I have a weatherking model number waka-037jaz just bought this with a payne furnace from a gentelman who said they worked together when he removed them but furnace doesn't have an A coil in it how do u connect the two
  • 614 Answers
The furnace can handle three tons of AC but you will need a coil and a line set to connect the two. Get a match coil for your furnace and a line set. 7/8 and 3/8 plus tstat wire and tstat. Sometimes you get stuck buying used equipment and it cost you more in the long run. I have owned a company for 44 years and I never never sell used equipment.... If you need help write back I will be glad to help you. RUSS
Posted on Jul 18, 2009
Ever limit switch i changed in my Weatherking furnace, it breaks the switch, what could cause this?
You need the model number of the furnace to determine what the flashing light is telling you. Many times the part that looks to be at fault is not the true fault in the furnace. A slow running blower could cause the limit switch to trip. The circuit board tells you that the limit tripped, but the real cause is the motor or clogged filter.
Jan 02, 2016 | FACTORY AC PARTS Limit Switch Double Pole...
HOW MUCH IS A WAKA-037JAZ RETAIL FOR
Hi Phil,
Go to an online store, that's probably where you are going to find it cheaper. Here is a link:
Good Luck,
JP
All Categories
Jun 28, 2015 | Heating & Cooling
I have a Ruud UAKA-037JAZ central heat and air unit (Silhouette 11 gas furnace). When I turn the thermostat to heat the heat does not come on. I removed the front panel and there are 2 green lights lit up...
Need furnace model number. It sounds like you're looking for a standing pilot. Your furnace might not have one. Very likely to have a spark ignition type system or hot surface igniter.
Feb 01, 2018 | Ruud UAKA037 Air Conditioner
What size ac ?
The condenser is 2 ton or 24 thousand btus.
Mar 08, 2010 | Heating & Cooling
I HAVE A WEATHERKING MODLE WAKA-037JAZ OUTSIDE AC UNIT WITH SPLIT GAS FURNACE-WHAT TON IS THIS UNIT
It appears you may have a 5ton unit, if your house is over
2000sq. feet then Im guessing that 60 thats appears in
the model number is equal to 5ton. 12,000 btus per ton
of cooling
Feb 28, 2010 | Weather King 10AJA6001AH Air Conditioner
Finding the cooling contactor on weatherking acclaim II gas furna
the "y" terminal sends the hot leg of the 24 volts and the "c" terminal sends the common leg to the condenser..
Nov 15, 2008 | Weather King Heating & Cooling
Warranty on compressor
The actual age of your unit can be determined by the serial number. Based on the age indicated there they can tell you if the warranty is still valid. Your local Rheem/weather king dealer can do this for you. Most compressor warranties are either 5 or 10 years. Good Luck!
Jun 11, 2008 | Weather King 10AJA2501AH Air Conditioner
Heating & Cooling Logo
392 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
