Question about Pioneer DEH-P7900BT CD Player
I have a DEH-P7900BT. It was working very well for the last one year. But last week onwards I am facing a strange issue. The audio from the system go blank (mute) for few seconds and then come back. This happens while I drive. Initially I thought this is because of bad CD. But surprisingly the same issue happens while I am listening to FM. But the display works fine during this. I am really worried please help.
  • jais_seb Jul 18, 2009
    Thanks Guru for your suggestion. I will check that out. And yes it is true that I am getting this issue only while driving. I checked my car light while driving to see whether it is diming while my speaker sound goes mute but it doesnt
  • 341 Answers
I would check both of the power wires for the unit. There is a yellow one and a red one. The yellow one always has power regardless of the position of the ignition switch. The red one only gets power when the ignition switch is in the on position. Also does this only happen when the vehicle is in motion or does it happen just sitting and listening to the stereo? It also could possibly be the ground wire not getting a good connection. Make sure the ground wire is tightly connected to something that is metal. Good luck.
Posted on Jul 18, 2009
I have the Pioneer DEH-p7900bt and when i hook it up in my car the everything works except the screen, only the top third or so of the display screen lights up. but all everything else lights up. i dont...
I say it is the screen or face if you well mine did the same thing and it is cheaper to find one on ebay than to repair it. I checked one place out and they wanted like 60.00 well good luck and take care
Mar 18, 2011 | Pioneer DEH-P7900BT CD Player
Hola mi nombre es christian, yo tengo un pioneer DEH-P7900BT y cuando lo conecto solo prende las luces de los botones pero la pantalla no, no se si esta mal conectado o el stereo no cirva. por favor...
Esto no es una solucion, pero la misma cosa esta pasando a mi. Estava trabajando, pero en un momentito se cebro.
pienso que tu radio no cirva. La misma cosa esta pasando a otros dos personas en estos forums.
my espanol es muy mal.
Dec 08, 2009 | Pioneer DEH-P7900BT CD Player
Twice my Pioneed DEH-P7900BT has just stopped working. Keyboard went dark and the unit shut off. I pressed the button to open the face place and it opened and is stuck that way. It also didn't eject my CD...
This sounds like a wiring problem. Double check all of you connections. If the Connections look good then I would check the connections inside the radio. Check the power wire mostly. The wire could have a bad solder joint inside the radio itself.
Mar 02, 2009 | Pioneer DEH-P7900BT CD Player
How do you eject the damn cd out of the pioneer DEH-P7900BT
Your Manual
http://www.pioneerelectronics.com/pio/pe/images/portal/cit_11221/429287552DEHP7900BTOperationManual0328.pdf
will go over all the functions in detail.
3 EJECT button
Press to eject a CD from your built-in CD
player.
Press and hold to open or close the front
panel.
Bottom rightmost button.
Nov 11, 2008 | Pioneer DEH-P7900BT CD Player
DEH-P7900BT display issue
hey....alll you have to do is hold the "sourece" button until the unit shuts off, then push the wheel in until a menu shows on the display. scroll over until you see the "reverse mode" option...simply push either up/down or left/right to turn this off!!! NOW UR DONE!
Jan 12, 2008 | Pioneer DEH-P7900BT CD Player
Deh-p7900bt no sound
lol... i had the same problem...
there is a blue wire in the TRUCK ADAPTER HARNESS side.. thats the amp remote or turn on..
make sure to connect that to the blue or blue/white "remote" wire on the deck.. that should do it.. unless you fried the audio ic chip in the deck...
if you cant figure it out please dont rate me "unhelpful" thanks
Jan 05, 2008 | Pioneer DEH-P7900BT CD Player
Pionee DEH-P7900Bt
This may be a long shot but who knows... I am one of those that reads the manual after I have figured most things out. I had the same problem but it was due to the above :) When a call was coming in I was pushing the phone button on the receiver. After reading the manual I discovered that is the "ignore" button for incoming calls. To answer the call you simply push the multifunction knob.
Sep 15, 2007 | Pioneer DEH-P7900BT CD Player
Pioneer DEH-P7900BT CD Player Logo
240 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
