Question about Dell Inspiron 6000 Notebook
Driver for cd/dvd
When i try to install dirver it still doesn't work
  • 1,463 Answers
Re: Driver for cd/dvd
Are you trying to install by cd? have you tried a download for the same cd
Posted on Nov 19, 2007
0 characters
3 Points
My DVD/CD-RW drive isn't recognized/ doesn't play disks.
It may be bad. Has the laptop been damaged? Dropped? Open Device Manager, DVD/CD Rom drives, is it listed? In Start Menu, Computer, Is it listed? Try re installing the DVD rom driver, the MS Vista 32bit drivers can be found here:
Feb 02, 2013 | Dell Vostro A860 Notebook
CD/DVD ROM Driver doesn't work.
update dvd firmwere of driver then try
May 19, 2012 | Apevia PC Laptops
My laptop (acer) doesn't play DVD movies or audio CDs what can I do to fix it?
Eject the DVD tray and clean the laser lens with a piece of cotton.
Enter to Setup Bios (Restart the PC and press " F2" key to entert BIOS setup and see if the DVD drive is show in device
In windows..go to control panel
devide manager and look if They are a yelolow mark bnear the DVD drive
Restart the PC.
If don´t work , may be the DVD drive is faiulre
Is important for people who share their knowledge, know your comments.
If the answer is helpful, rate my answers
Sep 21, 2011 | PC Laptops
goto run and type "compmgmt.msc"(without quotes) and select disc management if the dvd drive is showing below the hard disks means your dvd drive is working fine only thing you have to do is to right click on the CD-Rom 0 and change drive letter and paths to it
.if the CD ROM option is not seen in disk management then you have to go to the device manager option under computer management and expand cd/dvd -rom drives and you will find your dvd drive model if not that means that your dvd drive has got hardware problem
Aug 06, 2011 | Dell PC Laptops
Laptop is not detecting the CDs or DVDs
check your CD/DVD driver is properly installed. you can check it by going in control panel, Clean your CD/DVD drive by any Cd/DVD cleaner.
Jul 06, 2011 | Compaq PC Laptops
I lost my haier laptop audio dirver cd so i could get the audio after i installed the xp os
Running windows update should find the audio driver you need
If windows update doesn't find the driver, google the name of your laptop to find out which driver you need, then google the driver,
in future keep a backup of your drivers if you plan on reinstalling your Operating system
Jun 30, 2011 | PC Laptops
Dvd movies do not playback smoothly on my toshiba 1800 s274
format your laptop and install grfic dirver useing the laptop cd ..........and install recvier program and after working
Jun 22, 2009 | Toshiba Satellite 1800-S274...
Lan driver
try and find the "recovery" CDs, the second CD usually has all the drivers, where u can install the driver from it.
Jun 16, 2009 | Toshiba Satellite A15-S127 Notebook
DVD/CD Rom no longer reads cd or dvd - restore drive
Here's a Fixya:
How old is the notebook? There is 3 possibilities to get it fixed:
1. It might be the CD you're trying. Did you try another CD? or DVD to see if it does the same?
-If yes you might have the read/write head dirty and all you have to do is buy a lens cleaner follow the instructions and clean the drive. This is worth a try.
- If you are referring to CD's that you are BURNING with the same drive and the drive would not read it. Then most probably you did not get a brand of CD's / DVD's which are suitable for your drive. Check your drive's laptops manual to see the reccomended media.
2. Upon doing this check if you installed any software which might affect the drive. Such programs include. ASPI dirvers Daemon Tools copiers such as Nero and Alcohol 120% or others such as Clone CD. If so uninstall the offending program and reboot to see what happens. Sometimes even games might cause the problem.
3. Is the PC / Laptop old? As i did not have any details. And if it made any "funny noises" most probably its a hardware problem and it compromises reliability so if you tried all the above. You best bet is to check for a replacement drive. They do not cost much.
Hope that this Fixya helped you in any way.
Jan 05, 2009 | Toshiba Satellite A105 Notebook
Dell Inspiron 6000 Notebook Logo
20 people viewed this question
Top Dell PC Laptops Experts
Sudeep Chatterjee
Sudeep Chatterjee
Donna Sander
Are you a Dell PC Laptop Expert? Answer questions, earn points and help others
