Question about Garden
I need a diagram of how the housing is put back together on a briggs&stratton 15.5 IC OHV
  • 155 Answers
Hi if you go to the b&s website and go to parts look up , Put in your model,type & code numbers
found on your engine cowl it should bring up an exploded view.
Hope this helps
Mark.
Posted on Jul 23, 2009
18.5 hp Briggs & Stratton putting in rocker arms back, one goes in to far?
turn the crank see if it rises back up you may have droped one of the guides that ride the cam because youll have to tear her back down
Nov 20, 2012 | Briggs & Stratton Briggs Stratton Intek V...
Briggs & strattion ignition wire diagram
Check out Google and you should be able to down load a PDF Manual that will show you every thing you need to know.
Oct 02, 2012 | Briggs & Stratton Briggs Stratton Intek V...
Need manual for briggs 407777 0229e1 trying to replace crankcase gasket something fell out im tryin to decide how to put it back together do you remove the round plate at the bottom to insert this small...
An exploded parts diagram is available here:
http://www.briggsandstratton.com/engines/support/?NTT=4077770229E1
There are service manuals available here:
http://www.jackssmallengines.com/Products/BRIGGS-STRATTON/Manuals
Oct 04, 2011 | Briggs & Stratton Briggs Stratton Intek V...
Low oil & smokes - 2yrs old
The piston rings need to be replaced. The cylinder might need to be bored out bigger, then put in
a bigger piston.
Hope this helps.
Oct 25, 2010 | Briggs Stratton IC Horizontal OHV Engine ...
Need valve clearance for 24 ohv engine,4457770168e1
You should be able to get the settings from the Briggs & Stratton Website
Aug 24, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Brigss and Stratton engine getting to much fuel
I HAVE A BRIGGS & STRATTON INTEK 18.0 ,JUST FINISHED CUTTING THE YARD,WENT BACK ABOUT 20 MINS LATER TO PUT LAWN TRACTOR AWAY. WILL NOT TURN OVER WHEN I TRY TO START, FUEL LEAKS OUT OF THE EXHAUST AND AROUND THE BOWL
Jun 19, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Pull cord on B&S 6.5 HP OHV engine used on water pump occassionally will get "stuck". Cord pulls out 3-4" only, but then starts normally when pulled at later time (eg 2 hours later). Why? Can I correct...
The Sprag clutch need to be oiled.
Remove cover, remove the top part of the sprag clutch you will see some small balls ensure they are not rusty oil the shaft and put back together.
Hope this tip helps.
r/
David
Dec 20, 2009 | Briggs & Stratton Briggs Stratton Vanguard...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
