell UtilityPRO thermostats won't go off -- it goes dim, but not off, so we have this green glow in our room all the time. My other brand new UtilityPRO thermostat is fine -- a couple of seconds of inactivity, and the light goes off. There's no code 280 in the advanced functions... any ideas on how to set the backlight?
  • scarobinson Jul 19, 2009
    I don't have an obvious model # -they were installed by our utility company. The bar code on the operators manual is 85-3126, and the bar code on the thermostats is 443045388, if that helps. The only other identifying mark is the name: UtilityPRO series, "Touchscreen Programmable Demand Control Thermostat." It's one the utilities install so they can cycle your A/C on and off during periods of peak demand. Trying to be environmentally friendly here, but now have a green light glaring at me 24/7!
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 86 Answers
After posting that I was having the same problem, I found a solution.
I used these instructions http://www.hydro-temp.com/help/drawings/honeywell%2069-1894ES.pdf and followed the Installer Setup on pages 6 through 10. Basically you just need to enter the setup mode following the instructions, scroll to setting# 280 and change the setting from "1" to "0" then the backlight will turn off after 8 seconds. Don't change any other settings if you don't know what you are doing.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jeffrey_634abadf963e31e5
Posted on Jul 24, 2009
  • theboop4u Dec 19, 2010
    This worked for me. I was initially told by my utility company installer that if I wanted to change the backlight option later on, I would need to call them for instructions since the code was not included (instructions manual stated to press one middle button that only gave limited codes). These instructions worked perfect.
  • nurahsmith
    nurahsmith Oct 29, 2012
    I would really like to thank you for posting this response. I've been living in my home for nearly five months and that backlight was driving bonkers. Thanks again.
  • 148 Answers
Do you have a model # for that stat? I can probably get the setup manual for you that shows how to disable\adjust the backlight function.
Posted on Jul 18, 2009
  • Mike McDowell Jul 20, 2009
    I think you have a bad stat because the backlighting is not adjustable. I do have the owners manual that I can send you just send me an email @ mocha44143@yahoo.com and I'll send it to you.
    MIke
The UtilityPRO program is described here:
https://buildingsolutions.honeywell.com/Cultures/en-US/Markets/Utilities/
and the manual for 85-3126 is linked at the bottom of the page. The instructions for the backlight are on page 22.
Posted on Dec 04, 2010
It is how they wired the unit. If it is wired to run on 24 volt it is on all the time if it is on 12 v it shuts off as it derives power from the battery. You have last years model.
regards
Posted on Jul 01, 2010
My wife insists on screwing with our Honeywell UtilityPro Series thermostat and this time I suspect that she has changed something in the ADVANCED FUNCTIONS settings. Not the ADVANCED FUNCTIONS menu...
Not trying to be a smart alec or anything like that but have you ever considerd in a thermostst with a lock-out key pad. We use them at the day cares and have no problems with the stats anymore.
Jan 30, 2011 | Heating & Cooling
House lights dim when ac comes on since new honeywell thermostat installed. Is this ok?
This is to tell you that the new installed honeywell thermostat as high voltage capacity, it is ok, it is not good enough, though, it as no much effect on your lighting points, but you can get a technician to see if there is a way to adjust the voltage at the thermostat.
Take care.
Jun 25, 2010 | Honeywell Programmable Thermostat Heater
Honeywell T2060 UtilityPro Demand Control Thermostat
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can’t find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need.
Feb 16, 2010 | Honeywell Electronic Programmable...
Thermostat, honeywell ct31a1003, brand new wont turn on heater, no ac, need wiring diagra. only red and white wires were previously connected. where do they go on new thermostat?
The red wire goes to the R or Rc terminal and the white wire goes to the W terminal. If there is more wires like a yello that goes to Y and there is probably a green this goes to G. There could also be a black and a blue the black would go to C and the blue would go to Y2.
Dec 31, 2009 | Kitchen Appliances - Others
I want to replace programmable thermostat with old dial style
The terminals should be the same on both thermostats, except for C- common.
R- usually RED, goes to hot side of transformer,
W- usually WHITE, goes to heat
Y- usually YELLOW goes to outdoor unit
G- usually GREEN goes to furnace blower
Any of the other wires just cap them off you don't need them. If you have an Rh and Rc terminal instead of R and don't have them on the programmable then put a jumper from Rh ro Rc.
If you need more, then let me know what terminals you have on both t'stats and brand of furnace and AC, if you have a heatpump then there's more wires let me know.
Oct 13, 2009 | Honeywell CT87B ROUND HEATING&COOLING...
Wiring
red goes to RC and RH, White goes to W, Green goes to G and Blue goes to Y. iam assuming on the old tstat that Red whent to R White went to W Green went to G and Blue went to Y
Sep 20, 2009 | Honeywell Programmable Thermostat Heater
Same problem, backlight on all the time
http://www.ntsupply.com/files/products/VP8000TechData.pdf
check out this website
if this is the touch screen tstat you have to enter installer setup
touch the SYSTEM button once
hold down what is usually the HOLD and SCREEN keys touch both keys at the same time
(hold the two blank keys on either side of the center key at the bottom)
this will bring you into the setup
BE VERY CAREFUL WHAT YOU CHANGE THIS COULD EASILY SCREW UP YOUR SETTINGS
change where the numboer is 0120 to 0280 and change 1 to 0 then hit done this should fix it:)
Jul 24, 2009 | Honeywell Electronic Programmable...
I'm installing a Honeywell RTH7600B programmable thermostat and replacing a Honeywell T87F2873. The new one calls for a Red, Green, White, and Yellow wire, while I only have a Red, Green White and Blue....
Every thing the same except take your blue wire and replace the yellow for it. So when you hook it to t-stat goes like this
Red to R
White to W
Green to G
Blue to Y
Jan 16, 2009 | Heating & Cooling
Changing a room thermostat a potterton to honeywell t6360
I think I've done it - but don't take this as absolute truth.
For the Honeywell T6360B the original Potterton wiring should be rewired as follows:
Brown [Live] goes to terminal 1; Blue [neutral] goes to Terminal 2 and the yellow/green [which is not an earth but a switched live - i.e. gives live to the heating system when the thermostat clicks in] goes to terminal 3.
Obviously all done with the power isolated and when it was switched back on we had heating again :o)
It's been on over two hours now and all seems fine.
Jan 13, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
6,949 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
