My xe falcon wont start and I have all dashligths and no ignition its like theres no battery in there but it was running fine yesterday
SOURCE: 1998 au falcon automatic transmission, car wont start in park
check the neutral safety switch, sounds like it needs to be replaced. countrcurt0
SOURCE: replaced ignition and steering wheel now car wont start -security light on
Hi......
On your Buick 94.
The problem is the ANTI THEFT SYSTEM..
If you have replaced the ignition switch.
If you are using a NEW KEY, the car won't start.
Because in the OLD KEY, is there a Resistence with a number of ohm's
The computer need the resistence to activate the the signals to operate the vehicle.
OK.. with the New Key and Old Key you can go to any Aloha Smith and they will remove the Chip from the Old Key to the New Key.
And the car must start and running.
But if you are using the Same Key that you have before the repair made.
I recomend to check the 2 Orange wires from the Ignition lock Cylinder to the steering column lower connectors.
Ok I hope this work for your problem.
Any moree info, I will glad to help you.
I'm a Mechanic and have all the repair information for all the cars.
Thank you for use fixya...
SOURCE: left key in ignition overnight, now car wont start
try checking the main relay under the dash
SOURCE: 2001 nissan sentra xe p1320, p1140 codes car
Distributer Signal Output is code p1320........Intake Valve Timing Control Position Sensor Bank1 is code p1140...
