Can you recommend new speakers and record player for a Sony LBT-D159 please? The record player never worked properly but the rest of the system is in good working order.
Would like better quality speakers and record player that are compatible with this system and will fit.
Generally that is a safety to protect the amplifier due to wires crossed and shorting. Start by disconnecting all of the speaker wires and see if that clears it. Then install each one at a time and test. Continue until one sets off the warning. Can be wire or a bad speaker.
Below is a link for the service manual! The cassette dismantle is on page 9. from what I see there is a plate that covers access to the belts, that is if Your lucky! the plate is shown in the first picture on page 9, sorry I have worked on other brands, and some of them You have to do a lot of dismantling to even get to belts! Hope this helps You! Regards! Sony HCD A295 HCD D550 LBT A295 LBT D550 Service Manual
I'm having a problem with my Sony LBT D307 it keeps power on for only 2-10 on then it goes off,then it leaves only time blinking,then you powe on it works,then off again???? Also I have brought new battaries for my remote but it's not working,
My audio in wont work when connected to my note note book pc,it worked fine about 2mons ago, ive even switched audio in cords and still nothing. Both my music on my pc and stereo wok seperatly but wont when connected HELP!!!
To isolate the source of the problem disconnect all speakers and turn on the unit, if it works that means that you have to check cables and speakers. If the problem remains that means the problem is with the unit.
Professional technician is required:
The problem is at the power output section (Defective out put IC or Voltage error?)
Good Luck
Toufic Malek
