Question about Mastercool 67680 Evaporative Cooler Air Conditioner
Master cool controller failed
Lost the 24 VAC supply. It looks like the transformer failed (115VAC in, Nothing coming out). Where can I get parts for a new controller (AdobeAir Part # P225101A)
    Champion:
  • 233 Answers
Generally this is a 115/24 40 va transformer, as long at the VA rating and mount is the same you can source a universal.
Posted on Jul 20, 2009
Color code for theromstat
Wiring Examples and Instructions
How-To-Wire-It.com
Basic or Common Connection Points
Terminal Colour Signal-Type Description C Black 24 Vac Common Common side of 24 Vac Transformer See Diagram below R or V red 24 Vac Transformer Power Power side of 24 Vac Transformer See diagram below RH or 4 red 24 Vac for heat 24 Vac power before heat switch see diagram below Rc Red 24 Vac for cool 24 Vac power before cool switch see diagram below Y Yellow switched power (cooling) Signal to turn on cooling system see diagram below W White Switched power (heating) Signal to turn on heating system see diagram below G Green Switched power for fan Signal to turn on fan (forced air) see diagram below
Heat Pumps/Multi-Stage Units
Terminal Colour Signal-type Description Y2 Can vary Switched power (2nd stage cooling) 2nd stage cooling signal to compressor W2 Can vary Switched power (2nd stage heating) 2nd stage heating/ sometimes used as emergency heat E Can vary Emergency heat enable Dedicated emergency heat 0 Orange Reversing value Reversing dynamics of the heat pump ----
Nov 22, 2015 | Honeywell Digital Round Thermostat,...
I installed a goodman 5 ton heat cool unit and a 5 wire battery operated tstat, the unit is 2 stage will it work with this tstat cant get anything to work even jumping the tstat
See if there is 124 VAC across the common and the red wire. If not then the thermostat transformer inside the unit will have to be replaced or the fuse changed if it has one(not likely).All t/stats are not the same. If your T/stat doesn't have a provision for the 2nd stage or emergency heat then you have the wrong T/stat That will definitely blow the transformer that supplies 24 vac to the control relays
Nov 15, 2015 | Goodman Heating & Cooling
Where is the low voltage 24 vac transformer located?
The transformer is located in the furnace. You might want to check to make sure the furnace door is on correctly brcause theres a swich that will open for safety . Also some have a fuse on the solid state board.
May 26, 2014 | Rheem RASL024JEC-RHPNHM2421JC 2 Ton 18.50...
Acl lifestyle lp522
The display should not be blank, meaning nothing there to look at. Different digital thermostats can be powered in 3 ways. Just from their battery's, from the furnace control transformer, from the furnace control transformer with battery back up in case the control power fails to retain your programming. Usually, removing it from the base and pulling the battery's to kill ALL of its power, waiting a minute or so then re-powering it, will restore the factory program and return the display. Also, there may be a small fuse on the back of the stat. If it has one, it will be easy to see if you are looking for it. Easy to miss if just looking at it for no reason. Be sure there is power to it. The battery's and their connections first. If you have a meter, check for control voltage. Put one lead on "R" then touch the other to "C", "Y" or "H". Should have 24 volts (AC) from the furnace transformer. I have never seen a stat blow from a power outage. But?
Dec 18, 2013 | Heating & Cooling
Conveyor belt not working on the image17.5s
CompartirFacebookTwitterGoogle+DeliciousDiggGoogle BookmarksMySpaceStumbleUponRedditMessengerVodpodYahoo BookmarksBeboMister-WongWordPressGoogle ReaderOrkutXINGEvernoteNetvibes ShareStrandsPosterousBusiness ExchangeArtoTipdSmakNewsPlurkAIMYahoo MessengerIdenti.caMozillacaBlogger PostTypePad PostBox.netNetlogTechnorati FavoritesCiteULikeJumptagsHemidemiFunPInstapaperPhoneFavsXerpiNetvouzWinkDiigoBibSonomyBlogMarksTailrankStartAidKledyKhabbrMeneameYoolinkBookmarks.frTechnotizieNewsVineMultiplyFriendFeedPlaxo PulsePingSquidooProtopage BookmarksBlinklistFavesYiGGWebnewsSegnaloPushaYouMobSlashdotFarkAllvoicesJamespotImera BrazilTwiddlaLinkaGoGounalogHuggDiglogNowPublicTumblrLiveJournalCurrentHelloTxtSpurlYampleOneviewLinkatopiaSimpyLinkedInBuddyMarksAsk.com MyStuffViadeoMapleWistsConnoteaBackflipMyLinkVaultSiteJotSphinnDZoneCare2 NewsHyvesSphere***** BrowserGabbrSymbaloo FeedsTagzaFolkdNewsTrustAmazon Wish ListPrintFriendlyRead It LaterTuentiEmailRediff MyPageGoogle GmailYahoo MailHotmailAOL MailAny email By Lockerz1 )probably a faulty speed sensor try to adjust firt with the face to the motor. 2) the speed sensor is not plugged in properly tight . 3)also possibly a faulty motor Test for 110 vac.without load. 4)main control board or lower board faulty, try to see if coming 115VAC from transformer. 5) Test the main transformer for primary voltage and secondary voltage 6) Power supply coming from transformer and see if there are some components Ic., resistor, capacitor or diode burn. 7) You must test the tension form Deck belt is about 2-3" for lif, if not Re-adjustment 8) Lubricate the deck belt. See the block diagram for final diagnostic and you will get strong Resultant.
sincerely.
Merry Christimas.
ernesto cuadra
managua,nicaragua
Dec 19, 2011 | Icon Image 17.5 S Treadmill
PROfORM xp TREADMILL TURNS ON BUT BELT DOES NOT RUN
CompartirFacebookTwitterGoogle+DeliciousDiggGoogle BookmarksMySpaceStumbleUponRedditMessengerVodpodYahoo BookmarksBeboMister-WongWordPressGoogle ReaderOrkutXINGEvernoteNetvibes ShareStrandsPosterousBusiness ExchangeArtoTipdSmakNewsPlurkAIMYahoo MessengerIdenti.caMozillacaBlogger PostTypePad PostBox.netNetlogTechnorati FavoritesCiteULikeJumptagsHemidemiFunPInstapaperPhoneFavsXerpiNetvouzWinkDiigoBibSonomyBlogMarksTailrankStartAidKledyKhabbrMeneameYoolinkBookmarks.frTechnotizieNewsVineMultiplyFriendFeedPlaxo PulsePingSquidooProtopage BookmarksBlinklistFavesYiGGWebnewsSegnaloPushaYouMobSlashdotFarkAllvoicesJamespotImera BrazilTwiddlaLinkaGoGounalogHuggDiglogNowPublicTumblrLiveJournalCurrentHelloTxtSpurlYampleOneviewLinkatopiaSimpyLinkedInBuddyMarksAsk.com MyStuffViadeoMapleWistsConnoteaBackflipMyLinkVaultSiteJotSphinnDZoneCare2 NewsHyvesSphere***** BrowserGabbrSymbaloo FeedsTagzaFolkdNewsTrustAmazon Wish ListPrintFriendlyRead It LaterTuentiEmailRediff MyPageGoogle GmailYahoo MailHotmailAOL MailAny email By Lockerz 1) faulty speed sensor OR need to readjust do it the face must be face to face with the magnet from motor 2) the speed sensor is not plugged in properly 3) also faulty motor Test for 115 VAC coming from the main motor board 4) control board or lower board.faulty Testing from incoming input from transformer for 115VAC + 5VDC 5) Test the main transformer for input 115VAC, and secondary for power supply +5VDC 6) See if the power supply has output for +5VDC 7) See if there are some component from power supply : resistor+ capacitor+diode or IC.burning. 8) Lubricate your Deck belt very well. See finally the schematic diagaram supplied for me, and see the diagnostic for best troubleshooting.
Sincerely. Mery Christmas.
erensto cuadra
managua, nicaragua
Dec 18, 2011 | Proform XP 590S TREADMILL Drive Motor
Receiving Error Code 1
1) See the calibration software below the hood of your owner manuals for to help to diagnostic.
2) Adjust the speed sensor and tight the connector.
3) Main motor faulty. see the voltage 115 vac, without load.
4) Main motor controller board faulty. See the 115VAC for input coming from Transformer.
5) Test the TRANSFORMER for input voltage and secondary voltage,
6) Power supply output for +5vdc, for input and output.
7) Adjust the deck belt and drive belt.
8) Lubicate the deck belt.and
See the block diagram the I did for people like you. And diagnostic very easy. Sincerely. Merry Christmas.
ernesto cuadra
managua, nicaragua
Dec 15, 2011 | Proform Exercise & Fitness
I have a customer that recently replaced his generator, problem is , he got a 120 VAC output. He has 2 SW 4024 for 240 VAC output. Can I hookup the 120VAC to the master inverter, or should I get a...
I will accept the second option which is getting transformer.
Go ahead and get a transformer in order to step up the voltage. This is better than hooking up the 120V AC to the master inverter.
In summary, get a transformer to step up the voltage.
I hope this is clear now....
Good luck.
Apr 01, 2011 | Xantrex Technology Xantrex SW Series...
Wiring a generalaire 1042 humidifier to a goodman furnace,when there are no terminals marked hum
24 VAC HUM
The yellow wire connected to the I.D. Blower pressure switch
is powered anytime the pressure switch is closed and provides
24 VAC humidifier control. Remove the yellow wire and connect
the supplied brown jumper wire to the pressure switch
terminal. Reconnect the yellow wire to the "piggyback" terminal
on the brown jumper and then connect the 24 VAC line of the
humidifier to the stripped end of the brown wire. Using a wire
nut or a field-supplied quick connect terminal can make this
connection. The wiring must conform to all local and national
codes. Connect the COM side of the humidifier to the B/C
terminal on the furnace control board (or to the COM side of
the 24 VAC transformer). DO NOT CONNECT 115V HUMIDIFIER
TO THESE TERMINALS.
Feb 21, 2011 | Humidifiers
AC Control Transformer keeps failing.
well it has blown the fuse on the transformer, then you have coil switch bad.It could be the coil on the contath in for cooling.But can check by taking the yellow wire a loose and see if the don't blow. The red wire is one side of the transformer and the com could be any color.But look at the red wire because it is the main wire that travel the voltage throuhg the unit.
Mar 26, 2009 | Ruud UBHC Air Conditioner
Mastercool 67680 Evaporative Cooler Air Conditioner Logo
467 people viewed this question
Top Mastercool Heating & Cooling Experts
Bill Long
Dan Webster
Dan Webster
Boyet Soriano
Boyet Soriano
Are you a Mastercool Heating and Cooling Expert? Answer questions, earn points and help others
