Unit shuts down upon temporary loss of power
We have a Carrier Infinity, installed less than a year ago. EVERY time the power goes out, the unit shuts down for hours, sometimes a whole day. The display says ''system malfunction.'' The error code is usually ''contactor short.'' Yesterday it was ''high pressure switch open.'' The contactor has been replaced twice, although it probably wasn't necessary either time, because by the time the tech got here, the unit was functioning again. He replaced it anyway, because of the error message, which seems logical, even though the unit was then fine. Today we had another thunderstorm and the power went out for a few seconds. The Carrier service rep told us this morning NOT to flip the circuit breaker, just to leave it, as to avoid a lockout. After waiting 4 hours, we decided to flip the circuit breaker anyway, since in the past, that is the only thing that seemed to reset the system. We left the power to the unit off for about an hour, and when we flipped the circuit back on, the error message was gone AND the unit came back on! Two techs have been out MANY times and can not duplicate any issue. If we just leave the system on when the power goes out, the fan stays on. The air is warm of course, so we end up turning the system off. After we wait a while, we end up flipping the circuit breaker. The system then runs beautifully (after a 3 or 4 hour wait), until we have another thunderstorm. So, we have tried just leaving it and waiting for it to reset on its own, and we have tried to ''force'' a reset by flipping the breaker. I do not think it is a contactor, unless it is possible that we need a stronger one, as one tech recommended. IS THERE AN INTERNAL LOCKOUT (other than the keypad lockout)? IF SO, HOW DO YOU RESET IT and WHAT WOULD CAUSE THE SYSTEM NOT TO RECOVER WHEN THE POWER FAILS FOR A FEW SECONDS? Isn't a properly running unit designed to withstand a BRIEF power outage? We have a surge protector from our utility company on our main line. Could this create a problem? The utility company engineer says not. Could this be a software issue with the Infinity controller? All settings appear to be correct on the control panel. Any help is greatly appreciated!
  • amandastonen Jul 19, 2009
    Thanks. That was the first thing they did...controller was replaced with a new one a couple months ago. It did not do the trick.
    Problem Solver:
  • 9 Answers
Its time to shake a local rep and ask for an exchange on that controller. If they want to sale us on customer service then make them eliminate that as a possibility an exchange it for free.
Posted on Jul 18, 2009
Can I fix my Carrier Heat Recovery Ventilator HRV?
Check to see if the thermostat is set for blower .if thermostat is off unit would not do anything
Jun 01, 2017 | Carrier Heating & Cooling
I have a 17 kW kohler generator. When the power goes out it comes on fine. When the power comes back on the transfer switch transfers back to utility power but the generator never shuts off. I have let it...
if unit is over 8 years old it has a mechanicial timer for the Cool down run time (after power comes on) these go bad from believe it not "Rust" the timer will need to be replaced with a new model , that most likely will be an electronic timer replacement , now if unit is less than 8 years old . and this is a new install then verify that ,Sense connection on terminal strip on ckt board is connected to land power
Dec 13, 2014 | Kohler Electrical Supplies
Furnace stops before house warms up
This could be due to a fault in the temperature limit switch
Jan 26, 2013 | Gibson Tappan Frigidaire Furnace Control...
Powers off immediately after starting
My immediate reaction would be to cut your losses and buy a new unit as sooner or later you will run into a part that is no longer available.
Nov 03, 2012 | Whirlpool Microwave Ovens
Carrier infinity control SYSTXCCUID01-B sensor communication erro
There should be a little black sensor bulb outside either on the unit normally under the electrical panel or inside it. It sound like the wire has come off or been disconected. It needs that on to properly run. Your control is trying to communicate with the outdoor unit and can not.
Jul 07, 2009 | Heating & Cooling
Generac 4456 does not start on power loss
I install and work on these everyday. If you hooked up the transfer switch you probable have a control wire wrong. check the utility power sense wire. That lets it no when to start in auto. it could be a relay or fuses. or a control board.
Jul 01, 2009 | Generac Guardian 200 Amp Transfer Switch...
System Malfunction, No communication with outside unit
I work on Carrier Infiity systems. The outside board has a Model plug on it. This tells the system what size unit it is. They do go bad. You can reset your self by turning the power off to the Air Handler. These system have 10 year warranty and if you still have a problem have the replace the outside control board and model plug. Also you can contact Carrier on the their website and get answers. You may need to talk to a service rep in your area. Carrier is good about their Tech support. You should have to pay for a service call if you your problem continues. Sometimes power surges or stoem cause these problems but not often Rusty
Apr 26, 2009 | Heating & Cooling
Total power loss during use
Check the voltage on the outlet,make sure it is 115v -- 122volts max, any less will cause it shut off, make sure the polarity off the outlet is correct and it is grounded,check all of your wiring connections, if all this is ok replace unit with a different unit or different supplier of unit
Jan 26, 2009 | Microwave Ovens
Carrier Air Conditioner Infinity System - Air Handler Sweating & Duct Work Condensation
Either its not drainning mositure properly or low air flow across the "A" coils- caused by dirty filter .
Sep 12, 2008 | Heating & Cooling
Carrier Infinity DC motor drive problems
Contact the company that installed the unit. Its new, under warranty, Anything you do could void the warranty. If they do not take care of the problem without charges contact Carrier and tell them what's going on. The company who installed the unit is responsible for making it run correctly. Good luck. kstfas
Aug 26, 2007 | Carrier 38CKC036 Air Conditioner
Heating & Cooling Logo
253 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
