Question about Panasonic Lumix DMC-FX33A Digital Camera
Reset factory settings panasonic dmc fx33
My camera is stuck in zoom mode and the pictures come out at 4x . My kids did something with the settings - how do I reset the factory settings on zoom?
5 Suggested Answers
SOURCE: burst mode on Panasonic Lumix dmc-fx50
I have, after sifting through the 144-page manual, figured out what the problem is! At some point you must have set the "Auto-Bracket" setting to on - I did the same thing! To turn this off, put it in any of the Scene or Manual Exposure modes, then press the up (↑) key until "Auto-Bracket" comes up. Then, using the left or right (←,→) keys, set it to Zero (0). This should hopefully solve your problem! :)
Posted on Sep 19, 2008
SAFFOTO
  • 77 Answers
SOURCE: The flash on my Panasonic Lumix DMC-FX33 is not
You camera may be in 'auto'flash' mode, meaning the camera decides if the flash is necessary, depending on the lighting situatioin. Try your flash setting on forced flash instead of automatic, or try it in the dark to see if the flash goes off.
Posted on Jun 15, 2009
  • 11967 Answers
SOURCE: Lumix DMC-FX01 Buttons not working
Remove the card and battery. Clean the battery contacts inside camera with a cotton swab lightly dampened with rubbing alcohol. Be sure battery is charged. Press all buttons on camera. Insert card and then the battery. See if it works. If you can now get into the setup menu, you can do a reset from the menu.
Posted on Aug 23, 2009
  • 24 Answers
SOURCE: how do I reset my Panasonic DMC-FX35 to facoty
you'r menu should have a reset setting, there are 2 menu's 1 when you'r ready to take a picture & 1 when you'r viewing you taken pictures
Posted on Jan 14, 2010
Flash is not working
Are you sure you turned it on in the camera settings? Try checking the user manual for information on how to turn on flash:
Panasonic DMC FX33 manual
Feb 11, 2014 | Panasonic DMC-FX33 Silver Digital Camera
Flash not working on DMC fx33
Are you sure you enabled flash through the options? Check the user manual for any setting related to flash before considering having the camera serviced:
Feb 10, 2014 | Panasonic DMC-FX33 Silver Digital Camera
Settings for average photos
Set the camera to either the automatic or simple modes. See pages 22 and 24 of the manual.
Sep 02, 2012 | Panasonic Lumix Dmc-fs12 black 12.1mp 4x...
Lumix DMC-FX33. Keep on getting "Please turn camera off and then on again" over and over again. Occasionally I can focus and take a picture and the camera works for a day or two. Then the problem...
I have the same problem. It resulted when we used the camera is windy conditions with very fine sand blowing around. Some of those grains are lodged in the automatic lens cover and in the autofocus/zoom mechanism in the lens. I can actually hear the grinding as the camera tries to open.
Now, how do I fix it?
May 06, 2010 | Panasonic Lumix DMC-TZ3 Digital Camera
Lumix DMC-FX33 turns itself off
The message appears when force has been applied to the lens. You will probably need service.
Aug 13, 2009 | Panasonic DMC-FX33 Silver Digital Camera
My FZ18 will not zoom. Stuck at wide angle. A msg will sometimes flash when first turned on...CAMERA WILL RETURN TO PREVIOUS ZOOM SETTING...or something like that. It functions otherwise. I have been thru...
Set camera to P mode.
Press [MENU ] to display the [SETUP] menu
and select the item to set.
The [REC], [CUST. SET MEM.] or [SETUP]
menu settings are reset to the initial
settings.
• [FAVORITE] (P98) is fixed to [OFF] and
[ROTATE DISP.] (P97) is fixed to [ON].
• If the [SETUP] menu settings are reset,
the following settings are also reset.
See page 22 in manual.
http://www2.panasonic.com/consumer-electronics/support/Cameras-Camcorders/Digital-Cameras/Lumix-Digital-Cameras/model.DMC-FZ18K
This should reset whole camera to factory setting.
Cheers.
Jul 08, 2009 | Panasonic Lumix DMC-FZ18K Digital Camera
CAMERA UNIT IS PANASONIC LUMIX DMC-FX33 MENU
It may be that for the type of picture you are taking the mode - dial at the top of the camera is not compatible.
Try a couple of different modes by adjusting the dial to auto, etc.
Apr 22, 2009 | Panasonic Lumix DMC-FX33A Digital Camera
Zoom and shutter not functioning
that is a symptom of being dropped and stuck in a mode.
it requires total dissemble of the camera to fix or replace the lens. your lucky it takes pictures at all. most cameras refuse if the lens is stuck.
Jul 28, 2006 | Panasonic Lumix DMC-LC33 Digital Camera
Panasonic Lumix DMC-FX33A Digital Camera Logo
881 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
