Question about Magic Chef Kitchen Ranges
When trying to turn on the oven, it beeps and give f8 code. What does f8 mean and how do i clear it.
  • lindaontheru Jul 18, 2009
    Is there anyway i can clear it so that i can use the oven until i can get a clock?
  • 3,037 Answers
Maytag-Magic Chef-Jennair-Admiral: Oven Fault Codes:
F0 Function key shorted or stuck button Clean and un-stick button or replace Touch Pad or Clock
F1 Defective Touch Pad or Membrane Replace Touch Pad or Membrane
F2 Oven over heat defective Relay Board or (if present) or defective Sensor
F3 Oven Sensor Open Replace Sensor
F4 Shorted wire or Sensor locate short and correct it or replace Sensor
F5 Hardware, safety circuits disagree Replace Clock
F6 Missing AC (power) signal Check for proper voltage (plug, breaker, etc.)
F7 Function key shorted or stuck button Clean and un-stick button or replace Touch Pad or Clock
F8 A/D Warning Replace Clock
F9 Door Lock Warning Check door lock circuit or Replace Clock
I just thought I would post the other codes for anyone else that may stumble onto this problem. Replacing the Clock should fix the problem. Let me know how this turns out. You can get a new one through the place you bought it or directly through the manufacturer.
http://www.maytag.com
Maytag 1-800-688-9900 USA
Maytag 1-800-688-2002 Canada
Benjamin
Posted on Jul 18, 2009
  • Benjamin Patri
    Benjamin Patri Jul 18, 2009
    You can try disconnecting the clock for now and see if that works, otherwise no.
How do I clear an error code FO on my GE oven
it usually means the touch pad or the oven control is defective.
Dec 05, 2015 | GE Ovens
Hi, My oven has been beeping a F10 error code for some time now, and I would like to know how I can fix this problem?
This is from Frigidaire website
These codes mean that the oven's electronic control has detected a condition it needs to check. When you see a code, follow these steps:
  • Press STOP/CLEAR to clear the display and stop the beeping.
  • Reprogram the oven.
  • If the code still displays, turn off the power to the oven at your breaker box and wait five minutes to turn it back on.
If the code is still displayed after you've followed these steps, contact your local authorized service provider.
That is the best answer I can give. I hope it helps. I don't know what the code is, but it only gives this answer.
Joe
Aug 30, 2011 | Frigidaire FGB24L2A Gas Single Oven
My oven door is locked closed. Also, it reads F8 and beeps. In order to stop the beeping, the cancel/off button must be hit. When I do that, the fan turns on for about a minute and then stops and goes back...
The control board runs self checks about every 10 seconds to check the oven codition,and what the F8 error code means is it has detected a problem with the control board itself and it needs to be repalced
Gene
Aug 04, 2011 | Jenn-Air JJW8430D Electric Double Oven
What does F7 meanon my ge oven
The F7 error code means that a button on the touch pad is bad,you can clear the error code by the pushing clear/cancel button if it doesn't reoccur all is well. If it returns (what i have heard from my customers is that it always reoccurs in the middle of the night when their fast asleep) the touch will need to be replaced
I hope this helps ,if it does please give me a 4 thumbs up rating
Gene
Jul 30, 2011 | GE Ovens
Jenn-air w276w oven gives error code F8 and beeps continously. How to reset?
F8 means "Analog / Digital problem" and it means that you have to replace to replace you display board. You can try to find a circuit breaker on a side of your house and switch it off and back on (should be a double breaker, at least 40 amps).
Oven repair in Santa Ana, CA
Appliance repair in Santa Ana, CA
Jan 25, 2011 | Jenn-Air Ovens
Oven beeps and shows F7.
  • Press "Stop/Clear" to clear the display and stop the beeping.
  • If the code still displays, turn off the power to the oven at your breaker box and wait five minutes before turning it back on
thanks.
Sep 29, 2010 | GE JGRP17 Gas Single Oven
I get an f8 meswsage when I try to use the oven. It starts to beep about 10 minutes after I try to preheat oven
F8 usually means that you have a fault in the ERC (electronic range control). meaning you have to replace the control.
First try unplugging the range over night and see if this clears the problem. If not you can check the price of a control at a local parts store. They can be fairly pricey so depending on the age of your range - you may want to consider a new range.
Jul 14, 2010 | Magic Chef CGR3725 Gas Kitchen Range
Frigidaire double oven beeping and showing f8 code
there is a problem with the lock for one of the doors do they both close all the way or does one hit the latch. could be bent linkage or bad switch on lock or the control board has a bad relay on it.i need a model # to help any ferther
Dec 31, 2009 | Frigidaire 27 in. Electric Double...
Oven emitted black smoke and F7 beeping on display
F7 stuck keypad
Stuck keypad may mean relay is turned on.
Determine if problem is with the Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
Mar 30, 2009 | GE Profile JK915 Electric Single Oven
Kenmore Gas oven is giving F8 error code
Unfortunately the F8 usually means an EEPROM data shift error. Try turning the power on and off several times. If error continues, you have no choice but to replace the ERC. Check on line for the best price. There is a group in the Chicago area that repairs ERCs. Check them out at www.cgiltd.com The failure of the your power system may have been associated with a surge either as the power went off or when it came back on. It may have been the surge that did the damage.
May 19, 2007 | Kenmore 30464 / 30465 / 30469 Gas Single...
Kitchen Ranges Logo
Top Magic Chef Kitchen Ranges Experts
Paul Carew
Sal De
Are you a Magic Chef Kitchen Range Expert? Answer questions, earn points and help others
