Dead engine,
do head lamps work?
on a dead car, dead engine, all power comes from the main car battery. and all power feeds are fused.
if fuses blow, no power to that feed.
if the battery is dead so will be the head lamps and hand lamps
do not take a key top work (a safety feature)
this car is toyota corolla. (with geo stickers)
how do you know power is missing from F10?
you used a voltmeter there? or test lamp? how>?
there were 2 engines, 4A and 7AFE engines.
ill guess and answer for 4AFE engine
Fuse 10 is not a number its the current rating of the fuse.
and is maked (you didnt show a photo of fuse, nor where it is)
is marked IGN
now ill answer with the schematic. (makes it 10x more easy)
now power feeds IGN fuse, from the key switch
if that switch works the power come to it from
AM2 fuse
If AM2 is dead then the battery is dead. or
the battery ground is bad.
or the battery lugs are rusty
or the battery is only discharged, so charge it.
or jumper cable start car like you see the AAA tow truck man do.
SOURCE: fuse under steering colum
open drivers side door and look at the end of the dash should be a vertical access for fuse panel
SOURCE: how can i obtain the diagram for the fuse box located just underneath the steering column?
If you copy and paste this to your desktop you can zoom in on it.
SOURCE: Where is the turn signal flasher located on a 1995
On the fuse block with the other fuses below the dash
SOURCE: 2001 Chevy Tahoe, Heated seat back works but not seat bottom.
Open drivers side door and look at the end of your dash board that is faceing the door.You will see a little triangle shaped door that pops out.There are also more under the hood,drivers side in a big square box.Behind the batterie.
SOURCE: Problem; Where is the fuel pump relay on a 1995
You may have a late 95 early 96 which moved the fuelpump relay under the dash inside glovebox.
Testimonial: "Perfect soltion! Good job!"
