Question about KitchenAid Refrigerators
Refrig side doesn't cool like it did, changed the overload relay and nothing was diffrent, and the compressor is hot to the touch. is this common? i now have the freezer side set on the middel setting and the frig side all the way up, we stuck a freezer pop in the freezer and it is still frozen and we stuck a warm soda can in the frig side and it is cold now and we have cold air coming out the top left side vent in side the frig side of the unit, its not a fast cold blast but its cold. This problem started when we noticed that we had a lot of ice build up in the freezer side and the frig side started to loose it's cool.we had some one come out and they said it was our defrosting cercuit board, and another person said it was our overload relay! before we installed the overload relay we cleaned the coils real good and every thing else that is on the bottum of the unit, then we plugged it in and after awhile the compressor started to make a klicking noise and the compressor was hot to the touch ,you could touch it but you couldn't leave your hand on it. the fan was working just fine but the back of the unit was off due to damage a while back, way before this problem. we have a cover on the back now made out of thin sheet metal "cut to fit" one of my questions is! does the back cover go completly across the back with out having any vent holes or vent slots? question #2 how hot is hot? question #3 are my units settings ok now ? did i fix the promblem? please help thanks!
Why is there a fee for your solution, but you want me to add my own solution for free, i guess you guys are just like so many others out there complaining about the problems we have here in the US.
Stop thinking about the money all the time, and just do something for free for a change.
A SIMPLE ACT OF KINDNESS IS THE ONLY ADVERTISING YOU WOULD EVER NEED
every one says if only the other guys would do it ! " GUESS WHAT "
"YOU ARE THE OTHER GUYS" "STOP BEING SO SMALL THINKING"
WHY IS THERE ALWAYS A FEE NOW? I WANT TO KNOW HOW MUCH YOU CHARGE FOR SIMPLE DIRECTIONS WHEN SOME LOST SOLE NEEDS TO FIND HIS WAY AND STOPS ON YOUR COMPANIES DOOR STEP? IF IT'S FREE NOW, FOLKS LIKE YOU WILL SOON FIND A WAY TO CHARAGE A FEE ON THIS ONE ASWELL.
THE MONEY MONSTER HAS YOU AND YOUR COMPANY AND THE ONLY WAY TO REALLY HAVE WHAT IT TAKES TO BE A GREAT SERVICE TO ANOTHER HUMAN HERE ON EARTH IS TO TRULY BE FREE OF THE MONEY CHAIN AND BALL "GREED IS FOR TODAY WHAT PLANS DO YOU HAVE FOR YOUR COMPANY TOMARROW? MORE GREED ? USEING HIRER PRICES? JUST BECAUSE YOU CAN OR BECAUSE YOU NEED TO.
GOOD LUCK ON CHASING THE MONEY MONKEY AROUND, I HOPE YOUR REAL HAPPY SPENDING ALL YOUR DAYS GATHERING ALL YOU CAN, JUST TO END UP NEEDING MORE.
MAYBE YOU WILL SEE THE TRUTH ONE DAY AND IT WILL SET YOU FREE.
HAVE A GREAT DAY I KNOW I WILL AND AGAIN GOOD LUCK WITH CHARGING THOSE FEES.
Posted on Jul 18, 2009
Admiral HMG61139 21.1 cu ft Side-by side refrigerator, not cooling. clicking sound every few minutes. (sounds similar to oven thermostat or relay coming on).
Thier is one of a couple things going on with your refrig.
The start relay on the compressor is bad so what your hearing is the overload thermostat tripping on and off and keeps trying to start the compressor
The fan motor by the compressor called the condenser fan motor is not running to cool the compressor so once and what you overload keep trying to start the compressor but its too hot to start
Finally the compressor is locked up and the overload still keeps trying to start it but its totally seazed and ain't going to run
I hope this helps you to determine what is wrong with your refrigerator,
Gene
Aug 10, 2011 | Admiral 26 cu. ft. Side-By-Side...
I have a frigidaire side by side #FSC23LR5JM2 that is not keeping cool enough. Age is aprox 1.5 yrs. Noticed the problem over a couple of days. Turned the temp cooler by 2 numbers in the frig and freezer,...
if the freezers staying cold but not the refrige section,then its the damper vent door between the freezer and refrige section thats either frozen shut or the damper door motor is bad or without power,if nothings cold as in freezer and refrigerator sections,then its the ptc overload & relay on the compressor thats bad,unplug the ptc overload & relay off the side of the compressor and obtain an exact replacement and plug in the new replacement and it will again cool
Mar 23, 2011 | Frigidaire FRS3R5EMB Side by Side...
Not cooling clicking sound refrig compresso and
IT'S MOST LIKELY THE START RELAY/OVERLOAD PROTECTOR ON THE SIDE OF THE COMPRESSOR. UNPLUG UNIT AND PULL START RELAY OFF AND SHAKE. IF SOUNDS LIKE IT'S FULL OF GRAVEL IT'S BAD, OR GET VOLT /OHM METER AND CHECK CONTINUITY BETWEEN THE START AND RUN TERMINALS ON BACK SIDE OF RELAY, WHILE YOUR THERE CHECK CONTINUITY BETWEEN THE BACK SIDE OF OVERLOAD AND WHERE L1 WIRE COMES IN FROM THE HARNESS. IF ALL THAT CHECKS OUT THE COMPRESSOR MIGHT BE BAD OR DRAWING TOO MUCH CURRNET FOR THE FACTORY START DEVICE. YOU DIDN'T NOTE A SERIAL #, SOME OF THOSE MODELS WERE UNDER RECALL FOR THE RELAY/OVERLOAD PROBLEM.
Oct 06, 2010 | Maytag MSD2756G Side by Side Refrigerator
Making humming noise on and off and not cooling
Unplug the refrig and pull the refrig out and remove the lower panel covering the fan and compressor . On the compressor , is a small box ( overload/relay ) with 2 or 3 wires going to it . This part just plugs onto the side of the compressor . Take your complete model number with you so you get the correct part . If you had given the model number here , I could have given you the pt # . Also clean the coils in the front bottom of refrig , of dust , lint , pet hair , etc , as this could have caused the compressor to get hot and short the overload/relay .
Sep 27, 2010 | KitchenAid Refrigerators
Not cold, fan runs, compressor hot to the touch, compressor relay click about every few minutes but nothing happens.
You need to replace the piece ( overload/relay )attached to the side of the compressor , with 2 or 3 wires attached to it . Take your complete model number with you when you go to get the part , so the correct part is gotten . If you had listed it here , could have given you the part number . Also , make sure the coils are clean at the bottom in the front of the refrig , as this will also cause the relay to burn out , if not clean .
Oct 15, 2009 | Kenmore Refrigerators
The mini fridge does not cool. This fridge doesnt use any fans so nothing to check there. The compressor seems to be awfully hot (although I dont know if thats normal) you wont born your hand but it would...
Hi, it's possible,your motor overlay relay has switch off motor, if your days are hot, or if room temp get high, that could happened,unplug ref. let motor cool down for about an hour, if compressor is running, but not cooling, it's possible you got a freon leak, normally ref have a condensate line, that passes through, front of door, that usually get rusted and leak,normally we by-pass it, now if there's a leak, you will have to repair leak first, you will have to change filter drier, vacuum and recharge. no you won't be able to buy freon and tap it up, same princple like vehicle a/c, but, different application, could also be an electrical problem, check motor overload, situated on compressor terminal, remove compressor terminal cover, and you will see overload relay, it's round, has one wire connected to compressor terminal and another connected to wiring harness. also, you can check compressor for short circuit, remove 3 wires from compressor terminal, place one tester lead on copper tubing coming from compressor and next tester lead, place on compressor terminal one by one, if you hear a beep (continuity) from any one of those terminals, compressor windings are faulty, replace compressor, or could just be hot summer months, let it cool down, but remember, remove plug from receptacle. or you are victim of low voltage, low voltages are more frequent in summer months, it could damage compressor winding, or compressor overload relay, let it cool down, and retry it. let me know what happened, before you attempt any repairs. and i can tell you what exactly what the problem are. good luck.
Aug 11, 2009 | Sanyo SR-4911M Compact Refrigerator
Refrig compressor only click but does not engage
Probably the start relay or a bad overload (check overload continuity with a volt/ohm meter) Maybe a broken or burnt off wire inside the compressor terminal cover. Possible, but unlikely compressor locked up. Unplug it before getting into the terminal cover.
Jun 27, 2009 | Magic Chef CTB1922 Top Freezer...
My refrigerator dosen't cool or freeze
the hot piece is the compressor.the clicking is the relay trying to start the compressor.generaly when im out on a service call and the compressor is hot and relay clicking the compressor has failed internally.because if the relay was clicking but the compressor was not hot there was a chance only the relay was bad and not allowing power into the compressor.but because the compressor is hot that tells me the relay is letting the power to the compressor but the compressor cant do anything with it because it locked up and its absorbing that power getting hot and then clicking on overload you could try a relay but i don't think it will help. God bless ,tom
Jan 23, 2009 | Kenmore 50522 / 50524 Side by Side...
Refrigerator Compressor hot to touch & fridge/freezer not cooling
you need to do an amp draw with your meter,clamp the run wire on the compressor,you should get 2-5 amp reading,any higher means the compressor is going bad,also should be a locked rotor amp(LRA) reading on comp.-mike
Nov 04, 2008 | Kenmore 53542 / 53544 Side by Side...
Refrigerators Logo
60 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
