Question about Fujitsu Siemens CELSIUS Notebook
Mine keeps pressing W
I set the settings not to repeat when a key is held down. It mildly helps me cope with pressing delete. It's very annoying...
I fixed mine by referring to my laptop's service manual on how to open the laptop till I get to the keyboard. Once there, I very carefully unplugged the cable connecting the keyboard to the board. After which, I just plugged it back in and re-assembled my computer.
Viola! It's fixed for me now!
Posted on Jul 18, 2009
How do i get my voicemail
on a home phone? You press the messages button.
On a cellular phone, first you make sure you have one in the contract and have paid for that service. The carrier will tell you how to set it up. I just had to redo mine, I held down the 1 key and followed the prompts. To get my messages is from the phone button and then your press voicemail and wait until you hear the prompt to put in your 4 digit memorable pass code. Then you press 1 to hear first unheard message, 7 to delete and 9 to save.
Apr 24, 2016 | Lands Phones
Can't find temporary recovery log
the only solution i can find to your problem is to delete the firmware update you've put on your table,you need to wipe the data,just reset it to factory settings,,just hold the back and power key then if you see it light ang the logo just release the power key the back remain,then your on the system mode just select wipe data fastory reset or what ever you want just press up and down volume to select..then press back button to start.....hope it help....
May 28, 2013 | Tablets & eReaders
How to delete whatsapp from a nokia C3 - 10
For Nokia C3-01:
1. go to the folder where you keep Whatsapp (usually Main Menu - Applications - Extras - Games folder or Application folder)
2. press left down corner button Options
3. Scroll down to Mark/ Mark all
4. Choose Mark and tick Whatsapp then
5. press left down corner button Options
6. the very first option is: DELETE MARKED!!! Press...
HOORRRAY, THE MOST ANNOYING APP IS DELETED!!!
Jan 01, 2012 | Nokia C3 Touch and Type Cell Phone
How do you set the answering machine or voice mail on this phone?
First make sure the answering machine is on; press the On/Off button to turn it on and off. To set a message to be heard by those calling in: press and hold Skip/Annc. Begin speaking when A shows in the message window. Speak from about 9 inches away from the phone. Messages must be more than 3 seconds and less than 3 minutes long.
Press Prog/Mem and then Skip/Annc to hear the current message. Press and hold Setup until you hear the current setting (Selected announcement is A or Announce Only). Use Skip/Repeat to change the setting. No one will be able to leave a message if Announce Only is on.
After you have held the Setup button, as above, press Setup additional times to set the number of rings before the machine answers and the remote access code among other features.
To set the date and time, press and hold Clock for 1 second. Use the Skip button to advance the current digit; the Repeat button will subtract one from the current value. Press Clock again to advance to the next value to change (day of week, hour, minute, second).
Press Play to hear new messages; press and hold Play to hear all messages. Press Repeat to repeat the current message. Press Repeat twice to hear the last message. Hold Repeat to slow the message playback.
Delete a message by pressing Remove during playback; press Remove twice to delete all messages (if there are no new messages). A blinking F indicates the memory is full and messages must be deleted.
I hope this helps.
(btw additional instructions for the answering system are available at the AT&T website. Direct link: http://telephones.att.com/documents/product_Product/219/UserManual/1982/1855_manual_bkm.pdf which may or may not work.)
Oct 29, 2010 | AT&T 1855 Phone
How do I delete one of the set programs on my utiltech 7-day digital timer? The directions say press the mode key, and keeping it held down, press the program key, it doesn't work. Any suggestions?
Clearing event on Utilitec 7-day timer:
Tiny print on instructions say: press PROG button several times to locate setting you want to clear > Press and hold MODE button > press PROG button to clear setting > to finish, press CLOCK button and display will show time of day.
In case of operational failure:
Tiny print on instructions say: press RESET button to clear all settings >> and then reprogram
Sep 12, 2010 | Intermatic Inc. ST01C Digital In-Wall...
How do I input in my radio code for Blaupunkt 2003 vauxhall corsa, if my code was 1742 and I can only use buttons 1, 2, 3 or 4 to use.
Blaupunkt CAR2003 Vauxhall Code Entry
The [ AS ] key must be held in while switching on the set. The set should then display 'SAFE' briefly followed by '10 - - - -'.
Press preset [ 1 ] repeatedly for the first digit
Press preset [ 2 ] repeatedly for the second digit
Press preset [ 3 ] repeatedly for the third digit
Press preset [ 4 ] repeatedly for the fourth digit
Press the [ AS ] key to accept. The set will now operate.
blank.gif _uacct = "UA-277454-2"; urchinTracker();
Apr 11, 2010 | Car Audio & Video
How do I change the time on my Durabrand PH5562 phone?
a friend of mine said to press the delete button and the down arrow until you get to the LCD screen. Keep pressing the delete button until you get to the hours and minutes. Set your time, then keep pressing the delete button until you get back to your screen.
Hunnybunny
Mar 15, 2010 | Lands Phones
Q key keps printing
Understand and use (or make sure they’re turned off) keyboard Accessibility Options. There are several types of help for those with typing difficulties, namely:
StickyKeys is an accessibility feature designed for people who have difficulty holding down two or more keys at a time. When a shortcut requires a key combination such as CTRL+P, StickyKeys will enable you to press one key at a time instead of pressing them simultaneously.
FilterKeys: You can set Windows to ignore keystrokes that occur in rapid succession, or keystrokes that are held down for several seconds unintentionally.
Bounce Keys: If you bounce your fingers on keys inadvertently, Bounce Keys will ignore repeated keystrokes until some time has passed. You choose the time period.
Repeat Keys and Slow Keys: The computer will ignore brief keystrokes according to the time limits you set. To access these Options and turn them off or on, go to your Control Panel– click Start >Settings >Control Panel >Accessibility Options.
By default it opens to the keyboard tab. If you are experiencing a sudden onset of bizarre typing behavior, your first step is to visit here and ensure that there are no checks in the three checkboxes, which indicates these Options are in use.
I mentioned that shortcuts ‘activate’ these features — such as Tab+Enter, and a couple of Alt+a letter– and so you may have turned them on unintentionally.
If you do have some difficulty with your typing, such as happens when a Mr. Arthur Itis comes to visit, or/and if you have tremors, here is where you can enable these aids and tweak their settings to get the most benefit from them. Click on the “Settings” button to see the choices. Below is the FilterKeys Settings dialogue.
In the case mentioned, my client had first held down the Shift key long enough to activate FilterKeys (because a finger “rests” there). The lady was an extremely fast typist, and this setting ignored her strokes as being too short. Since she has no use for this tool, I recommended that she uncheck the top checkbox and disable the activating shortcut.
This screenshot shows the settings for StickyKeys, and unless you have trouble holding down more than one key at the same time — such as Ctrl+Alt+Del to activate Task Manager — I suggest you uncheck the top checkbox here as well.
Aug 19, 2009 | Lenovo 3000 C100 Notebook
Brother MCF-5440 machine error 4F
ok
Access the internal maintenance mode by pressing the Menu/Set button, then press * 2 8 6 4 within 2 seconds. This should put you in the maintenance mode menu. Enter 80, then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.
This will reset the purge count value. Then the printer will restart, hopefully without the annoying cannot clean message.
All I ask is please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
All files on my website are only there for a limited time
Nov 23, 2008 | Brother MFC-5440CN All-In-One InkJet...
Help with siemens giga set4200
Hello, it sounds as if your base has gotten corrupt somehow. You can try defaulting it, but keep in mind you will lose all your messages, and will need to re-register your handsets if it works. To do so, get all your handsets together near you base. Unplug the power from your base and turn the base over. Push and hold down the Page/Registration key and keep it held down while you plug the power back in. Keep the key held down for at least 15 seconds, then release and begin registering your handsets. If you need help, I can email you a "cheat sheet" on doing so. You can contact me at www.cordlessrepair.com Good Luck !
Nov 05, 2007 | Siemens Gigaset 4000 Phone
Fujitsu Siemens CELSIUS Notebook Logo
269 people viewed this question
Top Fujitsu Computers & Internet Experts
Alun Cox
Computer Links
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
