Question about Microsoft Wireless IntelliMouse Explorer
Left button recently requires "extra" effort to make it work...any explanation?
    Novelist:
  • 109 Answers
Have you spilled liquid such as coffee or soda into the mouse? If not, the micro switch is starting to fail under the button.
Posted on Jul 18, 2009
Polatab tablet. Why is it indicating 'unfortunately settings have stopped working'?
Too many apps probably and not enough memory left for the OS so it just gives up and crashes either that or an app you added recently has caused the problem - you can either remove some apps to free up memory or recently installed apps or execute a full wipe and reload of the tablet os by pressing the power button and up volume then selecting the required option from the recovery menu!
Jan 24, 2016 | Tablets & eReaders
Steeling wheel locked can not start
Try turning wheel right or left while turning key, sometimes when you stop wheel will lock against the stop and requires extra effort to release
Mar 24, 2013 | 2004 Honda Element
Casio Exilim EX-P505 the left arrow key doesn't work. is it setting or broken? what should i do?
Most likely the arrow key switch is broken or the contacts are corroded. If it's a snap-button switch, it needs to be replaced. If this is bad, I recommend replacing the others also. If it's a conductive rubber button (like most TV remote controls), the conductive patch on the inside is worn and needs to be repainted with carbon/silver conductive paint. A miniature snap-button switch is generally less than a dollar from Mouser Electronics - soldering skills are required for replacement. Conductive paint for rubber button switches is $10.45 for a 1 gram tube. It has a very limited shelf life once it's opened, so use up the rest on the other camera buttons, and the power, channel and volume buttons on your favorite TV remote control (if you can get it apart without breaking the case)
Cameras are typically difficult to take apart for repair. You'll have to consider the value of the camera versus the effort to get to the control buttons. The electronics inside are sensitive to static electricity damage, so you should work on an anti-static mat and use an anti-static wristband with it..
Nov 14, 2017 | Casio Exilim Pro EX-P505 Digital Camera
My PD170 Start/Stop button cannot work (all 3 buttons). There's also no explanation on LCD. I already try to leave it for some hours with cassete compartment opened (hopefully it's only moisture problem)...
Sony cameras have a Hard-Lock switch that prevents buttons being pressed if locked, also make certain the tab on back of tape has not been slid to protect mode.
Jun 13, 2010 | Sony Dvcam DSR-PD170 DV Digital Camcorder
Which is better a top loader or front loader washing machine?
Front Loading Washing Machine: Fully automatic.
1. Better washing than toploading as technologically proofed.
2. No extra effort except putting cloths and detergent inside.
3. No need to observe in between while washing. Start and forgot. You can go market and come back.
4. No issue if electricity or water went out during washing.
4. Take more water compare to toploading semi-automatic.
5. You can not open it once it started.
Top Loading Washing Machine: Semi
1. Save water and detergent.
2. Need extra effort to put the cloth from one box to another.
Oct 10, 2009 | Washing Machines
Please send me VGA driver for pentium 4
Hii, you can download all the driver of your Intel motherboard including VGA driver also from
http://downloadcenter.intel.com/default.aspx?iid=gg_work+home_dowloads#.
Go this site and at the left hand side, go to the desktop board andselect your exact motherboard model. After selecting the model you justdownload the driver as per your requirement and install it.
Mar 02, 2009 | Intel Celeron -D 2.26Ghz Computer System...
1991 Chevy Silverado Rolls while in Park
Hi, This looks like the Pawl in the gearbox has been broken/damaged or even left out when the box was overhauled.
It lock the gearbox whilst in park so acting like a brake.
It could have occurred if someone put the vehicle in park whilst still moving.
Hope this helps?
Press the Blue button please to appraise My FREE! Effort.
Thank You!
Paul 'W' U.K.
Feb 28, 2009 | 2003 Chevrolet Silverado Ss
My bosch dish washer won't work. A number 1 is displayed on the electronic panel. what does this mean Paul
Helloduranjp,
Welcome to fixya.
You said, Your Bosch dish washer won't work. A number 1 is displayed on the electronic panel.
If it is displaying"01" then that means the extra dry setting is being applied!
Did you try to use the extra Dry setting?
Did the dishwasher work before this or is it brand new?
What is the model number and year?
Let me know ! I'm waiting for your response
Below is and example of the usage of 01 or 00 in a Bosch Dishwasher!
Extra Dry Heat
With this option you can raise the temperature of the rinse water and increase the drying
time which will result in improved drying.
To activate :
Press and hold the left cancel drain button ,
Then press and hold the on/off button when the LED display shows a, "00" or a "01"
To enable the additional drying heat,press the left cancel drain button until the LED display shows a "01"
To disable the additional drying heat,press the left cancel drain button until the LED display shows a "00"
press the on/off button to save the settings.
Huuum
Oct 02, 2008 | Bosch Dishwashers
Cant use dryer
Hi Haziel,
Is it that you want to dry only or wash 'n' dry straight through in one go?
If it's to dry only...
1. Switch the machine on
2. Press the Auto Dry or Timed Dry button until the neon light illuminates.
3. For Auto Dry press the button for 2 seconds to achieve the neon indicator to light up. then press the button until the glow is beside the level of drying you require.
4. For Timed Dry press the button until the time you require is in the display.
5. Press the Start/Pause key to start the cycle
Please note: in the Timed dry any time above 60 minutes will be displayed as 70, 75, 80, 85 etc. but then will be shown as 1:10, 1:15, 1:20, 1:25.
For wash 'n' dry straight through...
1. Switch the machine on.
2. Select the fabric.
3. Change the temperature or spin speed if necessary.
4. Select any extra options if required.
5. Follow the above to achieve the drying accompanied by the wash.
6. Then press the Start/Pause button to get the cycle under way.
There is a downloadable PDF of the user manual for this machine on the Service Force website, if you require the programming sequence guide, which, is covered in the user manual, should this explanation prove unhelpful.
I hope this does help you
WD Pro
Feb 17, 2008 | Zanussi WJD1667W Front Load Washer / Dryer
Maytag Washer Not Completely Rinsing
If your washer has an extra rinse button try pushing it. My Maytag refuses to wash unless that button is pushed, so in your case it may not be completing the rinse cycle correctly.
Just a suggestion.
Jan 03, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Microsoft Wireless IntelliMouse Explorer Logo
216 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
