Question about Emerson Televison & Video
I replaced the main board on a Emerson model LF320EM4A TV & still no picture ? There is only one board and tv repair man said it needed to be replaced. Still no picture?????
  • 2,559 Answers
Put a flashlight to it and see if there is a picture. If so the back light has gone out. If not then the lcd must be out if there aren't any other boards.
Posted on Jul 27, 2016
Testimonial: "Thank you very much."
I Have A Emerson Lf320em4A Replaced The inverter Board With A New One. No Now Display?
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Mar 09, 2017 | Emerson Televison & Video
I have a Emerson LED 32 LF320EM4A has sound no picture
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Oct 01, 2016 | Emerson 32-inch 720p LED TV Refurbished
Emerson 55 inch LCD TV no picture, but backlight and sound works
T'Con board fault. Check and replace it. If you wish to get some details; check the site linked here. Pull up older posts.
Aug 10, 2016 | Emerson Televison & Video
How do I fix our emerson flat screen tv
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Nov 27, 2015 | Emerson Televison & Video
Hello. My 32" Emerson TV has no power. Standby light doesn't come on when its plugged in.
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Nov 20, 2015 | Emerson LC320EMXF 32 in. LCD TV
How to fix tv picture upside down and fuzzy rainbow color.
Factory reset will make it right. There are two types of reset to TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Oct 24, 2015 | Emerson Televison & Video
Emerson LF320EM4A TV volume changes higher by itself
Check and replace the damaged component/s at its main board. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Sep 15, 2014 | Televison & Video
Emerson lcd tv w/ dvd 19"
Contact the authorized service center for Emerson. The main board to your TV is faulty. A replacement should be done. Gopakumar Gopalan Google
Feb 27, 2014 | Televison & Video
My Emerson HDTV 32 inch sound stopped working all together. The picture is fine, but there's no sound.
everything with sound picture av component has to do with the main board of the tv not the power supply the only thing you can do its replace the main board not the power supply board or anything else cause it may be only a resistor or a capacitor but to replace it the guy that comes to do it will charge more than replacing it go to www.shopjimmy.com and check your tv model and it will give you what you need and the price and cheaper than the manufacturer
Apr 13, 2010 | Emerson LC320EM9 32 in. LCD HDTV
Mother Board Failure Where do you get a replacement.
ebay!
Dell 32" W3202MH,W3706MH 01004-2960 Main Video Board ... - eBay
https://www.ebay.com/itm/...W3706MH...Motherboard.../162597765902?_...
  1. Cached
US$59.99 - ‎In stock Model: W3202MH,W3706MH. Do not match by TV Model. There are possibly several different boards for each model TV. This board has been pulled from a working cracked screen TV. Type: Main Video Board Motherboard Unit. ' eBay!
Dell Main Board 01004-2960 for W3202mh W3706mh ' eBay
https://www.ebay.com > ... > TV Boards, Parts & Components
  1. Cached
Used condition; • Returns accepted - 60 days money back or item exchange. Model: W3202MH,W3706MH. Do not match by TV Model. There are possibly several different boards for each model TV. This board has been pulled from a working cracked screen TV. Type: Main Video Board Motherboard Unit. See details.
W3202mh W3706mh ' TV Repair Parts & Components Online
https://tvrepaircomponents.com/...motherboard.../discount-w3202mh-w3706mh__part_... Get the best deals on Part in our clearance section in addition to deals on motherboard board, board video motherboard, main video motherboard, main unit, un.
Dell TV Main Board ' eBay
https://www.ebay.ca > ... > TV Boards, Parts & Components > Dell TV Main Board
  1. Cached
Dell 32" W3202MH,W3706MH 01004-2960 Main Video Board Motherboard Unit. Model: W3202MH,W3706MH. Type: Main Video Board Motherboard Unit. Do not match by TV Model. There are possibly several different boards for each model TV. This board has been pulled from a working cracked screen TV. C $74.81.
DELL 37" W3706MC 01004-3190 Main Video Board Motherboard Unit
https://www.ebay.ca > ... > TV, Video & Audio Parts > TV Boards, Parts & Components
  1. Cached
SKU: 01004-3190. Brand: DELL; Condition: Used; Notes: Please be sure that the BOARD Part Number and picture on your motherboard is EXACTLY as shown above. Do not match by TV Model. There are possibly several different boards for each model TV. This board has been pulled from a working cracked screen TV.
Mar 04, 2018 | Dell W3706MH 37 in. LCD HDTV
Televison & Video Logo
52 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
