Cars & Trucks Logo
m
mehdi saberi Posted on Jul 24, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Remote control doesnt open the doors,clock doesnt work
My car had a crash at the backside of car.they had to remove rear bumper to repair.after repairing I have above problem
Jeff Armer
Level 3:
  • Cars & Trucks Master 15,575 Answers
  • Posted on Jul 25, 2016
Jeff Armer
Level 3:
Answers
15575
Questions
Helped
7100553
Points
73899
What make , model an year vehicle ! Sounds like some wires may have been shorted or broke , ripped etc....
5 Related Answers
Anonymous
  • Posted on Jun 27, 2008
SOURCE: BMW remote control problem
I have a e60 525i that I just brought and it has the same problem, the owners manual suggests driving with the key in the ignition for a long time as the batteries are rechargable and may have gone flat, i have tried this and it doesnt seem to work
i also read something about getting water in the aerial about the rear window and that wrecks the receiever. My car isn;t under warranty so not looking forwarding to taking it to bmw
Anonymous
  • Posted on Dec 07, 2008
SOURCE: 2004 Jeep Grand Cherokee driver side power windows do not work
I had the same problem with now power to windows, mirrors and seat. The common soulution is the orange and or black wire in the boot have broken between the door and post.
Anonymous
  • 840 Answers
  • Posted on Feb 01, 2009
SOURCE: 2004 toyota rav4 rear bumper assembly guide
there are two bolts to the center and two around the corner on at the edge up high and one at the bottom of the bumper/ Please rate my response thank you very much
Anonymous
  • 295 Answers
  • Posted on Mar 21, 2009
SOURCE: how remove the rear inside door panel on a 2001 oldmobile aurora
The inner door panel is held in by clips and screw.
Look at the door near the door handle there should be screws holding it in and along the outer edge of the door. Once loose, and the door handle removed or the arm rest removed. The door panel then prys out , because of the clips that hold it on. Then pops out by applying pressure to the panel upward to the top of the door. The clips always break because of the design and plastic.
Good luck
Anonymous
  • 63 Answers
  • Posted on May 03, 2009
SOURCE: window dropped into rear door panel. How do I remove the panel & repair
the window regulator has failed. the door panel has to be removed first which requires removing the trim piece that is on the grab handle (extremely hard to remove without breaking) there are three of four screws that hold the door panel on. once the door panel is off, the vapor barrier has to be removed. don't tear it, it is there for a reason to keep water out of the vehicle. make sure you reseal it properly with window weld. once the vapor barrier is removed you will need to unclip the window glass from the regulator. i typically will take and break the tab that holds the window. once the window is loose, move the glass all the way to the top of the door. now remove the regulator, swap the motor over, and reassembly. i would recommend taking the vehicle to a bmw dealership, around $650 for the complete repair and the dealership will stand behind their repairs
How do i remove and replace drivers side door window
For Doors not getting open with remote or key problem,there are help links provided below.Click the link below to go through its procedure and troubleshoot the problem:----
drivers side front door will not open from inside or outside?
http://technoanswers.blogspot.com/2012/01/ford-f-350-crew-cab-drivers-side-front.html
Car door will not close?
http://howtobyme.blogspot.com/2011/11/car-door-will-not-close.html
All power door locks not working ?
http://howtobyme.blogspot.com/2011/11/all-power-door-locks-not-working-on_14.html
Repairing car Door lock Actuator?
http://howtobyme.blogspot.com/2011/11/repairing-car-door-lock-actuator.html
How to Access car door panel?
http://howtobyme.blogspot.com/2011/11/how-to-access-car-door-panel.html
Vehicle door panel components?
http://howtobyme.blogspot.com/2011/11/vehicle-door-panel-components.html
Truck Door will not close?
http://schematicsdiagram.blogspot.com/2011/12/ford-truck-door-will-not-close.html
Where is Cars Door control Module located?
http://schematicsdiagram.blogspot.com/2011/12/where-is-cars-door-control-module.html
Power door locks not working?
http://schematicsdiagram.blogspot.com/2011/12/power-door-locks-not-working.html
Door ajar light stays on?
http://technoanswers.blogspot.com/2012/01/door-ajar-light-stays-on.html
Door locks not working?
http://technoanswers.blogspot.com/2012/01/door-locks-not-working-on-ford-explorer.html
Front Door dis-assembly diagram?
http://repairhelpcenter.blogspot.in/2012/02/front-door-dis-assembly-diagram-for.html
Rear Door dis-assembly diagram?
http://repairhelpcenter.blogspot.in/2012/02/rear-door-dis-assembly-diagram-for.html
How to test Power door locks?
http://repairhelpcenter.blogspot.in/2012/02/how-to-test-power-door-locks.html
Doors will not open with Remote?
http://schematicsdiagram.blogspot.in/2012/02/lexus-doors-will-not-open-with-remote.html
How to replace Door Hatch ?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-hatch-on-acura-integra.html
How to remove Doors?
http://repairhelpcenter.blogspot.com/2011/11/how-to-remove-doors-on-acura-integra.html
How to Replace Doors?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-doors-on-audi-a4-and-vw.html
Remote will not unlock Rear door?
http://schematicsdiagram.blogspot.com/2011/12/remote-will-not-unlock-rear-door-on-gmc.html
Door locks or windows not working on car?
http://schematicsdiagram.blogspot.com/2011/07/door-locks-or-windows-not-working-on.html
This will help.
Thanks.
My 1998 park avenue passenger doors wont open
For Doors not getting open with remote or key problem,there are help links provided below.Click the link below to go through its procedure and troubleshoot the problem:----drivers side front door will not open from inside or outside?
Truck Door will not close? http://schematicsdiagram.blogspot.com/2011/12/ford-truck-door-will-not-close.html
-----------Where is Cars Door control Module located?
Power door locks not working? http://schematicsdiagram.blogspot.com/2011/12/power-door-locks-not-working.html
-----------Door ajar light stays on?
Doors will not open with Remote? http://schematicsdiagram.blogspot.in/2012/02/lexus-doors-will-not-open-with-remote.html
http://repairhelpcenter.blogspot.com/2011/11/how-to-remove-doors-on-acura-integra.html -------`-
--------Remote will not unlock Rear door?
--------This will help.Thanks.
How to remove the drivers side door panel to access power window motor etc
This will help.
Thanks.
2011 volvo s60 door removal
This will help.
Thanks.
2answers
Remove door panel on h3
This will help.
Thanks.
How do you remove inside off door to put motor for windows
This will help.
Thanks.
Remove door panel on 2000 Dodge Caravan
This will help.
Thanks.
How to remove power window switch
This will help.
Thanks.
1helpful
My 2009 Corolloa LE was bumped in a parking lot by a yellow truck, on the right rear bulge of the bumper, leaving a ding in the bumper. I can only partially access the backside of the bump by removing the...
Go underneath with socket and wrench. there will be 2 bolts with nuts on one end and two on the other end. Then the entire bumper can then pull off.
3helpful
Rear door on driver side won't open,have taken the panel off the inside of car,seems like the lock won,t travelas far as it does on the other door.is there any way to open this door,thanks[1997 lincoln...
Rear
Removal
  1. Using a small screwdriver, remove the screw cover from the armrest of rear door trim panel (27406).
  1. Remove the two retaining screws.
  1. Using Trim Pad Removing Tool from Rotunda Windshield and Moulding/Trim Removal Kit 107-R0401 or equivalent, pry rear door trim panel from door inner panel.
  1. Disconnect electrical connectors.
Installation
  1. Position rear door trim panel on door inner panel, aligning two locators on rear door trim panel. Reverse Removal procedure.
------------------------------------------------------------------------------------ Rear
Removal
  1. Remove door trim panel and watershield. Refer to Section 01-05 .
  1. Check all connections of remote control links and cables. Service as necessary.
  1. Remove remote control assembly.
  1. Remove door latch remote control assembly from latch assembly.
  1. Drill out rivet at bellcrank and link (264B14).
  1. Remove three screws attaching latch assembly to door.
  1. Drill out rivet that attaches actuator motor to door.
  1. Remove latch assembly with actuator motor and door latch control rod lever link assembly.
Installation
  1. Install new bushings and clip onto latch assembly.
  1. Install latch with links and power lock actuator into door cavity.
  1. Position latch assembly to door, aligning screw holes in latch and door. Install three screws. Tighten to 10-13 Nm (89-115 lb-in).
  1. Attach door latch actuator motor to door with a new rivet.
  1. Install bellcrank and link to door using a new rivet.
  1. Install inside door handle and remote control assembly to door.
  1. Open and close door to check latch assembly operation.
  1. Install watershield and door trim panel. Refer to Section 01-05 .
Item Part Number Description 1 221A00 Door Handle to Door Latch Actuating Cable 2 26446 Rear Door Control Rod Retainer 3 377901 Plug Button 4 26412 Rear Door Latch 5 W623451-S2 Push Nut 6 224A32 Counter Balance 7 22450 Door Outside Handle Tension Spring 8 W701210-S309 Screw 9 224A20 Outside Door Handle Anti Rattle Pivot (2 Req'd) 10 22404 Door Handle 11 224A24 Front Door Outside Handle Spacer (2 Req'd) 12 264A64 Rear Door Actuating Rod 13 22408 Outside Door Handle Anti-Rattle Bumper 14 22428 Outside Door Handle Large Pad 15 N621906-S2 Nut (2 Req'd) 16 N807329 Screw (3 Req'd) 17 26595 Rear Door Electric Latch Actuator (RH) 18 W701566-S47 Rivet 19 431C04-A Rear Door Latch Striker Assembly 20 — Door Lock Striker Plate (Part of Door Shell Assy) 21 W525172-S Rivet (2 Req'd) 22 264B14 Bellcrank and Link (RH) 23 264A50 Bushing 24 N802034-SG Rivet 25 26420 Rear Door Latch Control Rod Link 26 W525172-S Rivet (2 Req'd) 27 21818 RR Door Latch (Inside) 28 A26460 RR Door Latch Push Button Rod 29 21982 Door Latch Rear Striker Assembly 30 N808377-S101 Screw (2 Req'd) 31 250A04 Rear Door Catch 32 N801010-S100 Truss Head Bolt (2 Req'd) 33 N804234-S2 Screw 34 266A74 Rear Door Latch Actuator Retainer 35 24630 Rear Door 36 26552 Rear Door Latch Control Escutcheon A — Tighten to 21-29 Nm (16-21 Lb-Ft) B — Tighten to 10-13 Nm (89-115 Lb-In) C — Tighten to 7-8 Nm (62-70 Lb-In) D — Tighten to 26-34 Nm (20-25 Lb-Ft) E — Tighten to 3-4 Nm (27-35 Lb-In)
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
