Home | Toshiba | 42H81 42 in. Rear Projection Television | Toshiba projestion 42 ...
Toshiba 42H81 42 in. Rear Projection Television
Problem for Toshiba 42H81 42 in. Rear Projection Television
Toshiba projestion 42 has what looks like 3d in
By suarezga63 on Jul 18, 2009
toshiba projestion 42 has what looks like 3d in the picture
Solution #1
posted on Jul 18, 2009
Not Rated)
Slinteriors
Rank: Guru  Toshiba Expert Televisions & Videos  Expert
Rating: 89%, 3632 votes
the toshiba convergence repair kit is available at the following link for your model. It contains the parts and cd with detailed instructions
http://www.tvrepairworld.com/
Was this helpful?
Yes
No
Popular Solutions for Toshiba 42H81 42 in. Rear
Questions and Unsolved Problems for Toshiba 42H81 42 in. Rear
Do you recommend Toshiba 42H81 42 in. Rear Projection Television?
Answer
Answer
tv works ok for 35 minutes then it goes to blinking. turn off till fan shuts off it go for 35 than... (More)
Answer
i need the codes so i can put everything on 1 remote for my tv
Answer
hi. my tv just wouldnt switch on. sleep light is flashin green and on light flashing green. pls pls... (More)
Answer
I have a toshiba rear projection tv that after like 5 min. of running the the screen and bulb will... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Toshiba 42H81 42 in. Rear...:
Top Projection Television Experts
Rank: Guru Guru
Solutions: 1454
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Projection Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
