Question about Nike Mettle Sledge Watch WC0040 096
"one touch backlight"
How do you turn on the "one touch backlight" ?
You must hold start button 3 seconds, then your backlight turn on by adjust button
Posted on Aug 27, 2009
How do I change the backlight setting?
How to adjust the backlight strength, time-out length of the ...
www.cnet.com > Mobile > Wearable Tech
CNETJul 23, 2015 - In order to adjust either setting, your Pebble Time watch will need to be updated to version 3.2. Launch the Pebble Time app on your device ...
how do i adjust backlight time on my iphone ' Apple Support ...
discussions.apple.com > Support > Apple Support Communities
Apple Inc.Nov 18, 2012 - Not sure what you mean by Backlight time. But you can adjust how long it is before your phone auto locks at. Settings> General > Autolock. How do in change my backlight settings on my iP...
Dec 31, 2013
Did they do away with the backlight timer for i...
Nov 6, 2011
how do change the back light to time out?
Jan 14, 2009
More results from discussions.apple.com
Dec 25, 2015 | Watches
Cant set it
    Setting the Time
  1. G-Shock watches feature a digital display that is set using the function buttons on the outside of the watch face. To set the time, press and hold the the upper left button until the seconds unit blinks on the display. Reset the seconds to "00" by pressing the lower right button.
    Push the lower left button to switch to the hours unit, which will start blinking. Advance the hour by pressing the lower right button. If you hold down the lower right button, it will advance the hour unit at a higher rate of speed. Once the hour is set, press the lower left button to switch to the minutes unit. As with the hours unit, pressing the lower right button will advance the minutes and holding it down will advance the minutes rapidly.
    Once the time is set, press the upper left button to save the setting.
  2. Backlight
  3. The backlight on a G-Shock watch has a manual control and an automatic function that will light the face of the watch whenever the alarm, countdown alarm or hourly alarm ring. To use the manual backlight, press the button on the bottom of timepiece. The light will glow for approximately 2 seconds before going out.
    The automatic function is set by pressing and holding the lower right button. When the automatic function is set, an indicator icon will display on the watch face above the seconds unit. You can turn off the automatic backlight function by pressing and holding the lower right button until the icon disappears.
    Note that backlight causes a drain on the battery, and overuse of the backlight will greatly reduce battery life.
  4. Setting the Alarm
  5. The G-Shock has an alarm that emits an audible tone for approximately 20 seconds when it turns on. To set the alarm, press the lower left button until "AL" displays in the upper left corner of the timepiece. Press and hold the upper left button until the hours unit starts to blink. Adjust the hour by pressing the lower right button. As when setting the time, you can advance the hour at a higher rate of speed by holding down the lower right button.
    Once the hour unit is set, press the lower left button to advance to the minutes. Use the lower right button to set the minutes. Follow these same instructions to set the month and day you want the alarm set.
    When the alarm time and date are entered, press the upper left button to save the setting. Push the lower left button three times to return the G-Shock to "Timekeeping" mode.
Aug 19, 2010 | Casio G-Shock G 520D 4AVDR Cockpit Series...
I cant figure out how to work it my casio gshock
    Setting the Time
  2. Backlight
Aug 14, 2010 | Casio Watches
Casio F91W-1 Wrist Watch- backlight color
You can change the backlight on a casio wristwatch by holding the Light button, but only if it has an LED light in the side of the screen such as yours does. There is Light Blue, Red, Pink, Blue, Green LEDs in the side of the screen and you can change between them. There is also an option that flashes between all the LEDs when you press the button.
May 06, 2010 | Casio F91W-1 Wrist Watch
Light turned off, can't get it to turn back on
There are more tha one version of your watch, so you need to go to the Nike web site to be sure that you have the correct instructions.
From what I can make out, the backlight comes on when the upper left hand button is pressed. The light will turn off after a short while, to preserve the battery
To get a copy of the instructions, go to the web site "Niketiming.com. "
Select you language and region.
On the left of the screen there is a box with a drop down menu for manuals. Choose yours and download.
Jan 17, 2010 | Nike Anvil Comold Super Deep Burgundy/Team...
Just got a nike anvil comold but cant get the backlight to work
I had the same problem. The seller told me to reset the watch by pressing down on all four buttons at once. Sure enough, the backlight function was enabled again.
Feb 14, 2009 | Nike WR0099 017 Mettle Anvil Comold Super...
Automatic backlight
PUSH AND HOLD THE MANUAL LIGHT BUTTON, SHOULD CHANGE TO AUTO MODE
Oct 21, 2007 | Casio G-Shock GW500A-1V Wrist Watch
Backlight
Try holding the indiglo button for atleast 3 seconds.
Sep 02, 2007 | Fossil Philippe Starck PH1035 Wrist Watch
Backlight doesn't work
Go to this link; http://world.casio.com/wat/download/en/manual/ and enter the four digit code on the back of the watch, you should get a user manual - i do think you are probably right however. Hope this helps :)
Apr 18, 2007 | Casio G-Shock GW300A-2V Wrist Watch
Nike Mettle Sledge Watch WC0040 096 Logo
279 people viewed this question
Top Nike Watches Experts
Jimmy Accardi
Electro Med Services...
Are you a Nike Watch Expert? Answer questions, earn points and help others
