Question about ASUS Eee PC 4G (90OA01A20102111U305Q) Barebone
My computer seems to scroll as if the "Tab" key is being held down
    President:
  • 846 Answers
Hello thedragon_43
The typical cause of this problem would be a sticky key, worse case the tab key is damaged. Either problem would cause it to continue to scroll down as you said.
The only thing you can really do to try and fix it is see if you can carefully pop it off with a flat head screwdriver. (Don't force it to hard)... Clean any mess you may see under it, and then put the key back on, again not forcing anything while doing so.
If that still can't fix the problem then you may have to consider finding a used or replacement keyboard for it.
Try my suggestion, and post back for further assistance. Thank you for trying Fixya!
Posted on Jul 19, 2009
How to restore sumsung galaxy tap 101
Perform a hardware factory reset - Samsung Galaxy Tab 2 10.1
  1. A master reset will return the tablet to the default factory settings and erase all personal information on the tablet. All important information should be backed up before proceeding.
    With the tablet turned off, press and hold the Volume Up key.
    Note: To turn the tablet off completely, press the power key, tap Power off,and tap OK.
  2. While holding down the Volume Up key, press and hold the Power key.
  3. Hold both the Volume Up key and the Power key until the Samsung logo appears.
    Release the Power key when the Samsung logo appears.
    When the Samsung Galaxy Tab 2 10.1 logo appears, release the Volume Up key.
  4. Press the Volume Down key to scroll to wipe data/factory reset.
  5. With wipe data/factory reset highlighted, press the Power button.
  6. Press the Volume Down key to scroll to Yes --delete all user data and press the Power key.
  7. Once the wipe is complete, press the Power key to select reboot system now.
  8. The master reset is now complete. The tablet will restart.
Mar 04, 2018 | Galaxy Computers & Internet
How do I reset the Samsung Galaxy Tab 2 7.0
Hold volume up and power key at same time..then on the android screen, with the android upside down, with his door open..scroll down and hit power button to select reset, or erase and reset..but you will lose everything on it...
Sep 30, 2014 | Samsung Galaxy Tab 2 7.0
Beeping when in start up many times and scrolls down the page automatically
Do you have picture? Many beeps can be faulty video output...but I would also guess maybe a stuck key, the beeping would be the interrupt working overtime and the scrolling down could be an indicator as to which key is stuck, depending on when it scrolls, posibly a down arrow, number on numeric keypad, or return or tab key?
Sep 15, 2013 | Acer Computers & Internet
Need to find list/definitions of "function Keys"
Please open this LINK, scroll down to page no. 2-5 i.e. the section with "To use the Function Hot Keys Fn". There you'll find the details about the functional function keys of your compaq. It seems your function key i.e. Fn key is activated, to deactivate, press and hold down the Fn key while you tap the Numlock key once.
Let me know if you need further help.
Good Luck.
Thanks for using FixYa.
Feb 26, 2011 | Compaq Computers & Internet
The scroll pad doesn't work
Hi, Inorder to get the scroll pad to work you need to press and hold down the Fn key located on the bottom row of the keyboard and with the Fn key held down push and let go off the F7 key and should be able to get the scroll pad to work. Thank you for your patience and best wishes for your effort.
Jan 04, 2011 | Acer Aspire AS5520-5537 Notebook
Dell mouse not responding; diagnostics results says test passed. mouse works on other PC
There is a very good chance it's one of two problems. First, while theoretically you can connect tons of USB products, sometimes USB ports can be kind of hinky... Try unplugging something else USB based and plugging in the mouse or try several different ports. Also be sure it's not plugged into a USB hub and is going directly into your computer. If this works play with the arrangement of your USB devices until you find a configuration that works, maybe you'll have to switch out a printer or external drive while using your USB mouse...
If this doesn't provide a solution the next thing to do is to uninstall the pointer device driver in device manager and allow it to re-install.
If you don't have an alternate mouse to complete the task, here is the keyboard shortcuts for Windows although depending on your version of Windows it may be slightly different.
-First hold the windows key and hit the r key (win+r)
this will bring up the run menu
-Next type mmc this will bring up a management console
-Next press the ALT key and hit the down arrow key
(this should drop down the file menu, if it doesn't please try ALT+F)
-Use the arrow key to scroll down to Add/Remove snap in and hit enter.
-Use the arrow key to scroll down to Device Manager and hit ALT+A to add the device manager to the console. Hit enter.
-Make sure local computer is selected if this menu comes up and hit enter.
-Hit enter one more time bringing you back to the console with the device manager added.
-Hit tab to get to the center console and scroll down to mouse.
(If tab isn't doing anything please hit the ALT key once.)
-Hit enter to open the tree if it isn't already
-Scroll down to mice and other pointing devices (or something along these lines) and hit the right arrow key to expand the tree again.
-Select the USB mouse with arrow keys
-Hit the alt key again then the down arrow (not together) and then the right arrow key until you get to the action menu and use the arrow key to go down to uninstall and hit enter.
-Wait a moment and then go back to the action menu (you may have to hit tab just keep trying tab and the down key (not together) until a menu opens. Go over to the action menu again and choose scan for hardware changes. The computer should recognize the mouse and now work.
I hope this helps you. Thank you.
Jan 04, 2011 | Dell U0636 Mouse
I can't log out of facebook from my palm centro!! how do log out??
1) Press the options key on the bottom right of your keypad (next to the alt key). A drop down menu will appear on the top of your screen.
2) Scroll over to the options tab.
3) Scroll down to the Settings tab
4) Logout button will appear
Oct 28, 2009 | Palm Treo 500 Centro
Why did the subscript numbers of the keyboard are entered instead of letters? how can i change it?
This can happen if the Fn (function key) is held down while the scroll key (number lock) is pressed. Try holding the Fn key down and press the scroll key to see if the letters free up.
Sep 26, 2009 | IBM ThinkPad T42 Notebook
How to clear tabs on a Swintec 8016.
To get to tab clear try the tab set key with the code key or the shift key.
DickyO
Sep 18, 2009 | Swintec 7040 Typewriter
Hot key
for mine it's:
tap scroll lock twice then press 1 or 2
Sep 26, 2007 | Belkin F1DK102P 2-port KVM Switch
ASUS Eee PC 4G (90OA01A20102111U305Q) Barebone Logo
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
