Question about Toshiba (MK6034GAX) 60 GB Hard Drive
Toshiba MK6034GAX Shows only 30gb
I just bought from a customer this Toshiba MK6034GAX laptop hard drive. The label indicates that this is a 60gb hard drive, but when i try to install it in my laptop, it showed only 31.5 gb. How is this happen. There is only one partition when viewed from windows disk management services. What should I do to access the remaining disk space? Please help!
  • 31 Answers
Linux may be on another partition and Windows cannot recognize it, otherwise the MBR could be damaged and you should conect it externally and run a disk check on the drive.
Posted on Jul 18, 2009
I have been given a Averatec series 3200 laptop along with 3 different hard drives ,can you tell me which Seagate and Hatachi hard drives fit this computer
what are the HDDs you have... type and size and speed is needed.
and if you can plug in one. then see if it boots, and works. then that one is proper, and you can test ea HDD and mark it will accept :
20gb, 30gb, 40gb, 60gb 80gb, 120gb,250gb - ATA 2,3,4,5 interface
Mar 03, 2015 | Averatec 3200 Series Notebook
My external hardisk is showing in device manager but it is not showing in disk manager
**Turn your computer off, then unplug the USB cable and then the power to the drive. Restart you computer, plug the power into the hard drive, wait 10 seconds and then plug the USB into the computer. This clears the hard drive buffer. See if the drive shows up in disk management. Before formating, turn off your antivirus. **
**1. Test your drive on another pc
2. Check your bios settings
Feb 03, 2010 | Toshiba MK6034GAX (HDD2D17) 60 GB Hard...
Hi my xbox is arcade model 2007. Update probs.
the problem here is the type of xbox u have the xbox arcade has a 25-30gb hard drive if i am not mistaken while the premiuim holds 60gb your best option is to buy a 60gb hard drive transfer everything over to that one the buy a premiuim xbox for 20-30 more then a arcade for almost double the space
Jan 16, 2010 | Microsoft Xbox 360 Console
I have a new mk6034gax HDD from Toshiba which is labelled as 60GB, but on 2 different PCs the bios only shows it as 40GB
the hd has a internal registers, for oem old moterboards. you need to reset this registers and program correct values.
you may find this utilities on toshiba website on service
area
Nov 27, 2009 | Toshiba MK6034GAX (HDD2D17) 60 GB Hard...
I have a 60gb hard drive on acer aspire 3690 but
you can transfer some of your files from My Document to D:/
Sep 12, 2009 | Computers & Internet
The light come on but it says it will not start
If you are running any Windows OS older than MS 2000, then it will not work unless the drivers are copied to the system's HDD. Windows XP and Vista are preferrable. Check your electrical power outlet for the right voltage. As a guard against damage, such devices don't work outside prescribed voltage range. On that same connector, try attaching a flesh drive and check for its functionality. If ok, then there is likely a factory fault and should be returned for replacement or refund. Good luck
Apr 27, 2009 | Computers & Internet
Hard drive and memory
the laptop should pick up a 20gb or 60gb ide hard drive with no problem
Memory Upgrade for Toshiba Satellite 2775XDVD Laptop, the Toshiba Satellite 2775XDVD Laptop takes the PC100 SDRAM SODIMMs Memory Type, and comes installed with 64 MB (non-removable) of Memory. You can upgrade your Toshiba Satellite 2775XDVD Laptop to up to a maximum of 192 MB Memory, the system has 1 socket to install Memory, already with 64 MB (non-removable) standard Memory installed. For best Laptop performance use the maximum amount of allowed Memory per slot for your Laptop.
Choose the following Memory Upgrade for Toshiba Satellite 2775XDVD Laptop
Dec 01, 2008 | Toshiba Satellite 2775XDVD Notebook
120gb Hard Drive
I'm going to say that the drive is mislabeled. I've ran into this before with Western Digital two or three times, and quite a few times with various memory chips. Contact WD support, explain the problem, and their usually pretty good about getting the right one to you.
Aug 14, 2008 | Acer Aspire 5050-3242 Notebook
Change of HD problems
check if the hard drive you bought is an IDE or SATA hard drive. if it is SATA you cant use it on your laptop. it should be IDE
Dec 11, 2007 | Computers & Internet
Toshiba (MK6034GAX) 60 GB Hard Drive Logo
123 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
