Question about Lexmark X4270 All-In-One InkJet Printer
Lexmark 5650 all in one--can send fax but can't receive.. I hear the dial tone and everything. I do have an answering maching located in another room..it does not detect the fax signal...the answering machine is set at 4 rings and the fax at 6... Aletha Boggs
SOURCE: Can't send or receive fax Lexmark X5070
If you need the manual e mail me at
joepizza2@yahoo.com
Posted on Apr 21, 2008
  • 81 Answers
SOURCE: No dial tone detected
It may be a bad modem on the copier. Plug your phone into the auxillary phone port on the copier and see if you get a dial tone. Also make sure that your cord from the wall is plugged into the line port and not the phone port.
Posted on Jul 24, 2008
SOURCE: mx700 fax connection problems
I can not received fax from my mx 700 when why answering machine is on.
Posted on Nov 07, 2008
SOURCE: fax connection problems - no dial tone
are you sure the jack is working? the cord is ok, and plugged into the "line" port on your machine?
Posted on Mar 01, 2009
SOURCE: I can not send or recieve faxes. Ran fax test
you need to find a telephone with 2 conductors and not 4. I tried it and it worked. Cable phone service does not use VOIP it actually uses services similar to the telephone company. Instead of converting the analog signal of the phone somewhere down the street at the switch it converts it to digital at the cablemodem and sends it at different frequency on the cable. It then goes to the cable company and hooks into the regular telephone system.
Posted on Sep 05, 2009
HOW TO SEND A FAX
You can send a fax in a variety of ways. Using the control panel, you can send a black and white or color fax. You can also send a fax manually from an attached phone. This allows you to speak with the recipient before sending the fax.
To send a basic fax (single- or multiple-page black-and-white fax) by using the control panel.These features allow you to control the pace of your dialing. They are also useful when you want to use a calling card to charge the call and you have to respond to tone prompts while dialing. NOTE: If you need printed confirmation that your faxes were successfully sent, enable fax confirmation before sending any faxes. TIP: You can also send a fax manually from a phone or by using monitor dialing.
1. Load your originals. NOTE: If you are sending a multiple-page fax, you must load the originals in the document feeder tray. You cannot fax a multiple-page document from the glass. 2. Enter the fax number by using the keypad, press Speed Dial or a one-touch speed dial button to select a speed dial, or press Redial/Pause to redial the last number dialed.TIP: To add a pause in the fax number you are entering, press Redial/Pause, or press the Symbols (*) button repeatedly, until a dash (-) appears on the display. 3. Press START FAX Black or START FAX Color. • If the device detects an original loaded in the automatic document feeder, it sends the document to the number you entered. • If the device does not detect an original loaded in the automatic document feeder, the Fax from glass? prompt appears. Make sure your original is loaded print-side down on the glass, and then select Yes.TIP: If the recipient reports issues with the quality of the fax you sent, you can try changing the resolution or contrast of your fax.
Send a fax manually from a phone You can send a fax from a telephone on the same phone line if you prefer to use the keypad on your phone, instead of the keypad on the control panel of the device. You can do this by plugging in a phone into the 2-EXT port on the back of the device. When you send a fax manually, you can hear the dial tones, telephone prompts, or other sounds through the handset on your telephone. This makes it easy for you to use a calling card to send your fax. Depending on how the recipient has their fax machine set up, the recipient might answer the phone, or the fax machine might take the call. If a person answers the phone, you can speak with the recipient before sending the fax. If a fax machine answers the call, you can send the fax directly to the fax machine when you hear the fax tones from the receiving fax machine.
1. Load your originals. NOTE: This feature is not supported if you load your originals on the glass. You must load your originals in the document feeder tray. 2. Dial the number by using the keypad on the phone that is connected to the device. NOTE: Do not use the keypad on the control panel of the device when manually sending a fax. You must use the keypad on your phone to dial the recipient's number. 3. If the recipient answers the telephone, you can engage in a conversation before sending your fax. NOTE: If a fax machine answers the call, you will hear fax tones from the receiving fax machine. Proceed to the next step to transmit the fax. 4. When you are ready to send the fax, press START FAX Black or START FAX Color. NOTE: If prompted, select Send Fax, and then press START FAX Black or START FAX Color again. If you were speaking with the recipient before sending the fax, inform the recipient that they should press Start on their fax machine after they hear fax tones.
The telephone line is silent while the fax is transmitting. At this point, you can hang up the telephone. If you want to continue speaking with the recipient, remain on the line until the fax transmission is complete.
Send a fax using monitor dialing Monitor dialing allows you to dial a number from the control panel as you would dial a regular telephone. When you send a fax using monitor dialing, you can hear the dial tones, telephone prompts, or other sounds through the speakers on the device. This enables you to respond to prompts while dialing, as well as control the pace of your dialing. TIP: If you do not enter your calling card PIN fast enough, the device might start sending fax tones too soon and cause your PIN not to be recognized by the calling card service. If this is the case, you can create a speed dial entry to store the PIN for your calling card. NOTE: Make sure the volume is turned on, or you will not hear a dial tone. To send a fax using monitor dialing from the control panel
1. Load your originals. NOTE: If you are sending a multiple-page fax, you must load the originals print-side up in the document feeder tray. You cannot fax a multiple-page document from the glass. 2. Press START FAX Black or START FAX Color. • If the device detects an original loaded in the automatic document feeder, you will hear a dial tone. • If the device does not detect an original loaded in the automatic document feeder, the Fax from glass? prompt appears. Make sure that your original is loaded on the glass, and then select Yes. 3. When you hear the dial tone, enter the number by using the keypad on the control panel. 4. Follow any prompts that might occur. TIP: If you are using a calling card to send a fax and you have your calling card PIN stored as a speed dial, when prompted to enter your PIN, press Speed Dial or a one-touch speed dial button to select the speed dial entry where you have your PIN stored. Your fax is sent when the receiving fax machine answers.
Apr 01, 2011 | HP Officejet Pro L7680 All-In-One Printer
Cant install fax software for lexmark x5495 aio printer.
1. Unplug the printer from the PC
2. Uninstall all the software related to the All-in -One ( that is on the PC)
3. Connect the All-in-One again then follow the software instructions for reinstalling the printer.
From the instruction manual:
Sending a fax
Entering a fax number
1 From the control panel, press Fax Mode.
2 Enter a fax number using:
The text box Enter a fax number using the keypad.
Notes:
• You can include a calling card number as part of the fax number.
• Enter a maximum of 64 digits in a fax number.
• Press Pause / Redial to insert a three-second pause in a number you
are entering to wait for an outside line or get through an automated
answering system.
Speed Dial or Group Dial a Press Phone Book.
b Enter Speed Dial and/or Group Dial numbers.
• Press or repeatedly until the Speed Dial or Group Dial
number you want appears.
• Use the keypad to enter the number of the Speed Dial entry (1–
89) or Group Dial entry (90–99).
Notes:
• For instructions on how to add Speed Dial or Group Dial numbers
using the computer, see “Setting up Speed Dial” on page 118.
using the control panel, see “Using the Phone Book” on
page 108.
3 If you want to send a fax to a group of numbers (broadcast fax):
a Press .
b Repeat step 2, using any combination of the previous methods, until a maximum of 30 fax numbers have
been entered.
Sending a fax using the software
You can scan a document to the computer and then fax it to someone using the software.
1 Load an original document facedown in the Automatic Document Feeder (ADF).
2 From the desktop, double-click the Productivity Studio icon.
3 From the right pane of the Welcome Screen, click Fax.
4 Select the Document option.
5 Click Start.
6 Enter the recipient information, and then click Next.
Note: A fax number can include up to 64 numbers, commas, periods, spaces, and/or these symbols: * # + - ( ).
Faxing
103
7 Enter the cover page information, and then click Next.
8 If there are any additional documents that you want to send with your fax, add these now, and then click Next.
9 To send your fax:
• Immediately—Select the Send now option.
• At a scheduled time:
a Select the Delay sending until option.
b Set a time and date.
10 If you want a paper copy of your fax, select Print a copy of your fax.
11 Click Send.
Sending a fax using the control panel
1 Make sure the printer is on.
2 Load an original document facedown into the ADF or on the scanner glass.
Note: Do not load postcards, photos, small items, transparencies, photo paper, or thin media (such as magazine
clippings) into the ADF. Place these items on the scanner glass.
3 From the control panel, press Fax Mode.
4 Enter a fax number or press Phone Book to select a number from the Speed Dial or Group Dial list. For more
information, see “Entering a fax number” on page 103.
Note: To set up Speed Dial, see “Setting up Speed Dial” on page 118.
5 If you want to send a fax to a group of numbers (broadcast fax):
a Press .
b Repeat step 4 and press until a maximum of 30 fax numbers have been entered.
6 Press Start Color or Start Black.
Sending a fax while listening to a call (On Hook Dial)
The manual dialing feature lets you dial a telephone number while listening to the call through a speaker on the
printer. It is useful when you must navigate an automated answering system or enter a calling card number before
sending your fax.
2 Press .
3 Press or repeatedly until On Hook Dial appears, and then press . You can now hear the dial tone of
the telephone line.
4 Enter a fax number. For more information, see the related topic, “Entering a fax number.”
Note: Press the keypad numbers to use an automated answering system.
5 Press Start Color or Start Black.
Faxing
104
Sending a broadcast fax at a scheduled time
You can send a fax to a combination of up to 30 people or groups at a time you choose.
1 Load an original document facedown into the ADF or on the scanner glass.
2 From the control panel, press Fax Mode.
3 Press .
4 Press or repeatedly until Delay Fax appears.
5 Press .
6 Press or repeatedly until Delay Until appears.
7 Press .
8 Enter the time you want to send the fax.
9 Press .
10 If the printer is not set to the 24 hour mode, press or repeatedly to select AM or PM.
11 Press to save your settings.
12 Enter a fax number, or press Phone Book to select a number from the Speed Dial or Group Dial list. For more
13 If needed, repeat step 12 and press until a maximum of 30 fax numbers have been entered.
14 Press Start Color or Start Black.
Note: At the designated time, the fax numbers are dialed and the fax is sent to all of the designated fax numbers. If
the fax transmission is unsuccessful to any of the numbers on the broadcast list, the unsuccessful numbers will be
dialed again.
Receiving a fax
Receiving a fax manually
1 Make sure the Auto Answer light is off.
2 To receive the fax if you have not set up a manual answer code:
• Press Start Color or Start Black.
or
• Press * 9 * on the telephone after you answer it and hear fax tones.
3 To receive a fax if you have set up a manual answer code, enter the code on the telephone after you answer it
and hear fax tones.
Note: For information on how to set up a manual answer code, see the related topic, “Setting a fax manual answer
code.”
4 Hang up the telephone. The printer receives the fax.
Faxing
105
Apr 15, 2010 | Lexmark X5495 All-in-One &USB...
Can not receive or send fax. When I send a fax, it says no answer, when I try to receive a fax, the other side hear it was ringing on and on, but they did not get the receiving signal.
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.hp.com/printer/prob676ijt65/solution
aswq22
Aug 18, 2009 | HP Officejet 5610 All-In-One InkJet...
Cant send a fax
Confirm dialing the correct fax number?
Any 0s to get an outside line, any special area codes?
What happens when you try to send a fax, can you hear a dial tone? can you hear the fax ringing? can you hear a response from the recipiant?
Jul 17, 2009 | Lexmark F4270 Plain Paper Inkjet Fax
I am unable to send fax, I get a 'phone line error' message. The phone line is fine, I checked it by pluging a seperate phone into it. When I go to 'On Hook Dial' I do not get a dial tone on the fax...
Please check the dial tone by following the instructions given below:
1. Press "Fax Mode."
2. Press "Menu."
3. Press "Up Arrow" or "Down Arrow" repeatedly until On Hook dial is highlighted.
4. Press "Select" twice.
You can now hear the dial tone of the telephone line.
5. Enter the number to which you want to send a fax.
6. Press "Start Black."
Mar 29, 2009 | Lexmark X8350 Print, Scan, Copy and Fax...
Problems sending and receiving faxes.
  1. Open Lexmak Productiviti studio - 5600 - 6000 Series ( icon on Desktop)
  2. Open Setup and manage faxes link ( left bottom corner)
  3. On Ringing and Answering card look at the Manual Answer Code ( if some nuber inside delete it, it should be blank)
  4. On Dialing and sending card look at the Dial method (if you have a tone phone select Touch - tone, and if you have pulse phone select Pulse)
The diference betwen Touche Tone and Pulse is that Tone when you press nuber hear tone (like on cell phone), and Pulse when you dial nuber hear serie of short pulses (like when you dial nuber 5 you hear 5 short pulses like tttttt)
Mar 24, 2009 | Lexmark X5650 All-in-One InkJet Printer
Recieveing
If all else fails try the manual mode:(Press Receive Mode to select
FAX ONLY, FAX/TEL,TAD:ANSWER MACH. orMANUAL.)
Manual Reception
Pick up the handset while the phone is ringing.
2 Press Fax Start if you hear fax tones (beeps).
3 When the LCD shows RECEIVING, replace the handset.
(best used when you are expecting a fax and know that the incoming call is a fax)
If you are like most people you probably also have a phone with an answering machine or voicemail setup on your home phone. If this is the case you may want to set the reception made to
TAD:ANSWER MACH.
May 28, 2008 | Brother IntelliFAX 2800 Laser Fax
Lexmark 7350 all in one
Before you begin
To pinpoint the cause of the issue, please record answers to the following questions:
Can a fax be sent or received?
Can a fax be sent, but not received?
Has the fax function ever worked in the past?
Any error messages may also help to narrow down the cause of the issues.
Print out the following:
- a settings list to view the current fax settings
- a receive log if there are issues receiving faxes
- a send log if there are issues sending faxes
- an activity log if faxes cannot be sent or received.
Initial checks
If the fax option has worked in the past and does not do so now, check that the same connection is being used and that it still works.
Check to see if any configuration settings have been changed that could have affected the fax settings.
Faxes cannot be sent/received:
If you are using a digital line, you need an analog card, an ISDN adapter, or an ADSL filter in order to send faxes.
If a PBX is being used, an ISDN Adapter/ADSL filter will not be used as these are supplied within the system. (A PBX is normally used within a company to share a small number of public lines among a large number of private ones to save on cost.) For instructions on configuring the X6100 Series machine with a PBX, see How and When to Use the PBX Option.
Check the phone line (without the printer):
Test the line by connecting a phone directly into the phone port.
Check for a dialing tone.
If you cannot hear a dialing tone, try another phone cable. Once you can hear a dialing tone, you know that the phone port is live and working.
Make sure the RJ11 cable is not damaged.
Check that the printer is accessing the dialing tone correctly:
Press the Options button on the operator panel five times until ON HOOK DIAL is displayed.
Press Select. You should hear a dialing tone.
If you can't hear a dial tone, make sure that the speaker volume is set to High. (Go to Fax, press Options eight times until SPEAKER VOLUME is displayed, then use the plus or minus buttons to change the setting to HIGH. Press Select.)
If there is still no dial tone, unplug the power cable and the phone lead, then plug them back in and try again.
Faxes can be sent but not received:
Connect the Lexmark All-in-One directly to the phone port. IMPORTANT: Do NOT connect any phones to the EXT port.
Make sure the Fax receive mode is set to answer the fax after 3 rings. (Press the Fax button on the operator panel and then press Options three times until ANSWER FAX WHEN is displayed. Change the settings using the - or + buttons as appropriate.)
Faxes can be received but not sent:
Make sure that Country Code is set correctly:
Press the Fax button on the operator panel and then press Options 15 times until Advanced is displayed.
Press Select.
Press Options 13 times and then press the + or - button until the right country is displayed.
Press Select.
IMPORTANT! These tests must be carried out with NO EXTENSIONS, i.e. phones or answering machines, connected to the EXT port on the All-In-One.
Feb 15, 2008 | Lexmark X8350 Print, Scan, Copy and Fax...
Can't receive incoming faxes!
It sounds like maybe the printer is not picking up the incoming call. Check to see that the printer is the first thing connected to the phone jack. If you have DSL you will need to plug the printer into the "phone" side of the DSL filters that you have on all your phone jacks.
If you have an answering machine it should be plugged into the printer's phone jack - not the other way around. The printer is smart enough to pick up fax calls and pass voice calls on to the answering machine if you get it hooked up right. Check the user's guide for more specifics.
Oct 15, 2007 | Lexmark X5470 All-In-One InkJet Printer
Lexmark X4270 All-In-One InkJet Printer Logo
186 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
