Question about LG LRSC26910 Side by Side Refrigerator
Icemaker makes too few cubes
I have an LG refrigerator, but mine is a french drawer model with bottom drawer freezer. I have noticed that in each "batch," the icemaker makes significantly fewer cubes than the number of cavities that are in the icemaker. The cube size, however, is absolutely correct, and can be adjusted with a little electronic setting on the front of the icemaker.
So what I want to know is this: how are the little cavities that make each cube connected? It seems like water just doesn't flow fast enough from one cube cavity to the next, so the tray-filling switch cuts the water pressure off before the further-away cubes have time to fill up? But that doesn't make sense either, because then I would have eight very-tiny cubes, as water would eventually seep to other cavities before freezing. Instead, I have a few plump, full-size cubes, but definitely not the full capacity of the icemaker.
    Champion:
  • 363 Answers
Find the water source for the ice maker(most are under the kitchen sink and are tapped off of the cold water line to the faucets) You need to either shut off the tap by turning it clockwise until it is closed. Then you need to disconnect the vinyl tubing from the valve. get a bucket and place it where it will catch the water from the tap. Gradually open the tap by turning it counterclockwise until water starts to come out of the valve. If you have a large enough bucket open the valve all of the way. If the stream of water does not change then the valve is bad and needs replacing. If the stream is nice and strong then the valve is ok. Turn the valve clockwise to close it, reattach the vinyl tubing and open the vale all of the way. This should improve the quanity of ice cubes. If not then there is a cripmp in the vinyl line between the tap and the solinoid valve on the back of the refrigerator.
Posted on Jul 18, 2009
Lg icemaker stuck
You have an overflow of ice building up in the reservoir. Turn off the maker and use the contents until 3/4 are used up. Turn on again and stop when near full. Check to see if the LEVEL of the refrigerator is correct. The BOX may be tilted forward and an adjustment made.
Feb 26, 2014 | Refrigerators
How do you change the ice cube setting on the 25cf LG French Door bottom freezer? I cannot see anywere in the manual where it indicates where you change this setting?!
The icemaker requires a water pressure of 1.5 - 8.5kgf/cm2. It is acceptable if the water supply fills a cup of 180cc with water in 3 seconds. The icemaker produces small cubes if the water fed into it is not enough and lumped together if too much water is supplied. In order to obtain the desired size of ice cubes, the amount of water supplied to the ice maker needs to be adjusted. Adjust the valve supplying water to the icemaker or the unit in general in such a way that right amount of water fills the ice tray.
Nov 05, 2009 | LG LFX25960 Bottom Freezer French Door...
Maytag MFD2560HES - water flow restricted - noisy fridge
The flow of water is controlled by a solenoid. Thus magnetic -- rather electromagnet which mones the vale from open & close, both in the ice-maker & the water dispenser.
Thus the valve which is activated when door closes, must have lost its earlier condition and must be making an irritable buzz whenever its on. Simply get the Valve assembly replaced, preferably from their authorized service center closest to your place of residence.
Sep 25, 2009 | Maytag MFD2560HES Bottom Freezer French...
LG French Door Model LFX 25960--Freezing in right crisper door
Have person who changed out you controlboard come back and recheck connections and controlboard itself.
Jul 26, 2009 | LG LRFD22850 Bottom Freezer Refrigerator...
I've got the LFX25960ST model. The icemaker
its the ice maker .water or condensation has built up in the ice maker modual and refroze upon turning unit back on.either get a new ice maker or uninstall the ice maker and let it dry for a few days and reinstall.but it could happen again that way.or maybe not.
Jul 24, 2009 | LG LFX25960 Bottom Freezer French Door...
My french door with freezer at bottom ,LG icemaker making very little ice.
Perhaps there is not enough water coming into the tray on each cycle? Are the ice-cubes very thin? If so timer needs to be reset. LG use a 3-switch DIP on a control panel near the main power board. By changing these switches to various combinations of on/off you can change the timing - longer means more water each time (but too much water means overflow into the blocks already made).
There are service manuals that explain what each setting does - but because its near the high-voltage power board, I'd suggest you get a repairman unless you are a good DIY'er
May 12, 2009 | LG LRFD22850 Bottom Freezer Refrigerator...
Bottom freezer door/drawer won't close all the way on one side.
Remove all the food from the freezer and then the drawer from the cabinet. Now using a silicone based lubricant, lube the tracks up real well. Be sure to clean the tracks first if gunked up. Make sure nothing small fell out of the basket over time and is laying on the floor in the rear of the freezer section. Once done, you should be fine.
Eric Campion
Feb 21, 2009 | LG LRFD25850 French Door Refrigerator
Icemaker problem GE profile energy star 22.2 bottom freeser french door top
are you on a well system? it could possibly be a pressure issue with the water system not dilling all the way. stuck cubes will break icemakers.
Mar 30, 2008 | GE Energy Star PDS22SIS Stainless Steel...
Ice maker tray
There is a fix for this problem.  Call a qualified LG tech to order the updated metal bar for this icemaker.
Feb 02, 2008 | LG LFC25760ST 25 Cu. Ft. Panorama French...
Ice maker not making cubes
You may have ice built up in icemaker where the water goes into it.  You will have to remove the icemaker and to get the ice cleared out.  Once that's done, you should be ok.
Jan 13, 2008 | LG LRFD22850 Bottom Freezer Refrigerator...
LG LRSC26910 Side by Side Refrigerator Logo
531 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
christian nielsen
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
