Question about Sony DVP-CX995V Multi-disc DVD Player
DVD Player Won't TUrn
I keep wanting to open my dvd player and turn it on. It keeps saying Stand by mode and then the power turns itself of.
How can I get it too work.
If the unit does not see the door switch (the door where the disks are inserted) it will power off after a few seconds. Under the door there is an adjustment for the door switch. It's about an inch back from the front face of the unit and - this is tricky - it's behind a small plastic cover. If you push with your finger you will feel a soft spot and will see the edges of plastic. The plastic piece is about a quarter inch high and less than an inch long. After removing the plastic cover you'll see the adjustment screw. Loosen the screw a little bit and you'll be able to slide the screw (which is attached to the switch). You won't see the switch, but sliding the screw left or right (it's in an oblong hole) will adjust the switch position. Change the position until the unit powers up and stays on.
Posted on Feb 13, 2010
  • kevin1099 Nov 03, 2010
    That screw is not for the door. It it simply to centralize the "eject" pop-up blade which pushes the selected disk out of the carousel. If it powers down after a few seconds it's likely the switching power board that is bad.
My sony dvd player won't turn on
Almost all devices might go through something like this. Sometimes, its the cable that get broken or loose. When I say loose, i mean to say that some cables have to be moved to a special position, for example, the head phones I am using now, are placed in a special position because they're like 2 years old. Same thing happens with my play station 2. I have to keep moving the cable to make it work and turn on.
Mar 14, 2013 | Audio Players & Recorders
I forgot the password to our dvd player. It is a Memorex MVD 2037 DVD player. Any suggestions?
The default password is 1234.
or..
Memorex MVD 2037 & Memorex MVD 2051
1. Turn on the Player.
2. Press the Open / Close button, (keep tray open)
3. Press the Clear button.
4. Press 1,3,6,9.
5. Press the Region you want, 0 for Region free.1 for Region 1 and so on
6. Turn your player off and then back on.
N.B if the hack does not work you may find you have to ommit step 3 and try again.so the hack will be
1.Turn on the Player
2.Press the Open / Close button , (keep tray open)
3.Press 1,3,6,9
4.Press the button for the Region you want, 0 for Region free, 1 for Region 1 and so on.
5.Turn your player off and then back on.
Alex
Feb 01, 2011 | Memorex MVD2037
Dvd dvd door will not stay closed. tried turning off and on multiple times. just keeps popping open.
Reset your player. Press and hold the FF and RW buttons at the same time on the main unit itself for 5 secs. Afterwards, unplug the player from the power source and let it sit unplug for a minute. Plug it back in to the power source and turn it on.
If its still the same issue,I just want to inform you that your unit laready needs service for repair.
Sincerely yours,
Genius 101
Oct 22, 2010 | Samsung DVD-VR375 DVD Recorder/VCR
Can't turn on my go video dvd/vcr player, keeps
Unplug it, press the power button, then plug it in and retry it. If it doesn't work, unplug it, press power, and let it sit a couple days, to try to reset everything. There may be a reset pinhole in the back, unplug it and press the reset button.
Sep 15, 2009 | GoVideo Go Video DVD/VCR Combo
My dvd player will not open sometimes it works and sometimes it d
try disconnecting power to the radio for a few hours and see if it resets itself
Jun 11, 2009 | Legacy Audio LTVD52 Car DVD Player
TV won't work after storm
ok lets try this hit the power button on the DVD player some go into stand by mode and when power is interrupted you have to push the button manually also reset the surge protector next get a lamp that you know works and unplug the tv and plug the lamp into the socket where the TV was plugged into turn on the lamp, does it turn on? yes then something wrong with TV again may have been in stand by mode plug back in and try pushing the power switch on make sure the TV if it has a remote is on the right im put to get a picture say like a satellite or cable or DVD player. hope this helps.
May 29, 2009 | Mitsubishi WS-55859 55" Rear Projection...
Panasonic dvd/vcr DMR-EZ47V model.Code OOOOOO keeps going across.
You must manually hold in the on/off button on the machine itself (NOT on the remote) for approximately 30 seconds. This will shut the unit off. Then you can restart it.
Jan 20, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
Panasonic DVD player stuck in safe mode
Just got off with the Panasonic people. You have to turn it on, then hold down the VCR play button and channel up button at the same time until the unit turns off. This will reset the whole player. Then turn it back on & it should open!
Nov 29, 2008 | Televison & Video
When i try to open my disk tray it says locked
I had same problem with JVC player. Found out from manual that there is child lock- activated by pressing stop + eject when unit in stand-by mode. (which I must have done accidentally) Unlocked by repeating action - in stand by mode.
May 24, 2008 | Televison & Video
DVD tray won't open
Hi kjflynn06 let your DVD player stand for about 2 days then you plug it in back if that does not work call a tech could be a faulty power supply good luck.
Apr 25, 2007 | Cyberhome CH-DVD 300 DVD Player
Sony DVP-CX995V Multi-disc DVD Player Logo
187 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
