Question about Frigidaire FRS6R5EMB Side by Side Refrigerator
When I close the refrigerator door the freezer door opens and stays open and create condensation and leaks below the refrigerator. How can I solve this?
  • 10,865 Answers
The problems you have are related.
Self-defrosting refrigerators dispose of the water generated during the defrost cycle, usually via a tube or channel that directs the water to a pan at the bottom of the refrigerator. From the pan, the water normally evaporates.
If the tube or channel is clogged or obstructed, the water backs up and leaks into the inside of the refrigerator compartment. Then the water builds up at the bottom, inside of the refrigerator. When the water has built up for a time it may spill out of the front of the door opening. To fix this problem, clear the drain tube or channel and allow the defrost water to flow down to the drain pan.
Posted on Jul 18, 2009
Fridge leaking
check door gaskets are in good condition Open and close door quickly Wait for maybe 10seconds and try and open the door . If the gaskets are working there will ne a marked resistance to opening
May 13, 2013 | Bosch KSU49630 Top Freezer Refrigerator
Both of our light bulbs on top burned out the same time/day. Model # GLRT218WD My husband changed one light bulb and it didn't work. Does that whole piece come out of the top, where the light bulbs...
Check the door switch. Alot of the time when the freezer door stays open it creates condensation and than when you close the door is can freeze the door switch closed so the switch thinks that the door is always closed. If you need further assistance or this does not cure your problem please reply.
Aug 01, 2011 | Frigidaire Gallery GLRT218WD Stainless...
Freezer door pops open when the Refrigerator door is being closed
My new freezer did the same thing. I contacted the company and they went into the whole leveling thing. What it has to do with is the magnetic seal. The magnets are not strong enough to keep the freezer door from popping open when closing the big fridge door. They share the same duct. I level my doors on the fridge and freezer so they swing shut by themselves after opening. Just the force of the big door when it swung closed cracked open the freezer door about a quarter of an inch and if left unnoticed created a puddle and made the fridge run overtime. I solved the problem by placing strong magnets inside the fold of the magnetic seal at the handle end of the door. This is the flap on the outside the door seal. I used six magnets on the top and six on the bottom. The magnets were from discarded Sonicare tooth brush heads. They are very flat and super strong. You can find something on ebay. My freezer door doesn't budge problem solved. I did call the company and told them I solved the problem and they still insisted it was the leveling. Good luck, Art Knapp
Jan 08, 2011 | Refrigerators
When I close the frig door, it blows the freezer door open. The same when I close the freezer door, it blows the frig door open.
That is because the unit is sealed. If the doors are staying opened I have posted a how to fix it linked just below.
Doors
May 26, 2010 | KitchenAid Superba Architect KSCS25INSS...
Doesnt get cold??
Okay,
Defective compressor, refrigerant low from a leak in the system, dirty condenser coils, condenser fan not working, bad compressor relay or capacitor, main thermostat control not working, thermostat needs to be set at proper setting, frozen evaporator coils do to faulty defrost timer, defrost heater coil broken, or the defrost determination thermostat has stayed in the open position, which would result in no defrost and the ice blockage would stop air the circulation, defective evaporator fan, defective door switch which controls the evaporator fan when one opens and closes the freezer door. Freezer drain clogged which would possibly cause the fan to be stuck because of ice built up around it.
Oct 13, 2009 | LG LFX25971ST Bottom Freezer French Door...
GE Profile freezer door problem
I wil let you know of things you can do to solve this.
This happens because the refrigerators of today are air tight, the fresh food door pushes the air into the cabinet as it closes and the air has no place to go but up the air vent into the freezer and "pops" open the freezer door. First thing is make sure the freezer door is capable of closing properly and is not rubbing or catching anywhere. I sometimes add a washer or 2 to the center hinge under the freezer door so it doesn't rub anything. Put a little Vaseline ( or food grade silicone lubricant ) on the hinge side of the seal. I then raise the front of the refrigerator so that the front of the refrigerator is a little higher than the back of the refrigerator. Never level a fridge with a level. Once you have the door closing properly and front slightly higher than the back...let the fresh food door close from 90 degrees on it's own and the freezer door may "pop" open a little but will close again on it's own...and stay closed once all is set up properly. We see this more often now and have no trouble with the door staying open again after setting up the refrigerator properly.
Hope this helps, Thanks Sea Breeze
Sep 22, 2009 | Refrigerators
Hotpoint CTF15ELD top freezer refrigerator - freezer O.K. refrig too warm
It's likely the door was inadvertently left open, and the cold air passages from the freezer have built up enough ice that the cold air from the freezer has no way to enter the refrigerator. Check the cealing of the refrigerator. If you can see or feel ice in the passages between the freezer and fridge, you can probably solve the problem by finding a safe temporary home for your food, and leaving the refrigerator unplugged overnight.
May 25, 2009 | Hotpoint HTS16HBR Top Freezer Refrigerator
Doors creak loudly when closed and pushed from the outside. Don't when open.
This short solution may help solve your creaking problem. First thing is make sure the freezer door is capable of closing properly and is not rubbing or catching anywhere. I sometimes add a washer or 2 to the center hinge under the freezer door so it doesn't rub anything. Put a little Vaseline ( or food grade silicone lubricant ) on the hinge side of the seal. I then raise the front of the refrigerator so that the front of the refrigerator is a little higher than the back of the refrigerator. Never level a fridge with a level. Once you have the door closing properly and front slightly higher than the back...let the fresh food door close from 90 degrees on it's own and the freezer door may "pop" open a little but will close again on it's own...and stay closed once all is set up properly. We see this more often now and have no trouble with the door staying open again after setting up the refrigerator properly. Putting vaseline insid the hinge pins too is a good idea.
Let me know if I can assist you better, Thanks, Sea Breeze
Apr 27, 2009 | LG LFC21760 Bottom Freezer French Door...
Freezer door won't stay shut
Could be the air pressure created from shutting the refer door is popping open the other one. There are are channels between the two so cool air from the freezer gets to the refer compartment. Try this as a test... s l o w l y close the refer door and see if that keeps the other door from popping open. If that works then it's likely an air channel is frozen up somewhere and you may need to turn the unit off for a day or so to let it thaw out. Moisture from leaking door seals, or doors that were left slightly open overnight can be sucked in and freeze up the air channels. I don't know if you are sort of slamming the door shut or not but the doors need to be shut slowly due to how air tight the new refers are.
Nov 10, 2006 | Frigidaire FRU17G4JW Refrigerator
Frigidaire FRS6R5EMB Side by Side Refrigerator Logo
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
