SOURCE: NEC DTU 16D-2 issue
hi,1.to adjust the ring tone volume. from your phone set,press speaker dial 601.press the arrow key up or down to adjust. 2. if your station is programmed as system admin phone,then you can press feature 80 feature.to toggle between day or night.do not press speaker button while doing this. 3.the headset port need to be program,or you can do without it,by purchasing the headset came with the adapter and connect thru the handset cord. the new model is DTH-16D. CAN email me if you need a new phone, [email protected]
SOURCE: "NEC DTU-16D-2" Need it to ring!
Woo Hoo! I figured this one out on my own!
However...WARNING! I wouldn't recommend doing this unless you are technically savvy, as one wrong move could totally mess up all of your phones!!!
I searched and downloaded the Programming Manual from here: http://www.nec.co.th/html/download/Manual/Programming.pdf.
This manual will not only tell you how to fix this issue, but how to pretty much fix/change all programming for the NEC Electra Elite DTU-16D-2 phones.
I have also searched and downloaded the Feature Manual from here: http://www.nec.co.th/html/download/Manual/Features%20&%20Specifications.pdf
Happy Programming! =)
KayCee
SOURCE: HOW DO I GET THE ELECTRA ELITE IN MY OFFICE TO
you need to acces program mode and change 4-01 to assign ringing for the extensions you want to ring. ldtsnj.com
SOURCE: forgot password and have no manual for DTU 16D-2
The phone model is not enough information.
that phone can be connected to a few different phone systems, each with their own solution. please be more specific.
