Question about Vehicle Parts & Accessories
I have motorola car alarm and i need to override it can you help
1997 crown Victoria. viper alarm kill switch has turned all power to car. How do I reset
there is no override. Otherwise it would defeat the point of an immobilizer. I would find out why the alarm went off and deal with the rot cause rather than trying to bypass something made to be un-bypassable.
You may be able to reset the alarm by unplugging the battery from the car for a minute or 2 but I would start with the alarm manual to be safe. Possibly even remote the alarm and put the wiring back to stock.
Oct 16, 2016 | 1997 Ford Crown Victoria
Clifford g5 alarm how do i reset it after i was checking fuses it wont let me start the car
The car won't start because the Clifford alarm has a starter interrupt wire where the start wire runs through the alarm system module/relay. The unit then must still be active for the car not to start. If pressing the disarm/unlock button on your Clifford key FOB does not turn the system off, you will after to do it manually. You will need to locate the manual override button installed somewhere in the car that is connected to the alarm system. Turn the ignition switch to "on" or "run" and within 10 seconds press the manual override switch. That will turn the alarm system off and allow the car to be driven normally. I would then take the vehicle to an authorized Clifford or other DEI (Viper) install shop and have them diagnose your apparent problem.
Jul 31, 2014 | G5 IntelliGuard 770 P/N 919621 Car Alarm
2001 mitsubishi eclispse gs wont start how do you bypass the security system
  • 1 Turn the ignition key counter clockwise in the driver's side door to unlock the caricon1.png. This deactivates the alarm long enough for you to gain access to the vehicle. Then, place the key in the ignition and turn the key until it clicks once. This starts the car's battery, but doesn't ignite the engine. The LED light on the dashboard should stop blinking, indicating the alarm is temporarily disabled.
  • 2 Locateicon1.png the box for the alarm under the dashboard on the driver's side of the car. Then, look for the override button on the box. Typically, the small button is either red or black. With the ignition key in the "on" position, press the override button and hold it in until the alarm chirps once. This disables the alarm until you manually reactivate it.
  • 3 To reactivate the alarm, turn the key to the "on" position and press the override button once. The alarm chirps twice, indicating the alarm is active.
  • Hope this helps!
    Mar 15, 2014 | 2001 Mitsubishi Eclipse
    I need to locate a SIM ID for the carlink App
    you will have to go to a dealer that installs this type of car alarms and get an override code to be able to use your phone if button don't work.
    Jan 28, 2013 | Audiovox Prestige Cl100 Carlink System
    I have a 2000 dodge intrepid. The alarm never worked on it. We bought it used and all of a sudden when we go to unlock the door it turns on. Now the car won't start. I've looked online for answers and...
    The 2000 Dodge Intrepid is equipped with an alarm system that is triggered when unauthorized entry is attempted. In some situations, such as having the Intrepid valet parked or when it is being serviced by a mechanic, the alarm system needs to be disarmed so it doesn't go off. Disarming the alarm will prevent it from being activated until it is armed again.
    Difficulty: Moderate Instructions
    1. 1 Insert the key into the ignition.
    2. 2 Turn the ignition switch to "ON." Do not start the engine.
    3. 3 Press and hold the valet/override button within five seconds of turning the ignition on. The valet button is located beneath the steering column.
    4. 4 Release the valet/override button after the security indicator light turns off.
    5. 5 Turn the ignition switch off.
    have to do it in this order
    Dec 10, 2010 | 2000 Dodge Intrepid
    My colt sometime does not start, I switch alarm on and off then it starts How can I override the alarm/immobilizer?
    If its the manufacturers alarm, I don't think you can otherwise criminals could also...if its an after market one sometimes there is an override button (Tiny red) one down in the drivers foot well somewhere.
    Oct 15, 2010 | 2006 Mitsubishi Colt
    Have a code alarm for car remote dont work and cant disable it. wont start how do i disconect alarm so car will start
    Provided that your system is not programmed for coded override, the standard emergency override is as follows:
    1. Enter the vehicle (the security system will trigger.)
    2. Locate but do not press the valet/override switch yet (it should be a small black button installed under the dash within reach of the driver)
    3. Turn the ignition key to the ON position.
    4. Press and release the emergency override button (The security system will turn off).
    Note: If the automatic arming feature is enabled on your system. The security system will re-arm the next time the ignition key is turn off and the vehicle's doors are closed.
    If the coded override feature was enabled by the installing dealer, you will need to follow these procedure:
    1. Enter the vehicle (the security system will trigger).
    3. Turn the ignition switch to the ON position.
    4. Within 5 seconds press the emergency override button the number of times corresponding to the first digit of your personal code (Default digit is 1).
    5. Within 5 seconds turn the ignition key OFF, then ON.
    6. Within 5 seconds press the emergency override button the number of times corresponding to the second digit of your personal code (Default digit is 1).
    7. Within 5 seconds turn the ignition key OFF, then ON.
    8. If entered correctly the security system will turn off.
    9. Turn the ignition key to the OFF position.
    If the coded override feature is enabled and the code is lost, the system will need to be reprogrammed by an authorized dealer.
    Aug 03, 2010 | Audiovox Prestige Code Alarm Remote Alarm...
    Alarm is armed, and I dont have a remote.I need to manually dissarm the alarm or my car will not start
    Open the door, the alarm will sound , go under your dash, normally installation techs will install a kill switch or alarm override button either in the drivers side kick panel to the left of were your left foot rests or inside the fuse box panel, under the steering column or by the center column somewhere but most likely the drivers kick is the spot. So open the door and find the kill switch or override button and put the key in the ignition turn it to the on position without cranking and press or toggle the switch after you turn the key, this should override the alarm and let you start the vehicle, otherwise you have to remove the alarm main fuse from the brain and rewire your starter kill to factory so that you can start your vehicle normally again until an alarm tech corrects the alarm wiring.
    Good luck my friend, hope it is helpful.
    Jun 12, 2010 | 2002 Oldsmobile Alero
    Need a wiring diagram for the factory alarm system for a 1998 toyota camry le 6 cylinder. The alarm is preventing us from starting the engine and we need to locate the override switch.
    there is no "override switch" if there was, anyone could steal the car. if its a factory system, you will need a dealer to print a diagram and part of the service manual to diagnose it.
    Oct 13, 2009 | 1998 Toyota Camry
    Vehicle Parts & Accessories Logo
    122 people viewed this question
    Top Vehicle Parts & Accessories Experts
    Thomas Perkins
    Thomas Perkins
    Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
