Question about Panasonic Car Audio & Video
What is the fused blue antena wire for on a car AM/FM CD Player ? I have a 32 Inch areial attached with a separate coaxel connection.
  • 221 Answers
The blue wire on an after-market radio is the power antenna wire, or sometimes called the "remote" wire. It's used to send a 12V current to a power antenna, which tells it when to go up and come down. If you have a fixed (non telescoping) antenna, this wire is not needed. This blue wire is also used as the remote turn-on lead for amplifiers, equalizers, and other add-on stereo equipment.
Posted on Jul 18, 2009
Am radio not working
If I remember correctly, FM and AM tuners are separate devices with separate antennas. Both devices are located in the trunk. Check antenna connections and fuses, then try with diagnostic tool and look for error codes.
Oct 09, 2014 | 2009 Volvo S80
Hey, I have a oldschool pioneer dc-z92 system with tuner, turntable and CD player. I am having trouble setting a tuner, There is just 1 antenna which is AM loop antenna ( I dont know what is it ) I...
It sounds to me like you only have the AM loop antenna installed (looks like a circle). This is used for receiving AM radio frequencies only. There should be a separate dipole antenna that attaches to terminals next to the AM terminals that looks like a long pair of wires for FM frequencies. Sometimes the connection is coaxial (circular with two connections, one connection inside the other) and sometimes it is two separate wire connections. I hope this helps.
Oct 07, 2017 | Car Audio & Video
On alpine cd3 9852 model, attached wiring for model of car and proper connections, yet subs only work for radio.subs will not work for CD or IPod connection.all wiring is color coated and has been checked...
Make sure you are using the blue/white wire to turn the amp on. The blue wire is antenna remote and turns off when leaving tuner mode. The blue/white wire is amp remote turn on.
Sep 15, 2011 | Alpine CDE-9852 CD Player
I'm putting panasonic cq-c1103u player into 2001 corolla using an adapter plug. I have all the wires connected from plug to player harness, but the is 2 wires left over from the plug, the blue power antena...
unless you have a power antenna or an external amp, all those are extra wires. just cap them off. the orange wire is only used if the radio has an illumination feature that allows dimming on the radio. it is not needed to see the radio. DO NOT connect the blue/white from the radio to the orange of the harness. whenever you turn the radio on it will send 12V to your cars illumination circuit. this could damage your lights, dash lights and maybe the radios output.
Apr 12, 2011 | Panasonic CQ-C1103U CD Player
No am/fm signal on my in dash clarion cd player
What you might want to do is check your antena. The inexpensive to way to check: Get a piece of wire about two feet long. Expose about an inch of wire. Remove the antena from the back of the radio. Use the above wire and insert into the antena port. Hang the reminder of the wire up so that it can receive a signal. If this works then you have a bad antena. If you have the same problem, the problem is internal and will probably have to be taken to a service location.
May 28, 2010 | Clarion XMD3-RET AM/FM MARINE CD PLAYER
I purchased a Pioneer Deh-1400 cd am fm player 2nd hand with no manual. Can anyone tell me the proper wiring connections? Only the power line is labeled.
remote turn on is blue with a white stripe and antena is blue 12+ is yellow acc is red ground is black left front is white with gray stripe right front is gray with black stripe green with black stripe is rear left and purple with black stripe is right rear
May 18, 2010 | Pioneer DEH-1400 CD Player
Antena Wiring in a 1997 Mercury Sable trying to connect an FM Mod
i call these units "fm trap " there has to be a hole in the units box that has the power , groud and turn on wireing coming froim it , its seperate , and is around the size of a pack of cigarettes ,thats where the cars antenna goes into and one comes out to the radio , hole may be smaller if its a newer unit , antenna pins are much thinner than the older ones
Nov 20, 2009 | Car Audio & Video
Marantz SR870 tuner not working
Make sure your FM antena connection is good. A receiver will not pick up an FM signal without an antena. Even a small piece of wire will work to test. If the Tuner section is bad, an external tuner can always be connected to an Aux input. Due to cost, it may not be cost effective to repair this unit.
Hope this helps.
Oct 08, 2009 | Marantz Audio Players & Recorders
Poor radio reception with Jensen VM9512 in 2001 Nissan Altima
If you used the 2 plug nissan radio harness, there should be a blue wire on there which is the (power antenna) even if your car doesn't have a power antenna, this wire needs to be connect to power on the am/fm amplified ant which is used in many nissan cars.
if the jensen has a blue or a blue/white wire, connect it to one of those. if not, you can always connect it to the red ACC wire. that should solve your reception problem..
hope this helps
Aug 25, 2009 | Audiovox VM9512 Car DVD Player
Car Audio & Video Logo
82 people viewed this question
Top Panasonic Car Audio & Video Experts
xxxxxx xxx
Are you a Panasonic Car Audio and Video Expert? Answer questions, earn points and help others
