Question about Philips 47PFL3603D LCD TV
Philips 47PFL3603D LCD TV - TV not responding to remote
This is alsmost identical to my problem, only variable change is i have Comcast neither remote will get the unit to turn on or anything. The white led in the lower left corner is lit but doesnt react when any button on either remote is pressed. I have done all the basics verified the battery position and even unplugged he unit for 60+ seconds....no change in state. I also verified that i have the lastest software
LC8IULP-1.15
  • wirkinman123 Aug 05, 2013
    I have the same problem as the original poter. However, on my Magnavox 52MF437S/37, When the tv stops responding to the remote functions, the buttons on the side of the tv dont operate either. When this happens, I unplug the tv and replug it. Everything is back to normal.
    Sniper:
  • 53 Answers
One thing you can do is take your cellphone's camera, point the remote at the camera, and press a button. You should be able to see the infrared sensor firing.
If you can verify that, your remote's fine.
In this case, what you have is a bad IR sensor board. The part # is:
313926859182. Right now, there are so many of these things failing, that finding the original might be difficult.
Don't fear, though; it's a small part. And, best of all, it's cheap. Expect to pay around $5.00 for the part, maybe a bit more, maybe less, depending on the supplier.
Now, if you are handy with a power drill (fitted with an octagon/star bit for the back of your set), you can remove the 20 or so star-bit screws from the back of your television. Don't worry about putting the set on the floor. If your TV is on a stand, simply turn it around. You'll need to remove the stand screws, but you won't need to take the TV off of the stand.
Now that you've taken the screws out and removed the back cover, look in the lower left hand area of your set. You'll see a 4 inch long circuit board with 2 cables running to it. Pull the cables out (they'll come out easy). Remove the 2 star-bit screws.
One of the board's sides is under a plastic tab. Lift the board out of its slot from the other side.
Put your new board in, reconnect the two cables, reassemble the back and you are set to go.
Expensive repair for a few bucks and a better IR sensor.
This advice assumes that the control buttons (power, volume, channel) located on the side of the set still function. It also assumes you are able to use those buttons to power on the set and verify that you still have a picture on the screen.
Posted on Aug 02, 2009
  • 4 more comments
  • Bob McAnally Jan 19, 2012
    Kudos to the gang at FixYa for a wonderful site. This fix for my Philips TV was spot-on and cheap. Only snag I had was trying to get the plugs detatched from the board, as I did not want to tug on the wires, so I used a razor blade to pry them out while trying not to nick the wires. With that accomplished, the rest was really easy. Final tally...$20 and 2 1/2 hrs. labor. Thanks again to FixYa!
  • John Jun 03, 2012
    I also had the same problem with my IR sensor board 313926859182.
    I was also recommended before buying the new part to try to alter the old IR board by scraping off the capacitor sticking out just to the right of the connectors leading up to the power/volume controls on the TV. The rationale is, if I am going to replace the part anyway, why not try to mess with it?
    Funny enough, scraping off the capacitor worked perfect, now I saved myself $20 and have a working remote control now.
  • christi87807
    christi87807 Oct 12, 2012
    @Drannor68, was the capacitor small and black, like a little capsule? I removed it from nine and now the LED power indicator doesn't work. Nothing else has changed.
  • Brad Davis
    Brad Davis Mar 01, 2014
    I am amazed that this worked! I scrapped off the cap....and it works!
  • Bkpman
    Bkpman Jul 20, 2014
    Me too it works
  • Bkpman
    Bkpman Jul 20, 2014
    I'm posting the photo of the lil capacitor I plucked off with a plier .... I can't believe my TV remote works after four flipping years
Posted on Jun 03, 2012
  • Stephanie M Feb 09, 2014
    I am so happy I found this information. Thank you so much for providing the part number and instructions. I bought the part and followed the instructions exactly (except I didn't have a drill - very aggravating). My boyfriend and I worked on it together and now our remote is working! (after four years of not being able to use it) The repairman wanted about $150 to fix it - no way, did it ourselves thanks to your help!
My remote does not work
Remote Code for LCD Coby TV model TFTV2425 - Comcast Help and ...
forums.xfinity.com/t5/XfinityTV.../Remote...LCD-Coby-TV.../916553
Apr 14, 2011 - Remote Code for LCD Coby TV model TFTV2425 ... If your home entertainment device does not respond to the remote control after trying all of the codes listed for your ... I just changed to an hd box andcodes given by comcast did not work. Looked at my old remote notes and that is what I found and it works. Comcast DVR remote won't "select" an input from th...
May 26, 2011
Remote code for coby tvs
Feb 7, 2011
Comcast remote code for Coby tv/dvd
Mar 20, 2010
More results from forums.xfinity.com
Coby tv remote doesn t work Questions & Answers - Fixya
www.fixya.com > Forum > Tags > tv remote doesn t work
Dec 15, 2015 | Coby TFDVD2274 22 in. LCD TV
My philips pfl8404h remote not working think its the IR sensor where do i find this to replace
hi quick test to do , have you got an am radio if so point your remote at the radio and press the button one by one you should hear interference this mean the remote is working ok , hope it helps
regards
shaun
Mar 18, 2014 | Philips 47PFL3603D LCD TV
Phillips 47pfl3603d blank screen with sound
if the Tv have back light the problem is t-con if not the problem is inverter
Jun 06, 2012 | Philips 47PFL3603D LCD TV
Remote doesn't control. batteries are good, but there is no apparent connection between the remote and the TV. It is in use with a Comcast turner-DVR, which works fine, but I have to turn on and adjust...
Are you using Comcast remote to control the TV? When you program the Comcast remote to control your TV, it will do two functions: on/off, and Volume control. The Comcast can also be programmed not to control the volume of the TV (TV volume will have to be set at about mid level manually, then the Comcast box will send out variable sound level to the TV), just on/off ONLY.
Oct 27, 2009 | Olevia 227-S11 27 in. LCD TV
I can't get my philips 47pfl3603d/f7 to work with a coby dvd968 home theater system the tv has one spdif coaxial out and coby also has one i pluged the cable, still can't get to hear my tv channels thru...
You need to select the source of your home theater system. Press <SOURCE> on the home theater remote to switch between DVD, TUNER, and LINE modes. Select LINE, then you should now hear audio from your TV, Please make sure that your TV is not muted, just increase the volume until you hear audio on home theater. Also increase the volume of your home theater.
Regards,
Jeep Brainy
Jul 26, 2009 | Philips 47PFL3603D LCD TV
Comcast remote won't accept codes for Proscan TV
I had the same problem. I have the 40 inch Proscan and they supplied a remote control guide for comcast. It was only 4 digits and it did not work. I called Comcast and they did not know. I found it needed 5 digits so I added a 1 and it worked The code is 10178. Hope it works for you.
Jul 21, 2009 | Sylvania LC420SS8 LCD TV
Need code for comcast remote control
HI,
Could you kindly give the exact model of the comcast remote that you are using.
Thanks
Proton
Jan 03, 2009 | Philips 47PFL7403D 47 in. LCD TV
Philips 47PFL3603D LCD TV Logo
14,170 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
