Question about Dishwashers
Dial dosnt turn on its own to continue through
Dial does not turn on its own to continue through cleaning cycle.
When dial is turned manually, all the clcles seem to be working, however, whatever causes the dial to turn on its own, is not working.
    President:
  • 1,136 Answers
Hi, The timer has a motor that turns it. If you could get me a model #, I will look this up so I can see exactly what model you have. I have seen some dials hang up because something gets spilled on them and they get sticky betweeb the dial and the control panel.
With a model #. I can see if this is that style.
Thanks
Vic
Posted on Jul 18, 2009
We have installed GM40 time. which control shaft on / off cycle i.e 4 hours on / 2 off. i checked selector switch postion, i.e continuous on (upper position) and continuous off (lower position) in this...
I have GM40 timer sitting in front of me.
I cannot understand your question because I do not know what the 'control shaft' is.
If you mean the black-colored FM1 clock dial with captive trippers, then this dial is supposed to rotate continually as long as timer has power.
http://waterheatertimer.org/images/FM-1-Grasslin-Intermatic-20.jpg
Grasslin/Intermatic GM40 page
http://www.intermatic.com/products/grasslin/electromechanical%20time%20switches/multi-voltage%20time%20switches.aspx
The manual says quote:
With the manual switch in the middle position, the GM40 is in automatic mode and will switch at the programmed times. In the upper position "I", the load is permanently ON. In the lower position, "O", the load is permanently OFF. End quote.
In any switch position, the FM1 clock dial will continually rotate.
If your Load does not turn on-and-off according to the trippers set on FM1 clock dial, then 1) wiring is suspect or 2) if dip switches are not correctly set before applying voltage, and timer could be damaged.
The timer arrives with dip switches pre-set for 277Volts.
You can also manually rotate clock dial clockwise to observe when the load turns on-off.
Add a comment and give more information.
I would like to know what the 'control shaft' is, and what voltage you are using, and what dips switch setting you have, and which wires are connected to each terminal.
Apr 13, 2011 | Intermatic GM40 - 24 Hour/7-Day Dial...
Hello The washing machine is not going through
The lid switch has failed. It will not spin because it is a safety device.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 09, 2010 | Kenmore 22422 Top Load Washer
Unit fills with water Spray arms do not turn all other clcles seem to work
When my wife started complaining about her dishwasher not getting the top rack clean this is what I found and I wrote a tip about it...
Dishwasher Spray Arms not Spinning
heatman101
Sep 07, 2010 | Dishwashers
Agitation, agitation, agitation
HI. This problem concerns the integrity of the actual timer mechanism. The dial cogs seems to be worn, and the timer motor may be failing to advance in that particular section of the dial plate. This type of malfunction will require you to replace the timer control mechanism, asap.
Feb 15, 2010 | Whirlpool LSR5132PQ Top Load Washer
Dryer heats intermittently clcles off heat then
Try vacuuming lint and dust out of the burner intake and exhaust ports. Hope this helps!
Dec 05, 2009 | Kenmore 73952 Gas Dryer
I need an owner manuel for Caloric Range Model # EST 345 I can'g figure out how to run the self cleaning oven cycle.
you might try the following, although it is the instructions for an old model, it may be relevant;
"The actual self-cleaning process is initiated by a simple 5 step procedure: 1. Set the range clock to time of day. Note: on models not equipped with an automatic oven timer, the self-cleaning cycle is preprogrammed for a 21/2 hour cycle. Use Steps 3, 4 and 5 only. 2.Establish the length of cleaning time by:
A. Setting the start time. Press and turn the start dial of the automatic oven timer clockwise to the desired starting time. B. Set the stop time. Press and turn the stop dial of the automatic oven timer clockwise to the desired stop time. Max time is 3 hours miniumum 1/12 hours. 3. Set the oven selector dial on the control panel to "Clean" 4. Set the temperature control dial to "off". If you temperature control dial has a "Clean" position, then set the dial to "Clean" instead of "Off". 5. Remove oven racks, broiler pan and broiler grid from lower oven. Close and lock the oven door by moving the latch lever as far right as it will go - into the locked position. If the lever is accidently dislodged restore it to the locked position. Otherwise, the self-cleaning process will not take place. Shortly after the cleaning cycle has begun, the oven temperatur reaches a degree in excess of the normal broiling temperature. The red "Clean" light will come on and the clean cycle will start. In a few minutes the door lock lever, which you have placed in the locked position, will automatically be secured to prevent the oven door from beging opened during the cleaning cycle. This latch remains locked until the clean cycle is complete and the oven temperature reduces to normal baking and broiling temperaturs. NOTE: Prior to self cleaning cycle operation, the oven and surface lights must be turned offed. The upper oven can be used."
I found this here; http://www.appliance411.com/archive/21155_caloric_oven_lost_cleaning_manual.shtml
Nov 18, 2009 | Ovens
Dishwasher stalls
If the cycle doesn't complete, check these:
Water-heating cycle
Timer
Water-heating cycle Many dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water, waiting for the water to reach the pre-set temperature. What happens next, depends, as follows:
  • On some units, the pause is timed and the unit continues after the allotted time.
  • On others, the cycle can't continue until the water reaches the higher temperature. If you have this type of dishwasher and the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too.
Timer Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it.
May 31, 2009 | Bosch SHU4006 Dishwasher
Capresso s8 weak coffee
You should probably run a cleaning cycle with a cleaning tablet (the one you drop into the ground coffee shoot, not a decalcifying tab).
This will clean out all the insides where coffee particles and oil can accumulate.
The machine will ask you to run a cleaning cycle after a certain number of cups brewed. But you can also manually start it.
(this is copied from the manual)
You can run a tablet cleaning cycle at anytime even if
the machine does not prompt you,
• READY. Push and hold the Rinse button until display shows
RINSE. The Dial illuminates.
• Turn the Dial until display shows CLEANING. Push the Dial.
Display shows EMPTY DRAWER.
(Follow the rest of instructions for regular cleaning cycle)
Jan 16, 2009 | Jura Capresso Impressa E8 Espresso/Coffee...
Frigidaire FDB710LCS0 Dishwasher dial seems to stick?
I had the same problem. Turn the HIGH TEMP buttons off. Simply turning them off corrected this problem for me. Mine got stuck in two places and I had to manually turn the dials or the washer would run all night.
Nov 21, 2008 | Dishwashers
Dishwashers Logo
100 people viewed this question
Top Dishwashers Experts
