Question about Intel (RK80532PG0881M) Pentium 4, 3 GHz Processor
Processor Speed Problems
Ok, just got a new MB and CPU and got everything running perfect...downloaded the Intel Processor ID Utility and says its running at 3.0GHz and 800MHz System Bus...then after about an hour, I check the utility again and it is running at 1.96GHz and 524MHz SB....
    Problem Solver:
  • 7 Answers
Re: Processor Speed Problems
In bios you might have your computer set to auto fsb and the ghz can change depending on usage, if you are in full time gaming this should be at 3ghz for most of it. try finding a program that can record these results as you do something processor hungry
Posted on Jan 05, 2008
  • 63 Answers
Check your Power Options (located in the Control Panel) and make sure your computer is not throttling the processor to save power.
Posted on Nov 19, 2007
0 characters
3 Points
I have not vga(video) drivers.....pls help me
we can use three type of mother board on dual cpu. that are 865 chipset , 915 chipset , 945gz chipset, u can download thease driver from intel . enjoy good luck. plzzzzzzzzzz vote me for increase my rating
Jul 28, 2009 | Intel Pentium Dual Core E2140 / 1.6 GHz...
Maximum MB or GB of graphic memory supported by Celeron d 325?
you can as high graphics card as you want as long as the is a PCI card.
hope this helps.
please rate good.
Mar 01, 2009 | Intel Celeron D 325 2.53GHz 533MHz 256KB...
I have 2.6 celeron processor with intel 865 motherboard i am up grade tell us who is processor best
on mb with intel 865 the bigest CPU is pentium 4 @ 3GHz. socket 478
however your MB might require to update microcode for the new CPU.
one more thing: this chipset Intel 865 is obsolete, and intel does not manufacture this cpu type anymore.
Feb 22, 2009 | HP Celeron A , 2.6 GHz (DL458AV) Processor...
you could only upgrade the processor and RAM in this condition i.e.
you can only change your an upgraded p-III processor like 1.0 GHz, 1.1 GHz or 1.3GHz and
upgrade the RAM by changing to 256 in each slot.
that is all what u can do with ur pc
Oct 18, 2008 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
PC shuts dowm
It sounds like your computer is running to Hot>
You can check the temp. in tour Bios if you just want to see how hot it is running
I usually will run the computer for awhile and the reboot
and and before then press F4 or sometimes F2 to then go to setup
From there you bios will be there and you can see if your fans and the cpu temp and your Video cards temp..Which could be also getting too Hot and if you tweak it or if the Fans on the boards are covered in dust this will cause it to heat up. That goes same for the Cpu Fan too.
Note Please do not make any changes to your BIOS and don't Save anything
Thank You
Aug 28, 2008 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
Defective sony/intel cpu?
Sony tech support, refused 2 show me how 2 reset the multiplier.apparently their firmware has a multiplier of 6x locked in.nowhere in the bios/cmos can it be says its suppose to be a 9x multiplier 2 achieve the 1500mhz.why would sony throttle down a 1.5ghz rig to 997mhz?they cpu must be defective & to stop it from blowing up on people they set the multiplier @ 6x.ok fine but don’t advertise it as a 1500mhz rig & make consumers think that’s the speed they’ll b many other u.s.citizens r unaware that they’ve been swindled/cheated/misled?what about a recall? What about some legal action against them?i’ve spent hours & hours e-mailing them & making phonecalls & they’re intent on acting as if they’ve done nothing wrong.
Jul 15, 2008 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
Ok first of all can I have the model of the unit? secondly usually when you first boot up the computer you can hit delete to enter the bios setup. Now unfortunately you have to hope that the multiplier is in the bios. Sometimes it is a jumper located on the actual motherboard. Once I get your model number I can assist you further. Try that first once in the bios look around to see what you can find. Also you can change it in power management in control panel. But they are probably correct most laptops do bump up the speed automatically. This helps to conserve power. Which you would want with your laptop.
Hope this helps.
Jul 14, 2008 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
My pc is slow
you dont explain your processor speed
May 31, 2008 | Intel Celeron 2.4Ghz Socket 478 CPU (...
Processor upgrade
Need to look at the motherboard specs along with the processor "Socket". It will usually be a 754 or 939 depending on what your motherboard says. I wouldn't try too fast and set yourself up for disappointment. I would upgrade the RAM before the processor.
Mar 22, 2008 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
Intel (RK80532PG0881M) Pentium 4, 3 GHz Processor Logo
Top Intel Computer Processors Experts
Brian Sullivan
Brian Sullivan
Shafky Khan
Sudeep Chatterjee
Sudeep Chatterjee
Are you an Intel Computer Processor Expert? Answer questions, earn points and help others
