Question about Sharp Heating & Cooling
Air conditioner is flashing e1 - Sharp Heating & Cooling
  • Sophie Berry Jul 18, 2013
    i did this but machine goes back to bleeping when i plug it back in. Am I supposed to empty it?
  • 744 Answers
Hi..
1. Power down the air conditioner using the "power" button on the front
panel.
2. Unplug the air conditioner from the wall socket.
3. Hold the front panel "power" button down and plug the air
conditioner in. Continue to hold the power button down as the machine
goes through a brief test sequence (fan & compressor each come on
briefly, etc). There is a "beep" sound at the end of the test sequence,
and the machine will be off. At this point, you can release the power
button.
4. Unplug the air conditioner.
5. Plug the air conditioner back in.
thank u
rate me
Posted on Jul 18, 2009
What does E1 code indicate?
Your Air Conditioner Displays E1 (E2, or E3) In The Display ...
support-us.samsung.com/.../pop_troubleshooting_fr...
Samsung ElectronicsJul 8, 2010 - Home > Operation? > Your Air Conditioner Displays E1 (E2, or E3) In The Display Panel And Won't Turn On Share on Google+ Share on ...
How To Clear Sharp Air Conditioner E1 "Clean Filter" Error ...
sci.tech-archive.net > Archive > sci.electronics.repair > 2005-08
Aug 5, 2005 - Owners of Sharp air conditioner models ... the error code E1 will appear... following procedure to clear the nefarious E1 indication, and obtain
Oct 27, 2015 | Heating & Cooling
Everytime i turn my air on it flashes a code E1 and i was wondering what that code meant???? please help its hot out lol
E1-Automatic filter clean reminder.
Turn the air conditioner OFF and unplug it. NOTE: The air conditioner must be unplugged for the automatic filter clean timer to reset.
Clean the filter. See the Care and Cleaning section in your use&care manual. After cleaning, replace the filter and plug the air conditioner back in.
Aug 07, 2011 | Amana Heating & Cooling
Turning off code e1 flashing what is e1 code
Jul 28, 2011 | Sharp Comfort Touch AF-R120EX Air...
Ac shuts off E1 error message
E1 Error Code -->> Clean Filter
Owners of Sharp air conditioner models AF-S60FX, AF-S80FX, AF-S85FX, and AF-R80FX may experience the following (highly annoying) issue. After 720 hours of fan operation, the error code E1 will appear on the seven segment LED temperature display. This error code is intended as a reminder for the user to clean the air filter. However, because the procedure outlined in the user manual does not clear this error code as indicated, and the appliance has a nonvolatile memory that cannot be reset by simply unplugging it, the user of the appliance will become mightily frustrated, standing in potentially sweltering heat watching the appliance repeatedly shut down in the midst of operation with the "E1" display flashing.
Believe it or not, that is what it does: if you unplug it to remove the "E1" code from the display, and plug it back in and re-start it, it will simply run for anywhere from a few minutes to a few hours, and then merrily shut down again with the same flashing "E1" code.
Many people at this point, having put the manual under the canary or some such, will simply return the unit and never buy another Sharp air conditioner. But for the tech-savvy and search-adept, I offer the following procedure to clear the nefarious E1 indication, and obtain another 720 hours of cooling bliss:
1. Power down the air conditioner using the "power" button on the front panel.
3. Hold the front panel "power" button down and plug the air conditioner in. Continue to hold the power button down as the machine goes through a brief test sequence (fan & compressor each come on briefly, etc). There is a "beep" sound at the end of the test sequence, and the machine will be off. At this point, you can release the power button.
6. Congratulations! You should now be able to operate the air conditioner normally for another 720 hours, but only if you followed the instructions above exactly.
If you doubt the veracity of this information, or it does not work as expected, you can get it directly from the source at: 1-800-237-4277 (Sharp customer service line). You'll need to call between 7 AM and 7 PM US Central time, and have your model number and serial number ready.
May 28, 2011 | Sharp AF-S120FX Air Conditioner
E1 ERRORE COMES IN M Y AC WHICH REASONS
So you will come home to a hot bedroom, living room, etc. unexpectedly,
and you will NOT be amused, as I was not.
panel.
button.
the instructions above EXACTLY.
  • Date: 5 Aug 2005 06:33:46 -0700
How To Clear Sharp Air Conditioner E1 "Clean Filter" Error Code
http://sci.tech-archive.net/Archive/sci.electronics.repair/2005-08/msg00472.html
Mar 01, 2011 | Heating & Cooling
What does E1 flashing on display mean? The air conditioner comes on for 10 mins. and then flashes E1 in the display. I have cleaned filter b lown out grill and still no results.
if its a sharp ac ... it will need to be reset..
1) hold down the on/off button keep it held down and plug in the ac ..you should hear a beep...
2) hold down the mode button keep it held down and plug in the ac ..you should hear a beep...
one of two ways will reset the e1 error hope it helps..
Sep 19, 2009 | Heating & Cooling
Carrier Comfort zone 2 is flashing e1 after a storm/power outage
HEY THERE, DID YOU TRY POER CYCLING THE UNIT? TURN IT OFF AT THE BREAKER THEN BACK ON
SETH
Jun 27, 2009 | Carrier 38CKC060 Air Conditioner
E1 code flashing on my air conditioner
E1 indicates that it is time to clean the air
filter hope it helps
Jul 26, 2008 | Danby DAC8003D Air Conditioner
Unit stops working - E1
I wrote the solution #1 and have an additional comment. This really does work!! I fixed my neighbor's AC unit by following the instructions for clearing the E1 code. The unit will not operate until the code is cleared. The page is titled: Customer assistance for air filters cleaning (E1 code) on Sharp Air Conditioners
Aug 25, 2007 | Sharp AF-S80FX Air Conditioner
Heating & Cooling Logo
593 people viewed this question
Top Sharp Heating & Cooling Experts
Oloyede Monsuru
AJMAL KHAN
Tim Whalen
Are you a Sharp Heating and Cooling Expert? Answer questions, earn points and help others
