Question about Husqvarna Viking 1
Will not pick up lower thread. Bobbin wind and threading appears ok, we double-checked upper threading as well.
  • 10,865 Answers
Here is the link for free answers directly from husqvarna.
http://www.husqvarnaviking.com/us/2821_3079.htm
Posted on Jul 18, 2009
  • 3 Answers
DId you check for lint or thread fragments under the plate? This can cause all kinds of problems. Bush out any such materials. See if that helps.
Posted on Jul 23, 2009
The needle with top thread couldn't draw the bottom thread from the bobbin to ready the machine for sewing
Are you saying that the upper thread is not pulling the bobbin thread up to the top?
Install a brand new needle.
Remove the thread. RAISE the presser foot and rethread from the beginning--allows the thread to seat completely in the upper tension disk.
Check that the bobbin thread is inserted in the bobbin case facing the correct direction and that the bobbin case is threaded correctly through the bobbin case tension. Be sure to leave at least a 6" tail of thread on both the upper and lower threads.
Retest.
If it is still not picking up the bobbin thread, the bobbin case may be defective/malfunctioning or your machine probably needs professional service.
Feb 27, 2016 | Sewing Machines
I am having problems with the bobbin its not picking up the bobbin thread through the needle
thread the upper part and the needle put presser foot down hold loose end of thread with felt hand and turn the wheel with right . the needle goes down shuttle wraps the bobbin thread around the upper and when needle comes up the bobbin thread will be with it . OR have yo MOMMA SHOW U HOW
Feb 18, 2015 | Sewing Machines
Looped threads
Hello Rosemary
Looped thread on the underside are created by the upper thread. Loops on the top of the fabric are created by the bobbin thread. Whichever one is looping, has very little tension. This may be corrected by:
1. Re-threading the upper thread according to manufacturer's specifications.
2. Re-wind bobbin and re-set it into bobbin case and bobbin case area according to manufacturer's specifications.
3. Ensure that the needle is correctly installed and is the correct needle for the sewing machine.
4. Ensure that he bobbin being used is the correct one for the machine.
5. Double check that the tension on the upper thread is at the correct setting.
6. Double check that the tension unit is clean and free of dust, lint or lodged thread/s.
7. Double check that the bobbin tension is correctly set ... if you are comfortable doing so, otherwise leave it for a qualified technician
8. Make sure that he presser foot is down when stitching.
Please let me know how you go.
Happy stitching.
Nov 14, 2014 | Sewing Machines
Needle goes down but don't pick up the bobbin thread. It come up and tell me that my upper or lower thread is cut.
try changing the needle
try rethreading the machine top and bobbin
make sure to use every thread guide-this is improtant for the
thread tension
make sure the bobbin is turned correctly in the bobbin case
also could be a problem with the computer motherboard
or there could be a problem with the timing
Dec 03, 2012 | Brother PE-150V Computerized Sewing...
Thread breaking, not even threaded in needle anymore, thread gets caught on spool sometimes
Upper thread breaks
1.the needle may be bent or damaged--try rolling the needle on a flat surface to see if it's bent or not
Or the needle could be in backwards
Correct needle insertion
Correct needle insertion is mandatory for proper use of sewing machine.
Raise the needle bar to the highest point, then loosen the clamp screw to remove the old needle, place the new needle in the clamp with the flat side to the back of the machine or if using a round needle--the groove in the needle should face away from the shaft.
Push the needle all the way up to the stop or as far as it will go, then tighten the needle clamp screw
2.upper tension may be to tight--try 3 to 5
3.thread may be hanging up in bobbin case--check area for loose threads or lint
Lower thread breaks
The most probable cause of lower thread breaking is improperly wound bobbin
1.always start with a empty bobbin
Never wind one color over the other
2.choose thread that is identical in color & type as the one to be used for upper threading
3.wind the bobbin evenly across & in layers
4.don't wind the bobbin so full that it would be tight & hard to insert into bobbin case
5.bent bobbin--replace
6.lint built up in the bobbin case--frequent cleanings will eliminate this problem, the more often you use the sewing machine the more often it needs to be cleaned
7.thread catching on the bobbin spring or latch on bobbin case, check to see that the bobbin is inserted completely & correctly, & that you are using the right kind of bobbin
for the top & bobbin thread keep thread tails of 3 to 6 inches long pulled behind the needle before you start sewing
yes,sometimes the thread will get caught on the spool, you might think about getting a extra holder that sets behind the machine to hold those spool's that the thread get caught on, that's what I did.
Sep 15, 2011 | Brother PE770 Computerized Sewing Machine
Upper thread breaking while quilting
Upper thread breaks
Lower thread breaks
7.thread catching on the bobbin spring or latch on bobbin case, check to see that the bobbin is inserted completely & correctly, & that you are using the right kind of bobbin .
Sep 12, 2011 | Sewing Machines
My bobbin thread will not thread. When I bring the needle down, it comes up without the bobbin thread. The mechanism moves, but no thread. How do I fix this problem?
check the bobbin to make sure it's not warped
check the needle to make sure it's not bent-roll on flat surface to see if it roll correctly
make sure the bobbin is in the bobbin case correctly
make sure you have a 3 to 4 inch tail on the bobbin-so the upper thread can pick it up easily
make sure you have a 3 to 4 inch tail on upper thread also as it picks up the lower thread
or you can hold the upper thread with your hand to the side of the machine & use the handwheel to lower the needle as it picks up the lower thread
pull both threads to the back behind the needle
make sure there is no lint or loose threads in the bobbin area
Sep 01, 2010 | White Sewing 2200 Multi-Tasker
Needle will not pick up bobbin thread when sewing
double check the upper and lower tensions they often need to be changed to suit types of fabric and threads
Dec 12, 2009 | Singer Sewing Machines
Bernina 1008 bobbin tension problem
Double check that your needle is the proper one for your machine, and that it is in properly. It sounds like it is not picking up the thread properly. Tension problems usually have more to do with threading, thread or needle problems than with bobbin problems. Also check your bobbin is unwinding in the proper direction for your machine. Most machines unwind the bobbin thread, turning clockwise. Set your screw back to the factory settings, and give the machine a good cleaning as well. Lint can cause this to happen as well, if it builds up enough to interfere with the needle and the hook action. Double check that your upper thread is threaded properly as well. I suspect your needle is in backwards however.
Jan 08, 2009 | Bernina 1008
Sewing Machines Logo
183 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
