Question about JVC AV-48WP30 48" Rear Projection Television
I bought a jvcwp30 with a convergence problem and bowed picture. I replaced the convergence ic's and it fixed the bowing and most of the colors except it won't let me move the center red far enough down. i can move all the other colors in every direction, just the center red needs to go about a quarter inch lower, but it always stops short. Any suggestions? Thanks for your time.
  • traxxasdude9 Jul 18, 2009
    No, how do you tell if those are bad? Do they just look black?
  • traxxasdude9 Sep 02, 2009
    ok i got the tv working, i figured out that if you press the white button on the convergence board it goes into a much more detailed convergence setup menu, which allowed me to move the red to the correct spot.
  • JVC Master
  • 8,617 Answers
Did you replace any of the 12 feed resistors, as a JVC will usually burn at least one of the 12 resistors
Posted on Jul 18, 2009
My rear projection television is showing a double picture with the blue out of allignment. It also shows a bow on the top and a bow on the bottom.
The tv have a problems known as a convergence problems,tv convergence board it is dead.Tv have R,G,B colors lines mis alignments,have colors pictures shadows or 3D pictures look alike?Yes.The tv convergence board it is dead.Must require replacing 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv picture convergence problems.The tv shop,will cost u like $300-350 for parts and labors.
Apr 24, 2011 | Zenith IQC50H95W 50" Rear Projection...
There are 3 distinct color lines and the picture looks 3d. The lines are bowed and trying to adjust using the convergence grid doesn't work- the grid is bowed
Mitsubishis are notorious for bad solder connections on the convergence IC's. These are located on the big heat sinks on the main board. It's an easy fix if you know how to solder. Check for any play on the IC's when "wiggled".
Feb 06, 2011 | Mitsubishi WS-55511 55" Rear Projection...
My Toshiba projection screen TV the picture is bowed and the colors don't line up
3d colors not lining up poblem dicates "convergence issues.. bowing piture may indicate complete faliure of convergence alignment cuircits... depending on model the most likely cause will be 2 micochips (ic's called stk<s)
Aug 23, 2010 | Toshiba Televison & Video
Picture bowed and colors don't line up on my Sony KP-51WS500 Sony KP-51WS500 its bowed and words show up different colors like in 3s.
This is a convergence problem that can be as simple as poor solder connections on the convergence ICs or defecive ICs. If you can solder you can repair this yourself, Let me know if you wish to attempt the repair and I'll provide additional details and instructions.
Dan
May 13, 2009 | Sony Televison & Video
Colors have separated. and top and bottom af pictures are bowed. i have a sony kp-46s55. its about nini years old and it was free. currently the colors are separated and the top and bottom of the pict
nbad convergence ic , this need to be done by a profecional tv tech , because need to check for the pico fuse and resistor around the area
May 08, 2009 | Televison & Video
Projection T.V. Picture
Replace Both of your STK ICs convergence ICs STK392-110 use 150s Better ICs Call Mats 1-800-628-1118 Also RK42 RK46 RK48 RK50 RK54 RK58 RK60 will have to get back to you on resistor values
Jul 21, 2008 | Hitachi 60SX12B/13K 60" Rear Projection...
Covergence and Bowed Picture Problem
can you adjust any color of convergence in user menu blue, or red up or down left or right. if you can make any up or down left or right adjustments on any color then the likelihood it wont be a convergence ic. it would be a output resistor. so see if you can get any movement. with it being bowed i was suspect an convergence ic.
Jan 08, 2008 | RCA P60920BL 60" Rear Projection...
Problem with convergence
bad convergence ic's
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 03, 2008 | Philips Magnavox 9P6034C 60" Rear...
Hitachi projection tv model 3 51gwx208
Do you mean that at the top of the picture, the red color has shifted downward, bowed towards the center? If that is what you see, one color suddenly bows toward the center on any side of the picture, then it means that one of your convergence IC's has burned out and needs to be replaced. It is a good idea to go ahead and replace both STK392-110 IC's with the newer improved STK392-150's. If you have never replaced convergence IC's and realigned the convergence circuits in a projection TV then allow a qualified tech to handle it for you.
Aug 05, 2007 | Hitachi 51GWX20B 51" Rear Projection...
JVC AV-48WP30 48" Rear Projection Television Logo
258 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
