Question about Brother IntelliFAX 4750 Plain Paper Laser Fax
Get error 78 comes up on my brother machine after I changed the drum and toner
    New Friend:
  • 116 Answers
Heater thermistor harness disconnected or broken. replace it or replace fuser unit
Posted on Jul 18, 2009
My printer brother HL2170W has toner, the toner light is not flashing but whet its prints it comes blank
This sounds like an issue with either the toner cartridge or the drum unit. Have either of these consumables been changed recently? This should help identify the likely cause.
If the drum has been changed recently I would recommend cleaning the corona wire. If however the toner has been changed there isn't masses I can recommend in terms of trouble shooting. it may however be worth running off 15-30 pages in the hope of pulling the toner through.
Failing this I would recommend calling Brother technical support in case the issue is hardware related and not the fault of a consumable.
Oct 31, 2012 | Brother Office Equipment & Supplies
CHANGED DRUMAND THE CHANGE DRUM SOON ERROR IS
you need to open the front cover (where drum and toner is installed) and press the options button, it will ask replace drum? Press 1 for yes and close the front cover.
Apr 15, 2010 | Brother IntelliFax-2820 Laser Fax
Brother MCF-7340 first time toner replacement
If this model comes with the drum separately of the cartridge, only replace the cartridge. There's no need to change it every time. until prints start to get lines or dots. Don't expose the drum to light too much.
Jul 30, 2009 | Brother MFC-7340 All-In-One Laser Printer
BROTHER MFC 7820N MACHINE PUT IN NEW DRUM, CHANGE DRUM MESSAGE COMES ON. PUT IN NEW TONER, TONER END OF LIFE MESSAGE COMES ON.
To manually reset the counters, do the following:
  • Open front cover, press "option".
  • Answer Yes (by pressing 1) to the question in the display.
  • Your drum counter is now reseted. Press "option" again.
  • This time, press *, 0, 0.
  • Your toner counter is now reseted too.
(If nothing happens when pressing option, try using the back/clear button instead.)
Jun 15, 2009 | Brother DCP-7020 All-In-One Laser Printer
Toner Problem error message
remove the yellow plastic from the toner thats a protection. check around toner.
Jun 04, 2009 | Brother MFC-8460N All-In-One Printer
Change toner error brother 2820 mach has new brother toner ctg
with machine on, open front cover, press the "options" button, you should see "replace drum?" press the "start" key then 1 then 0. display should show accepted for a couple of secs. then show cover open. close front cover and message should be gone. if not, you will have to contact Brother.
hth,
razors
Jan 23, 2009 | Brother IntelliFax-2820 Laser Fax
Brother 8460n - toner error
Hi, This worked for us:
The message "Toner Error" is usually caused by the drum and/or toner
cartridge not being installed properly or if the machine does not
recognize the toner. To clear this message, follow the steps listed
below:
1. Verify you are using Genuine Brother Cartridges. Brother strongly
recommends that you do not refill the toner cartridges provided with
your machine. We also strongly recommend that you continue to use only
Genuine Brother Brand replacement toner cartridges. Use or attempted use
of potentially incompatible tone cartridges in the Brother machine may cause damage to the machine and/or may result in
unsatisfactory print quality. Our warranty coverage does not apply to
any problem that is caused by the use of unauthorized third party toner
and/or cartridges. To protect your investment and obtain premium
performance from the Brother machine, we strongly recommend the use of
Genuine Brother Supplies.
2. Make sure that you are using the correct drum and toner cartridge(s)
for your machine. The part numbers for your model are as follows:
NOTE: Some cartridges can look EXACTLY the same among different models
and will fit the machine even if they are not designed for use in that
model. Verify the part number before using the cartridge(s).
TN550: Toner cartridge (standard)
TN580: Toner cartridge (high yield)
DR520 = Drum unitt.
3. Make sure that the cartridge is not damaged. Remove the toner
cartridge by following the steps listed below:
a. Press the cover release button and then open the front cover.
b. Remove the old drum unit and toner cartridge assembly. Place it on a
drop cloth or disposable paper to avoid scattering toner.
NOTE: Be careful not to spill the toner. If toner gets on your
clothes or hands, wipe or wash it off immediately with cold water.
c. Hold down the blue lock lever on the right and pull the toner
cartridge out of the drum unit.
d. Look at the toner cartridge and see if any parts or pieces appear to
be broken or missing, if so, the cartridge may be defective and should
be replaced.
4. If the toner cartridge is not damaged, reinstall it into the drum
unit. If it was damaged, use a new toner cartridge and reinstall it into
the drum unit.
5. Reset the drum/toner unit into the machine.
6. Close the front cover.
7. If the message "Toner Error' continues to appear on the display
unplug the machine from the wall outlet.
8. Open the front cover and remove the drum and toner assembly.
9. Look inside where the drum was. On the left side wall, look for a
small, black plastic lever/actuator. A flashlight may help see it.
10. Using the palm of your hand, slide it along the left wall in and
out a few times as this may free up the actuator/lever in case it is
stuck. The actuator/lever is spring loaded and needs to move back and
spring forward to operate correctly.
If the lever does not move, spring back or is missing and your machine
is within warranty, you can locate a Brother Authorized Service Center
(ASC) in your area or contact Brother Customer Service by calling
1-877-Brother (1-877-276-8437) Monday through Friday, excluding
holidays. If the machine is out of warranty, you can locate a Brother
Authorized Service Center using the information listed above.
If the lever moves freely and springs back to its original position
continue to Step 11.
11. Reinstall the drum and toner assembly, close the front cover and
plug the machine in.
Aug 12, 2008 | Brother MFC-8460N Laser Printer
Change of toner
I have a brother mfc 7840w
I first used the electrical tape trick and that worked for a while. Then got the toner low message again. I then tried the *00 trick, which works as follows:
1. lift lid and open front cover
2. press clear/back. "Replace Drum?" will appear on the screen.
3. Press "*00" it will then read accepted and the toner low error (End of Toner Life) should go away.
4. close it all up and your done.
Jun 08, 2008 | Brother MFC 7420 All-In-One Laser Printer
Toner Error - reinstall drum unit
below:
DR520 = Drum unitt.
be replaced.
the drum unit.
Apr 10, 2008 | Brother MFC-8860DN All-In-One Laser...
Reset drum - brother mfc-8860dn
Open front cover
Remove drum unit and toner cartridge assembly
Put drum unit and toner cartridge assembly back in machine, but do no close front cover.
Press Clear/Back
You will get a message "Replace Drum?"
Select Yes to confirm
Jan 06, 2008 | Brother MFC-8860DN Printer
Brother IntelliFAX 4750 Plain Paper Laser Fax Logo
203 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
