I am upgrading the memory in a toshiba m55-329 satellite.If I install the I gig sticks in the laptop it will not boot up.If I remove them and install the original 521 gb stick it boots fine.If the 1 gb sticks in any combination it won't boot.Only with the 512.I spoke to cruical and we double checked the new memory and they are the correct ones.I doubt both sticks would be bad.I read youre suppose to let toshiba install memory on this computer..is there a trick or what?
  • dswimdude Jul 18, 2009
    I will give this a try,i spoke to them several times today an the assure me they are the correct ones.Iwill be very upset with them if these aren't the correct ones, I have the ddr-pc2700 now which is what every site I looked them up on recommended.You think it could be this simple?
    I just hope this is the solution if its not do I have to pay another if $11.00 if I ask you what next?
I did the same thing with my Dell laptop and when I installed the new memory sticks in it did not boot...I would say the memory you received from Crucial is not compatible with your system...I looked on the Cruical website and the M55 models use one or the other memory, either the DDR PC2700 or the DDR2 PC2-5300 memory sticks.....Both options allow for a 2GB maximum memory upgrade..I would send it back and exchange it for the correct ones.
Posted on Jul 18, 2009
M9 wont see more memory installed
ok remove on stick of memory from the new installed memory
restart computer and check how much is there
what you are seeing sometimes happens with mismatched memory sticks based on maker or speed
double check that memory all has same speed rating
May 24, 2012 | Toshiba Computers & Internet
I can't locate were you install the memory modules
You can purchase 1GB ram sticks for them...need to shop around.
Access the ram slots by switching laptop off / remove battery / depress on / off switch several X to de-enrgise system. Turn laptop upside down and remove one of the small panels...be carefull you do not lose screws. Very carefully unclip ram stick / lift up and out.
Mar 12, 2010 | Toshiba Satellite A20-S207 Notebook
I need a guide in order to upgrade the memory of my Toshiba Satellite P205D-S7438. I'm not an expert at all but I already did so on another laptop (another brand too) and I know it is possible for me as...
This is real easy underneath you will see a large flap undo the screws hold it, and remove, you will see the RAM slotted into the socket,simply obtain the correct RAM for your laptop, and slot it in besides, or instead of, replace cover, and reboot, it will automatically be detected and used. If you have done it before then you are on your way to being an expert.. Oh we always say and "X" is an unknown quantity, and a "Spurt" is "Drip" under pressure...Xpert... < Joke.
Mar 08, 2010 | Toshiba Satellite P205D-S7438 Notebook
Trying to upgrade memory in a toshiba satellite a105 s1013
Pls Check this link, in reference to your memory upgrade...it seems that your laptop could only accomodate max 1Gb of RAM
http://support.gateway.com/s/Mobile/Q106/Magic/5948sp2.shtml
Feb 14, 2010 | Gateway MX3215 Notebook
I tried to install 1gig of ram into my toshiba and it won't start
reinstall memory (check specs if they exactly the same as old one before reinstalling) if wont work install old memory , if works you may have a bad 1 gig stick
Dec 29, 2009 | Toshiba Satellite M35X-S114 Notebook
When i try to boot my toshiba a75 laptop i receive a boot last good ... it won't boot i removed memory module i installed 2 yrs ago and it boots ... i purchased new memory module and get same error- it...
Below are the specs to the type of memory that can be installed in the A75...it is very specific and cannot be anything else then what is listed. You have 512 mb built onto the motherboard, with one expansion slot. That slot can only hold up to 1 gb stick if the BIOS has been upgraded. Go to Toshiba support and make sure the BIOS on the machine is up to date so it will accept the larger stick of ram memory and make sure all the specs are right on the stick that you have.
Each memory slot can hold DDR PC2700 with a maximum of 1GB per slot.*
  • Maximum Memory: 1536MB
  • Slots: 1 (1 bank of 1)
  • Standard Memory: 512, 768, or 1024MB (512MB non-removable)
  • USB Support: 2.x Compliant
  • Oct 20, 2009 | Toshiba Satellite A75-S231 Notebook
    I have a Satellite 2405-S221 and I was wondering if the max memory i can install is 512K, is there a way to update the bios, or ANYTHING to increase that amount to at least 1 gig??
    Toshiba Satellite 2405-S221 Laptop takes the PC2100 DDR SDRAM SODIMMs Memory Type, and comes installed with 256 MB (removable) of Memory. You can upgrade your Toshiba Satellite 2405-S221 Laptop to up to a maximum of 512 MB Memory, the system has 2 sockets to install Memory, already with 256 MB (removable) standard Memory installed.
    In short.... yeah, 512k is the max.
    Doesn't appear to a bios limitation. It is a hardware issue that is limiting the amount.
    Jan 24, 2009 | Toshiba 2405-S221 Notebook
    Toshiba sattelite
    The problem must be the amount of total memory. Maybe the board supports only 1 gig. Chek the manual.
    Oct 15, 2008 | Toshiba Satellite A100-S8111TD Notebook
    P35-611 Memory upgrade question
    hi try going in to your bios at the start when starting your pc up press f2 this should get you in to your main board settings finding the sys on your bios when you go into the bios it should come up with your cpu hard drive and mem installed if you need to reset this to 2 gig if you dont and its reading 2 gig then go to save exet yes to this and reboot your pc this may fix your problem .
    this may just be a read problem and it needs to learn that you have a 2 gig mem
    if not let me know and we can try another way for you ok
    hope this helps ok
    all the best
    May 26, 2008 | Toshiba Satellite P35-S611 Notebook
    Laptop Freezes
    it sounds like the memory may be at issue as it heats up it dies, then cools down.
    if you have 2 sticks of memory take one out and see if it will run.
    if not switch to other stick.
    if still not running remove all memory as the system should have 64 meg of onboard non removeable memory .
    as per this google :
    _________________________
    Memory Upgrade for Toshiba Satellite 2250XCDS, the Toshiba Satellite 2250XCDS takes the PC100 SDRAM SODIMMs Memory Type, and comes installed with 64 MB (non-removable) of Memory.
    windows may not boot and run at all with 64 meg so you can enter the bios screen and let it sit there,
    instead of trying to unplug the system to kill it just hold the power button for 10 seconds and it should die.maybe.
    Apr 30, 2008 | Toshiba Satellite 2250XCDS Notebook
    Computers & Internet Logo
    24 people viewed this question
    David Payne
    David Payne
