Question about Sharp LC-C4655U 46 in. LCD TV
Picture no sound
I have a 46 inch aquos 1080p and don't know how to set it up. don't know if I even plugged all the plugs in correctly. i just need to hook it up to my direct tv box. i have no idea what "input" to use or to use TV or Analog, cable, air, satelite, etc. Don't know any of it. I managed to get a picture but no sound. I have not remote either. how do i set this thing up to watch and hear tv????????
  • 744 Answers
Hi first of all u should check ur transistor connections.Check your Horizontal and vertical output transistors.You should also check the horizontal and vertical yoke connections as well as your low voltage regulators.... if any of these got damaged u should purchase a new one.. but try to purchase with the help of a tv service assistant...
thank u!!!
rate me
Posted on Jul 18, 2009
3 Suggested Answers
  • 54 Answers
SOURCE: I can not remove the stand from my aquos 46 inch tv.
you will find 4 screws at the back of the tv about 4" inches from the bottom. lay the tv set flat on your bed. you will need a metric allen wrench to remove the 4 screw. once the 4 screws are removed slide the base away from the tv.
Posted on Jan 19, 2009
SOURCE: I ger AMP error ("Pull out AC cable, check your
I had the same problem with a Sharp Aquos 40". Sound just for a second and the message all the time in the middle of the screen, no more sound.
I opened the TV and found a speaker cable (a black one) with the PVC isolation broken and the wire in contact with the chassis. I just isolated it, the sound came back and no more error message.
Posted on Nov 19, 2010
When tv is turned on you get poicture and sound but there are broken horizontal lines from top to bottom of screen. this occurs on all hdmi inputsincluding roku and dvd player.
How to fix lcd lines on Sharp tv screen, hdmi video board ...
? 3:43
https://www.youtube.com/watch?v=cHki4D0EwOo
May 24, 2014 - Uploaded by Tampatec
How to fix LCD lines on Sharp TV screen, hdmi video board easy ... Make Money From Your Broken Cracked LCD LED PLASMATV ... TV Repair Help for Vertical & Horizontal Lines on Your TV Screen ... Sharp Aquos LC-32 37 46 52DH65E 66E 77E - NoPic/Sound with ... Get video URL at current time.
comments on LCD Display Symptoms and causes. - YouTube
https://www.youtube.com/all_comments?v=DedJvyNm_s4
We have frequent outages causing the TV to turn on from standby mode when power returns. (These ..... Sharp LC-70LE650U 70-Inch Aquos TV TURNS ON WITH PERFECT PICTURE AND ..... It has thin horizontal lines on the top quarter of thescreen. ..... hey there, bought a 52lg60-ua had no image/picture but had sound.
? 2:01
https://www.youtube.com/watch?v=DedJvyNm_s4
Jan 28, 2016 | Sharp aquos 52 in lcd 1080p aquos 52...
Reset secret number on sharp aquos
ROFLOL and we are supposed to know it .or guess ,or read your mind from afar .
Nov 21, 2015 | Sharp Aquos Quattron LC-46LE810UN 46-inch...
Sharp aquos lc-46le810un won't power on, psu diode zener and fuse blows..cause?
Unhook the PSU from everything that you can and turn it on, see if it blows anything out. If it does not then you are looking at a non PSU problem. If it does then it is psu. You need to get the schematics for this set if you can.
Aug 09, 2014 | Sharp Aquos Quattron LC-46LE810UN 46-inch...
Great sound but no picture
Take it back to the store if you just bought it. If you've had it for a while, then look at the plug-ins. Are they all plugged in? If so, then something is wrong with the actual tv. Take it apart if you have to. Keep searching the internet for help. It's not like you're gonna have any tv-specials to watch for a while.
Jun 16, 2012 | Sharp AQUOS LC-40LE810UN 40 inch...
Sound but no picture
Second problem with the same thing. Take it apart if you have to. Check the plug-ins. Keep searching the internet.
Sharp Blue Ray and Sharp Aquos TV were working just fine, now blue ray not recognized by tv; screen stays dark but the blue ray appears to be operating. Have tested the blue ray independently and worked...
A refurbished set? If blue ray is not built into set the issue is with the set--maybe the reason set was refurbished.....If have not tried it unplug set for a while and reconnect with set turned off.
May 01, 2012 | Sharp Aquos Quattron LC-46LE810UN 46-inch...
Jan 18, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Want to change my sharp hd tv from 480i to 1080p
You Can Not Change. The TV Recognize the signal on the INPUT.
If the signal is 480i than the tv shows 480i
If the signal is 1080p than the tv shows 1080p (if supported)
If you try with your areal antenna (for now digital broadcast is maximum 1080i (in USA) The TV itself doesnt "upconvert" lower resolution signals.
Dec 18, 2008 | Sharp AQUOS 52" Flat-Panel LCD HDTV
Have tv plugged in on hdmi cable but picture only showing in 480i how do i change to 1080p
You need to verify that you have hd service with your tv provider first. Then, you need to find out which of your channels are being broadcasted in HD because not all of them will be in HD. HD cable and satellite is not capable of broadcasting in true 1080p. Some of them have on demand services that stream 1080p movies, but thats about it. Channels can only go up to 1080i(which is still beautiful hd). Make sure your HDMI cable is version 1.3 and you should be good...good luck 2u
Dec 12, 2008 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Sharp LC-C4655U 46 in. LCD TV Logo
111 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
